2009+ Honda Accord Euro Bixenon Headlights (Left Hand Drive)
Old 01-12-2017, 02:32 PM
  #41
4th Gear
J_lu93's Avatar
Did you pay him through paypal or your credit card i formation?
Old 01-12-2017, 02:33 PM
  #42
julius071's Avatar
Through PayPal.
Old 01-12-2017, 02:35 PM
  #43
4th Gear
J_lu93's Avatar
Originally Posted by julius071
Through PayPal.
ohh ok thanks. Btw thanks for posting this up saved me alot of money lol
xtcnrice (01-13-2017)
Old 01-12-2017, 02:37 PM
  #44
julius071's Avatar
No problem, glad I could help. If you need harness to be done contact, Kevin over at Ratchet Racing CU2/CW2 CUSTOM PLUG AND PLAY HEADLIGHT HARNESS
Old 02-07-2017, 12:31 PM
  #45
kostantinos's Avatar
The headlights don't come adjusted from Honda, so they need proper adjusting. That is why you are probably seeing your low beam lower than it should be.
But the high beam part is true. High beam will be brighter since it's hid, but its more focused as it's going through a projector and not widespread as a reflector bowl.
Old 02-07-2017, 12:50 PM
  #46
julius071's Avatar
I have the headlight adjuster switch and at what setting should regular drive height be? Setting 1?
Old 02-07-2017, 12:58 PM
  #47
I had the dealer adjust mine and what they did is set the headlight adjuster switch to 2, and then align the headlights correctly.
So I can go up or down with the adjuster if need be.
Old 02-07-2017, 12:59 PM
  #48
julius071's Avatar
How much did the dealer cost you to adjust the headlights
Old 02-07-2017, 01:05 PM
  #49
60 I think
Old 02-07-2017, 01:08 PM
  #50
julius071's Avatar
Will they even touch non USDM OEM parts?
Old 02-07-2017, 01:13 PM
  #51
I know the service manager and he helps me out with things, some dealers won't
Old 02-07-2017, 01:16 PM
  #52
julius071's Avatar
I knew it...
Old 02-11-2017, 09:39 PM
  #53
balistek's Avatar
Did the US dollar get stronger? I put in the headlights and the final price with shipping is £436.74. Currency converter puts that to 545.31 shipped.
Old 02-11-2017, 10:34 PM
  #54
julius071's Avatar
Nope. Click the link in the first post.
Old 02-12-2017, 12:12 AM
  #55
balistek's Avatar
I did. I got to the site and found the parts and went to the cart.
Comes out to 545 bucks. I think I did it right.
Old 02-12-2017, 09:02 AM
  #56
julius071's Avatar
That is correct. It's better pricing anywhere I found actually. Please add comment "bubble wrap package before shipping"
xtcnrice (02-12-2017)
Old 02-15-2017, 09:26 AM
  #57
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Has anyone changed any of the bixenon bulbs? I decided to save money and not get the harness that includes working intersection lights (so they function as parking lights now), and I realize they're quite blinding (and rightfully so, given their original intentions); much like high beams but on the side haha. Thinking of switching them out to LEDs to not blind people as much, and maybe go with a less halogen-y look.
On that topic, has anyone changed any of the bulbs besides the D2S low beams? i.e., intersection lights, turn signals, parking lights (the "blue" tinted strip). If so, what did you get?
Old 02-15-2017, 10:15 AM
  #58
julius071's Avatar
I used the following:
HIDs: Osram Xenarc 66240 Nightbreaker
Interestion lights: OEM from bixenon headlights
Turn Signals: OEM from bixenon headlights
Parking Lights ("blue" tinted strip): T10/194: Osram LEDriving Cool White
Yes, it does blind other people but people sees the light when doing your head check.
xtcnrice (02-15-2017)
Old 02-15-2017, 11:08 AM
  #59
xtcnrice's Avatar
Thanks!
Yeah the intersection lights definitely serve a purpose no doubt. I just feel bad when I'm sitting in traffic or cruising at the same speed as the next guy on the freeway at night, and my lights intersection lights are blinding the side of their eyes lmao, since mine function as parking lights and will forever be on as long as my low beams are on.
Do the T10/194 Osram LEDriving Cool Whites need any special adaptor to fit? Any resistors or anything else needed?
Lastly, is your above-mentioned setup part of your air ride teaser vid?
https://drive.google.com/file/d/0B2O...NGLXdmRzg/view
Old 02-15-2017, 11:39 AM
  #60
julius071's Avatar
Originally Posted by xtcnrice
Thanks!
No special adapter is needed but these are bipolar and only lights up when plugged in correctly so don't freak out when it doesn't work first try. I think this happens to all T10/194 style bulbs, someone correct me if I am wrong.
Yes the video https://drive.google.com/file/d/0B2O...NGLXdmRzg/view has all the bulbs installed. I bought all the bulbs before hand then install all at once, I wasn't too worried about the intersection lights and blinkers as I am planning to do LEDs for the intersection lights and LED strips for the blinkers later in the year.
https://acurazine.com/forums/2g-tsx-...ra-tsx-948724/ Don't forget to like, comment and subscribe!
Old 05-05-2017, 11:59 PM
  #61
9th Gear
Volkr55's Avatar
Leveling
Hello,
Did you find any issues leveling out the beam? I have a set but they are not shooting level. Any suggestions?
Old 05-08-2017, 12:24 PM
  #62
julius071's Avatar
Do you have the leveling harness plugged in? Harness is available here: CU2/CW2 CUSTOM PLUG AND PLAY HEADLIGHT HARNESS
Or you could manually adjust the beam by the bolts on the headlights.
Old 05-08-2017, 10:41 PM
  #63
9th Gear
Volkr55's Avatar
Thanks for the info. Funny, just purchased the harness and switch. Also, purchased the plug and play harness. Wanted to get the corning lights to work. Have you installed yours yet? Any chance you can pinpoint the adjusting bolt on yours if you haven't installed yet? Appreciate the response and the info given.
Liked to see some pics if they have been installed.
Thanks again.
Old 05-09-2017, 12:20 PM
  #64
julius071's Avatar
Installed lights with "Ratchet" harness and switch with working corning lights last year.
I am not sure how to manually adjust the headlights and I am thinking you can fuss around this bolt here:
You can ask kostantinos as he went to a dealer to adjust the headlights with the headlight switch.
Old 05-09-2017, 04:20 PM
  #65
xtcnrice's Avatar
It's actually the beige one near the bottom. Turn that with a 5mm socket and it will raise/lower the beam.
Old 05-09-2017, 10:23 PM
  #66
9th Gear
Volkr55's Avatar
Thanks guys for the image. Is this the bolt that is mentioned in red?
Old 05-10-2017, 07:19 AM
  #67
xtcnrice's Avatar
Yup
Old 05-16-2017, 02:17 AM
  #68
9th Gear
Volkr55's Avatar
Thanks guys for the help. Worked as mentioned. Still have a funny step down. Beam is level then angles down then flat again. I think maybe the return wire is not facing down. I will need to check it.
Thanks again for your advice.
Old 05-16-2017, 11:04 AM
  #69
julius071's Avatar
Maybe its program to be at "OEM height" and now that you adjusted it via the 5mm bolt it goes down then back up to your adjusted angle? Would be helpful if kostantinos could give us any information on his adjustment at the dealership.
Old 05-16-2017, 01:26 PM
  #70
Unregistered Member
Harper's Avatar
something like this?
xtcnrice (05-16-2017)
Old 05-16-2017, 01:35 PM
  #71
xtcnrice's Avatar
yup I have this too
Old 05-16-2017, 02:14 PM
  #72
9th Gear
Volkr55's Avatar
That is it exactly. Anyone have a remedy? Great picture.
Old 05-16-2017, 03:48 PM
  #73
Unregistered Member
Harper's Avatar
That's normal, it's designed that way so you don't blind oncoming traffic.
The following 2 users liked this post by Harper:
julius071 (05-16-2017), kurtatx (05-17-2017)
Old 05-17-2017, 01:10 PM
  #74
Azine Jabroni
kurtatx's Avatar
Received 2,158 Likes on 1,386 Posts
Yup. My A4 has that, too
julius071 (05-17-2017)
Old 05-26-2017, 11:20 AM
  #75
the beam is supposed to be stepped like that, its not mean to be level
julius071 (05-26-2017)
