Steering wheel column cover(top) removal
Old 03-26-2005, 06:23 PM
R.I.P Red-CL
brizzle's Avatar
Anybody know how to remove the top of the steering wheel column cover? I know there is 3 screws that hold the bottom but I can't move the top. Please assist.
Old 03-26-2005, 07:56 PM
R.I.P Red-CL
brizzle's Avatar
Anyone?
Old 03-27-2005, 12:11 PM
Former Sponsor
uncald4's Avatar
Once you take out the screws from the bottom..... (I thought there were 4) push the sides of the bottom half inward. This will unclip the two halves from each other. Completely remove the bottom half before you take off the top. Removing your lower dash will mike this alot easier for you. It's only a few more screws.
Good luck and have fun!!
Old 03-27-2005, 05:36 PM
R.I.P Red-CL
brizzle's Avatar
Great thanks uncald4. There are 4 more screws after the bottom half is taken off?
Old 03-28-2005, 01:32 AM
Former Sponsor
uncald4's Avatar
Sweet. I'm glad you got it off. Sorry.... It's been a while since I've taken one apart.
Old 03-28-2005, 08:12 AM
R.I.P Red-CL
brizzle's Avatar
No I haven't gotten it off yet I was just questioning you that there are a few more screws after the 4 are removed. I just haven't tried it since you told me about this.
Old 03-28-2005, 12:15 PM
BlingBling INSPIRE 32V
songoku's Avatar
There's only 4 screws on the bottom. But like uncald4 said, there are 6 retaining tabs on the sides. You have to gently push the side to seperate upper & lower columb covers. Good luck..
Old 03-28-2005, 10:50 PM
R.I.P Red-CL
brizzle's Avatar
THanks songoku, I'll give that a shot
Old 03-29-2005, 12:42 PM
riontegra's Avatar
Wink
You don't have to unscrew anything. The screws on the bottom of the steering column only hold the bottom cover on. the top part simply snaps into the bottom portion of the column trim.
To remove the top cover, all you have to do is simply pull up. Make sure you adjust the tilt all the way down so you have enough room to do so. That's it!
Old 03-29-2005, 01:16 PM
R.I.P Red-CL
brizzle's Avatar
I have to push the sides in first right? Should I use much force or be real careful?
Old 03-29-2005, 01:43 PM
Bxscig's Avatar
You dont have to be too harsh, if u get the screw driver in where the clip is and lightly push and in wedge it up you should release one of the clips and just go around. I think if you just remove one side it is good enough to help release the other side.
Old 03-29-2005, 02:55 PM
Sig Rho's Finest
NYZGREATST's Avatar
why is it that you need to remove the cover?!
Old 03-29-2005, 09:12 PM
R.I.P Red-CL
brizzle's Avatar
I knew sooner or later that question would come up. I'm doing it for a cool mod that I'll show pics of when I'm done. I already bought a replacement top cover in case I mess it up. I'll show it when I'm done.
Old 03-29-2005, 09:18 PM
mclarenf3387's Avatar
Will it be ready for this weekend? (hopefully assuming no rain)
Old 03-29-2005, 09:40 PM
R.I.P Red-CL
brizzle's Avatar
I'm going to try to but most likely not.
02-25-2020 09:57 AM
james357
02-13-2016 02:37 PM
SpraykwoN
ILX
09-11-2015 08:45 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
MyKids&Cars
09-02-2015 12:03 AM
Quick Reply: Steering wheel column cover(top) removal
