Engine oil dip stick question.
Old 08-15-2015, 01:04 PM
I like cars.
Username 0's Avatar
I checked my oil the other day and it was above the second indicator hole. Isn't it supposed to be between the two holes? Did my mechanic put to much oil in?
Old 08-15-2015, 01:32 PM
WheelMcCoy's Avatar
A little bit over the 2nd / top hole won't hurt. Engineers built in a forgiving buffer. But a lot over can be bad. Overfill lets moving parts froth the top of the oil, and air bubbles in oil won't lubricate moving metal parts properly.
Did you measure with the car on a level surface? Did you warm up the car, then turn off the engine and wait a couple of minutes for the oil to return to the pan? Some people check when the engine is cold... check your manual.
Old 08-15-2015, 02:08 PM
I like cars.
Username 0's Avatar
I checked it with the engine cold and on level ground.
Old 08-15-2015, 03:24 PM
ulrblitzer's Avatar
<p>Your mechanic probably poured in the whole 5qts instead of measuring it out. I think we're suppose to take 4.7 qts or something.</p><p>Another reason why I just do it myself.</p>
Old 08-15-2015, 03:55 PM
I like cars.
Username 0's Avatar
I just read it takes 4.2 quarts with filter and 4 quarts without filter.
Old 08-15-2015, 04:31 PM
ulrblitzer's Avatar
<p>Mine takes &gt; 4.5 qts to reach max on dip stick every time I change out. I must be draining more oil out of the crank case.</p>
Old 08-15-2015, 05:56 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Stupid question: did you clean the dipstick off before checking it? It'll look higher when you first pull it out. Sort of obvious question but
Old 08-16-2015, 12:20 PM
I like cars.
Username 0's Avatar
Yeah I have. In fact I clean and dip about 3 times.
Old 08-16-2015, 04:05 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Too much oil also leads to early catalytic converter failure.
Old 08-17-2015, 06:28 AM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
<p>^ not if you don't have any&nbsp;<img alt="Bite Lip" src="https://acurazine.com/forums/images/smilies/bitelip.gif" style="height:15px; width:15px" title="Bite Lip" /></p><p>&nbsp;</p>
xtcnrice (08-17-2015)
Old 08-17-2015, 06:33 AM
ROTAREDOM
ssjoeboe9's Avatar
<p>On another note... I just changed my oil, and I bought 1 gal, +1 qt. (It was cheaper than buying 5 individual qts). Anyways, I poured about 1/2qt through to cleanse, then poured a whole gallon. Im past the first bubble by like 1/3 of the distance to the 2nd bubble. Moral of the story, my buddy was with me who worked at Valvoline for 2 years, he was like oh we always just fill it till the second line so we can't be blamed for putting too little oil in the car. Also, if you always fill to the 2nd, then they never have to measure anything.. I just stuck with what the manual said.</p>
Old 08-17-2015, 08:05 AM
ulrblitzer's Avatar
<p>It's also easier to check for oil consumption when you have an easy baseline to read and remember&nbsp;.. i.e. filled to the 2nd bubble/max hole to start.</p>
oyayjoe
01-01-2019 10:17 PM
ulrblitzer
09-24-2015 07:42 PM
pizokk1
09-17-2015 09:29 AM
datadr
09-12-2015 09:12 PM
02tl-p
09-06-2015 10:28 PM
Quick Reply: Engine oil dip stick question.
