2G TSX Chat, Chit, and General Info Thread
Old 02-08-2017, 10:35 AM
  #23521
Received 16,260 Likes on 11,971 Posts
lady gaga bumps
Old 02-10-2017, 09:13 AM
  #23522
2snail's Avatar
Originally Posted by Rdub81
This is what the new style grille looks like if anyone was wondering
this grill looks great!, please post pictures when you get yours installed. I need to get a new bumper and I also have grigio and im kicking myself for not ordering the modulo when it was in stock.
Old 02-10-2017, 12:45 PM
  #23523
Rdub81's Avatar
Originally Posted by cu2wagon
Your bumps. Your bumps. Your lovely modulo front bumps.
lady gaga bumps
Lol!
ok, will do. I know, hopefully the rear is still in stock when I'm ready to get that. That is, IF they're still available as of now
Old 02-15-2017, 05:46 PM
  #23524
rawger's Avatar
Recently realized my A/C didn't seem to be as cool, even after dropping the temperature down lower than usual. Then today I happened to feel the air flow from the passenger side and it was noticeably cooler compared to the two vents for the driver. The temps read the same, even tried turning "sync" on and off and didn't notice a difference. Any ideas on what could be the issue?
Old 02-15-2017, 09:25 PM
  #23525
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Can you change it to the floor vents and see they feel different from side to side?
Since the car uses wizardry to be able to have two different temperatures on the driver/passenger side, you might need to add more sacrificed goats blood.
My guess would be a stuck mixer door on the driver side. Although I'm just assuming based on how a normal car HVAC works... There's some flappy doojober that mixes the cold AC with warm air to modulate the temperature. Seems like if you're getting significantly warmer air on one side, that flappy thing might be stuck. Did you try going full hot and full cold to try to get it moving? Maybe just running it through some cycles will get it working.
Old 02-15-2017, 11:21 PM
  #23526
rawger's Avatar
I'll give what you mentioned a shot next time I drive. haven't done the whole hot to cold or checked the floor vents yet.
Also checked my VIN today and my car has the airbag recall. How long does that normally take for them to fix?
Old 02-16-2017, 10:28 AM
  #23527
Nghi Hoang's Avatar
J-Power ($190) or SPC camber ($450) ?
I have a set of wheel (19x9+30 / 19x9.5+30) coming and I'm going for tire size 245/35 and 255/35. I need some help with the camber kit.
Which one should I choose for daily driving?
Old 02-16-2017, 10:43 AM
  #23528
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
SPC is probably the best aftermarket option we have. But yes it's a lot more expensive than J-Power.
I have the J-Power 6pc rear camber kit, and I'm pretty sure it's just an SPC eBay knockoff. I've had them on for about 2 years now, and I don't see anything wrong with them other than some surface rust (I live in Canada and daily drive it through all 4 seasons, so I'm not at all surprised). I'm definitely no expert, but the bushings appear to be ok still from a basic visual inspection I did.
If you want the best without getting them custom made, SPC is probably the best option. But I like my J-Powers just fine, especially for the price.
edit: FYI, with 19x9+30 up front on 245s, you will probably need a front camber kit if you're lowered. I'm on 18x9 +30 up front on 235/40R18 Michelin PSS tires, and there's noticeable poke on natural camber from a ~2" drop. If I had 245s I would definitely rub. I bought an Ingalls balljoint front camber kit for the front, and will install it this spring. Will probably need around -2 degrees of camber or a tad more negative.
edit2: I have 18x10 +38 also on 255/35R18 tires in the rear, which is pretty equivalent to your 9.5 +30. I actually used my rear camber kit to make the camber more positive and I'm not rubbing at around -2 degrees (mind you, my rear fenders are rolled). If you're simply concerned about rubbing, I doubt you will too (although 255/35s will be a tad beefier on your 9.5s than my 10s). If you want to correct the camber like I did, then it's a no brainer to get a kit. If your only concern is rubbing, then try it out first before ordering because I suspect you won't if your rear fenders are rolled.
Nghi Hoang (02-16-2017)
Old 02-16-2017, 11:19 AM
  #23529
Nghi Hoang's Avatar
I having Tein SA on my car, and all fenders will be roll for sure. So according to your information, I will need font camber kit, so is this the one that Im gonna get?
Old 02-16-2017, 01:37 PM
  #23530
xtcnrice's Avatar
Yeah that's what I bought. But if you're not that low, you might not need it. Usually best to try it out first before you purchase, so that you don't end up wasting money. But if you're definitely going to be very low, then feel free to order it now.
Old 02-16-2017, 07:10 PM
  #23531
julius071's Avatar
Check out T-Demand ????T-DEMAND(????????)
Old 02-18-2017, 02:42 PM
  #23532
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
Those zip ties are beautiful
julius071 (02-18-2017)
Old 02-18-2017, 05:17 PM
  #23533
julius071's Avatar
Thanks!
Old 02-19-2017, 01:05 PM
  #23534
Nghi Hoang's Avatar
How much is it for a set? If it too much I cant
And still waiting for the wheel it been 3 months
Old 02-19-2017, 07:46 PM
  #23535
julius071's Avatar
Too much to mention.
The following 2 users liked this post by julius071:
Nghi Hoang (02-21-2017), xtcnrice (02-20-2017)
Old 02-21-2017, 03:26 AM
  #23536
AyyCee's Avatar
Hey guys, this is driving me crazy. Been experiencing some clunking noises when driving over bumpy roads on my front passenger side of the wheel for the last 3 or so months.
It is most prominent when the car hasn't been driven for a few hours (e.g. in the morning, or parked at school for the whole day), and the sound typically lessens as I drive.
Initially thought to be endlinks, and had that replaced but the sound still persists. I am also running Tein Street Basis coilovers.
Anyone have an idea of what it might be?
Old 02-21-2017, 07:17 AM
  #23537
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
Jack your car up, put it in nuetral and spin the wheels and see if you can isolate the sound
Old 02-21-2017, 11:39 AM
  #23538
xtcnrice's Avatar
Ball joint?
Old 02-21-2017, 01:21 PM
  #23539
CU2squad member
gtacu2squad's Avatar
Ball joint?
one of my biggest fears ...
Old 02-22-2017, 08:31 AM
  #23540
icu2tsx's Avatar
the window for repair is 2 hours, but it's a 30 min job.
Old 02-23-2017, 07:56 PM
  #23541
ROTAREDOM
ssjoeboe9's Avatar
You know you've done your taxes right when you come out to receiving very little or owing very little to the government... but damn $170 isn't even enough to cover my next costco visit!
Le Sigh**
Old 02-23-2017, 07:59 PM
  #23542
Nghi Hoang's Avatar
Le Sigh**
You making too much money. that's why bro
xtcnrice (02-24-2017)
Old 02-24-2017, 07:50 AM
  #23543
ROTAREDOM
ssjoeboe9's Avatar
lol feels more like the gov. is taking too much of my money haha.
Old 02-24-2017, 07:54 AM
  #23544
julius071's Avatar
Le Sigh**
I feel ya man. Like what I always say "you make more money the next day."
Old 02-24-2017, 07:55 AM
  #23545
Received 8,568 Likes on 6,621 Posts
Le Sigh**
Good job
I always when I see my friends talk about their 3 thousand dollar return.. I be like, "you have the government an interest free loan!!!
Old 02-24-2017, 08:56 AM
  #23546
icu2tsx's Avatar
Le Sigh**
Time to start making some tax deductible mini Joe's
ssjoeboe9 (02-24-2017)
Old 02-24-2017, 01:42 PM
  #23547
ROTAREDOM
ssjoeboe9's Avatar
Good job
Yeah the most BS part of the whole thing is that if you don't pay your taxes, or incorrectly file your taxes and the government comes after you, they slap you with a penalty and then make you pay the amount you owe, plus interest.... YET they can hold our money for an entire year without paying us interest back on the money they hold. It's some booooooo sheeet
I think it's deeply ingrained in our American Roots to be upset at our tax system haha
Old 02-24-2017, 08:01 PM
  #23548
Nghi Hoang's Avatar
About the modulo font on 2011+, have anyone try that yet? I wanted to have it but when I do some research it may cost about 1,2k
And do we really need all of those item? (I found it from xtcnrice thread)
Old 02-24-2017, 08:10 PM
  #23549
Unregistered Member
Harper's Avatar
I believe you need 09-10 fogs + grille to run the modulo front.
xtcnrice (02-25-2017)
Old 02-25-2017, 12:35 PM
  #23550
julius071's Avatar
Ditto.
Old 02-25-2017, 12:36 PM
  #23551
julius071's Avatar
If you plan on not running foglights.
Old 02-25-2017, 07:05 PM
  #23552
VR1
Itz JDM y0!
VR1's Avatar
You can get a grill for less then $380 from other members on here or the fb page.
Old 02-25-2017, 07:27 PM
  #23553
Rdub81's Avatar
Check out this eBay find. Some people...
09 10 2009 2010 ACURA TSX FRONT BUMPER COVER OEM S | eBay
Old 02-25-2017, 10:45 PM
  #23554
xtcnrice's Avatar
^lmao
Rdub81 (02-26-2017)
Old 02-25-2017, 10:47 PM
  #23555
xtcnrice's Avatar
Yep.. it'll be one of the last things I do to this car cosmetically. It's too expensive for 11+ vehicles, and plus it doesn't come in my car's colour so I'd have to spend on a respray as well.
Old 02-25-2017, 11:20 PM
  #23556
Unregistered Member
Harper's Avatar
Your sig is so colorful , ahem :ghey:
xtcnrice (02-26-2017)
Old 02-26-2017, 01:50 PM
  #23557
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
09 10 2009 2010 ACURA TSX FRONT BUMPER COVER OEM S eBay
I couldn't even sell my lightly scratched rear bumper for $50. It was up for months.
Old 02-26-2017, 02:02 PM
  #23558
cu2wagon's Avatar
Super JDM Dorifo-san action bumper. Much battle damage. Very authentic. Hyper wow.
Old 02-26-2017, 04:51 PM
  #23559
ROTAREDOM
ssjoeboe9's Avatar
I can't wait to sell my entire vehicle!
Old 02-26-2017, 05:23 PM
  #23560
Unregistered Member
Harper's Avatar
I'll buy it now for $34.50
xtcnrice (02-27-2017)
Quick Reply: 2G TSX Chat, Chit, and General Info Thread
