Brake/Speaker problems fixed on 2010?
I just leased a 10' TSX last week and then i registered for this site. I was reading around and saw that alot of people with the 09's are having their brakes go extremely early and their speakers blow. Does anyone know if these things have been fixed for the 2010 model?
i just bought my car almost a month ago and i had thought they had been fixed but i did recently read that they havent. but going through the forums, i cant remember seeing anyone with a 2010 that has had the speaker problems. plus, i have been blasting it and i havent had any problems so far. maybe cause i have a tech? idk
the brakes i cant be sure of. mine is still basically brand new, but i again i havent hear much from the forum about 2010 brakes. maybe the 09 is more popular on here.
i have a 2010 base and I "blast" my music, going up to mid to high 20's, and i have no problem with the speakers yet. just tweak the tone settings a bit, and don't max out the bass. i think i have the treble at 6, bass at 3 or 4, subw at 5. My electronic music sounds amazing.
what about the engine pinging?
i havent gotten a straight answer on that yet.
im not even sure on what it sounds like and wouldnt know what to listen for. ive tried but i havent heard anything out of the ordinary.
Yet, not everybody is experiencing this. In fact, not one of my customers has ever commented on brakes being replaced pre-maturely. The only place I hear about 10K brake life is here.
i grew up in hawaii, and reaching 10k miles takes longer to rack up if you're just doing daily driving and commute. maybe this year you'll hear about it more
I think the main point of contention here is not the actual life of the brake pads, but rather their intended life span and whether they are reaching it. For example, as I recall, our Integra's used to use rear brake pads every 20,000 miles or so. Personally, I always thought this was a little quick, but since it was consistent amongst our 1994, 1997, and 2000 model year Integras, I became comfortable that that was how the machine was designed. And in this way I never viewed it as a "defect"
So with regard to the TSX I don't believe there's a definitive answer that all of the cars will wear out the brake pads at 10,000 miles. I know this discussion is about the second generation TSXs and I don't recall if there were similar complaints about the first generation TSX (but I'm guessing there were). For the record, my 2008 TSX is at 26,000 miles and not showing any signs that I need to do brakes. As always, "your mileage may vary"
Note that, according to the 2010 V6 service manual, the speakers in the Base are 4 ohm, vs. 2 Ohm in the Tech. So it looks like the tech has different speakers.
While I certainly don't discount the possibility, I can say that there have been two generations of service loaners and none of them have had to have the brakes replaced before we sold them as used cars. These cars were sold between 12,000 and 15,000 miles. And of course, these were driven by many drivers with different driving styles and different commutes.
15,000 on my Wife's 2010. No brake problems or speaker problems.
In fact the only thing is of my doing. I need to get to a dealer to reset the TPMS system.
She is getting over 28mpg overall, (the TSX says 31.5) So I figure it is lower.
But the reality of life is that rotors on Honda products have always been a little on the small size. Our 01 CL-S is famous for going through front rotors like water.
I was just at the dealer for an unrelated issue and asked them this question. The service guy stated the brakes will go every 10000-15000 miles on the rear. He stated they purposed engineered it that way so the vehicle doesn't sway forward when braking. He said he hadn't seen anything about the speaker problems.
Conversely, if you'd didn't know about the issue (before you bought), and were rudely awakened to find that rear brake pads have a short life span, you can now take comfort in that the knowledge that your car is not defective. They are all that way.
Also they'll go often if you ride them for a nice smooth brake everytime you slow down from every speed, if you know its a red light.. dont' speed up to it, if you know you got time to stop, stop a little harder, let off the brake and do it again till you get there.. save brakes.
THƎSƎ HOPƎFUL MACHINƎS
I am sorry any dealer that is saying that the rear brake is wearing out earlier is a design issue is lying.
First off the facts do not correlate. 70% of your braking power is on the front wheels, even if they put it to 50-50, the brake wear is uneven. On my car the inside pads wear out faster than the outside pads (i got pictures to prove it).
Which means its a design fault. Sorry dealer, you are wrong.
I have had my 2010 TSX Tech for a little longer than a week with ~400 miles on it and I have no experienced the speaker blow out problems, engine pinging or premature break wear yet! *knocks heavily on wood*
i'm pretty sure on my way to work this morning i either just blew or just noticed a blown speaker on my 2010 tech. either passenger side tweeter or speaker not sure. i have sub on 3, bass on C, and treble on 1.. no reason for this. also my friend works at an auto parts store and thought it was funny when he was delivering break pads for a TSX with 9k miles, thats when i took notice to the break issues.
as you may have noticed, almost all (or maybe all) of the blown speakers are with the tech models and not with the non-tech. i believe someone confirmed that the amp in the tech TSX is crappy and ends up blowing out speakers.
as for the brakes, they have always been a weak spot in Hondas, and the TSX is no different. mine have been lightly squealing since almost day 1, and i have about 3,000 miles on them now. i haven't had time to take it in to the dealer but i probably will at some point.
you leased the car so you'll be in the warranty period anyway. just go out and enjoy it, and if something goes wrong, Acura should fix these for you without asking any questions.
I guess I've been pretty lucky with my car. Brake pads still good at 23k miles and no blown speakers. No other car issues. I do get the occasional pinging but that only happens when I get 87 gas.
so instead of the making a new thread i thought id ask here - anyone know if the speaker problem has been solved/fixed? i did some heavy googling and got a variety of answers - some ppl claim that an updated version of the speakers is now put in as a replacement of blown ones, or that only a certain batch of the 2010's still had the problem
Having the same issue my 10 6cy - tech on the speakers; sounds like a humming even when the volume is set to min. Almost as if there is some kind of interference for power fluctuation being heard through the pass/front speaker.
Brought in today, they swapped pass front speaker inside bottom of door and they said the problem is still there. They are going to keep it for a day or so; I'll give an update as to what they wind up replacing next...
i got a 2010 non tech and ive had my 2 front and 2 rear speakers replaced and im pretty sure they are blown again right now but i havent had time to bring it in..and also the breaks been sqeeking since i bought the car
I have leased a 2010 premium since July 2010 and have experienced no pinging or speaker issues. However, when winter hit with lots of snow, humidity, and cold, i have noticed that my breaks squeak quite noticeably in the first few minuteséstops after the car has been sitting. Usually goes away after that.
I've had the rear brakes serviced on my 2009 TSX at 31k miles I believe they replaced the brake pads with the "upgraded" set. My vehicle fell under the brake pad settlement still waiting on them to approve the reimbursement. Also I should note my front brakes are squeaky they've resurfaced the rotors at 12k miles due to excessive vibration during braking -- vibration went away but squeaking didn't. Just small annoyances the brakes work perfectly fine overall
weird....I just had that happen on my car for the first time today. Parked it at the train station all day to avoid driving in sleet and freezing rain and when I was leaving the garage, I noticed they were squeaking which they have never done before (typically park in closed garages). It stopped pretty much right away, so hopefully nothing but being cold.
Brake problem 2010 TSX V6 16,100 miles
Just got back from dealer and boy I'm pissed!
Went to Vegas last week and the brakes were very bad and felt a vibration! Vegas Mechanic told me they have had many cars with the same problem! Told me brakes are not covered and to check at my local dealer if they can do anything,
After dealing with dealer in San Diego they told me the same thing not covered. They told me to call Acura. Acura said they would split it with me and only charge me $100 for the front brakes. After I said No I want you to pay for it all they said let us look at the car again and measure how much breaks are left. Long story short They paid for the front brakes! They also said there is a service bulletin now on the front brakes. After a few phone calls a lot of time they said they will fix the car charge me $150 for the back brakes and to get reimbursed from Acura.
After all of this I pick up the car today and they put a dent in the side!!!
Then they said this could not have happened here!
Well I did not see it when I dropped it off and the paper work did not show any dents! The manger said he will fix it now.
To top it all off they gave the car back on fumes gas tank on E
I had a 1/4 tank when I dropped it off!
What a WASTE OF TIME!!!!!!!!!!!!!!!!!!
