Sway Bar End Link
Old 05-09-2012, 04:28 PM
DannyDee's Avatar
Sway Bar End Link
Sup guys. I will be getting new tires tomorrow, (both rear tires have bad thread so the ride is very bumpy). So hopefully the ride will be smoother. But, I hear a clunking noise when I go over bumps. I am on F&F coilovers type 1. NOT slammed all the way. I did some research & I considered buying brand new end links for all sides. Should I just to see if the noise will stop, plus it will be replacing a bad OEM part with something more beefier?
Also, is there a way to check to see if they have gone bad?
Visible ways?
Thanks!
Old 05-09-2012, 08:38 PM
MechEng
03tLsNBP's Avatar
Just get the Moog end links. They're 25 bucks a side and at least one and a half times the diameter of the OEM end links. The OEM end links are shit.
shamal (03-19-2017)
Old 05-09-2012, 08:41 PM
RC99TL's Avatar
Stock bars?
Best bet the center bushings are shot. The end links rarely go with stock bars but the center bushings harden and knock just from age.
If you remove the end links at the bars' ends and then wiggle the bar from between the center bushing mounts-I bet it is loose. There should be no deflection at all other than rotating in the mounts. While you are at it replace the rear center bushings as well. You won't know they are worn but after replacement the back end will track along with the front like new.
shamal (03-19-2017)
Old 05-10-2012, 01:25 AM
'12 & '13 AL West Champs!
Gfaze's Avatar
Originally Posted by 03tlsnbp
just get the moog end links. They're 25 bucks a side and at least one and a half times the diameter of the oem end links. The oem end links are shit.
+1
Old 05-10-2012, 07:54 AM
2000 TL Black on Beige
Sperry's Avatar
Moog end link
Checking the bushings is an excellent point.
Old 05-15-2012, 09:16 AM
RC99TL's Avatar
Woah, stop the clock! Are those actual zirk (grease) fittings?! In the era of "lubricated for life..." I haven't seen those in years!
Old 05-15-2012, 01:14 PM
05TSXPAT's Avatar
I also have the clunking in the front end. I changed my end ling to the Moog and the problem is still there. I will look into getting the center bushing replaced.
So, after looking at this post, I decided to check the center bushing on my car and found out that the Moog was wet and grease was all over it. I clean it ant saw that the rubber cap rotated and there is no grease in there..
Is this normal? Is it defective?
Here is a pic..
Appreciate any comments..
Pat
Old 05-15-2012, 01:50 PM
Avant Garde Wheels
jjashaa's Avatar
buy grease gun
put grease in through zerk fitting
never knew the moog endlinks came with zerk fittings.. interesting.
Old 05-15-2012, 02:19 PM
It's the Halladay season!
hANDYcaptd's Avatar
Yeah, that's normal. It's suppose to be like that to allow movement.
I doubt that's causing your clunking, but I'd still do what jjashaa said. Clean and grease it.
Old 05-15-2012, 02:42 PM
Avant Garde Wheels
jjashaa's Avatar
clunking could possibly be caused by something else.
i would check other bushings and joints.
Old 05-15-2012, 02:58 PM
05TSXPAT's Avatar
Thanks for the replies..
Cleaned and re-greased.
Thanks; Now time to keep looking to the clunk.
Pat
Old 10-17-2012, 11:28 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
updates? I have some clunking too
Old 02-01-2017, 02:49 PM
Mala Lim's Avatar
I have a 99 3.2 TL. there is a clinking/rattling noise on the drivers side in front suspension. The noise occurs whenever driving at a lower speed, driving over a bump and on rough terrain. There is no noise when turning tho. The handling of the car is still good. I checked the upper and lower ball joints by shaking and prying, I checked the sway links and bushings by shaking ad feeling around and they all show no rattling/clinking. I also checked on of the lower control arm bushing using a pry bar and it seems to be ok. What could the problem be?
Thank you
Old 02-01-2017, 02:50 PM
Received 8,583 Likes on 6,630 Posts
have you checked your shocks? how many miles are on the car/ on them?
STL TL-S
09-23-2015 08:52 PM
Brandle34
09-23-2015 07:20 PM
scionxb3003
09-22-2015 05:28 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
Quick Reply: Sway Bar End Link
