took the metal peice out of my fogs when i replaced the glass....
Old 03-26-2005, 09:55 PM
Agean Blue Bishes
demolition_x's Avatar
the part the covers the bulb. man its soo much brighter. much more light on the ground. would highly recomend.
Old 03-27-2005, 03:45 PM
TLSAnthracite's Avatar
any pics?
Old 03-27-2005, 07:02 PM
My Daily Driver
johnny--2k's Avatar
I was actually going to ask if this would be possible....how hard was it? I dont need to replace the glass, but how do the fog lights come apart?
Old 03-27-2005, 08:30 PM
Purchased: April 28, 2001
edgalang's Avatar
I did this about a year ago. I think the metal piece serves 2 purposes.
#1 to limit the light to the sides so that there's no glare.
#2 serves as a heat shield so that the refrlective part of the housing doesn't chip off.
Word of advice....if you HAD to replace the glass (since it broke) then I'd consider this mod since all you have to do is remove the phillips screw.
BUT....if your OEM glass is fine, I wouldn't even bother with it.
Old 03-27-2005, 09:39 PM
Agean Blue Bishes
i agree. ano before and after pics, but there is more light on the sides of the car such as on guardrails. also there is more light directly below the light. it is brighter. u can do it from the back with out replacing the glass but its a pain. you have to use needle nose pliars.
Old 03-27-2005, 10:07 PM
I thought that metal piece was there so you wouldn't blind on coming driver. Either way good to know.
Old 03-27-2005, 10:43 PM
Agean Blue Bishes
i don't see a difference blinding drivers from standing infront of my car with just my fogs on it doesn't bother me or any thing. also the hids do a good enough job blinding people as is.
Old 03-27-2005, 11:17 PM
Being an Acha Bacha in
Elegant TYPE S's Avatar
That is there as a heat shield. You will be melting your housing over time depending on how much you use yrou fogs. The metal lining will start to fade and chip away. Advice: put them back on.
Old 03-27-2005, 11:33 PM
Agean Blue Bishes
na since the metal thing doesnt go all the way to the base of the bulb i can't see it helping that much in heat dissapation. although it may im assured that the housing can handle it no problems.
Old 03-28-2005, 12:33 AM
If your using Halogens your asking for trouble. If its HID's u have in your fogs then you might be alright, even then iffy. Our housings are a very poor design to begin with. Even with the heat shield the silver coating chips and melts with the front of the glass too hot to touch. I'm speaking from experience, and I'm sure you'll concur with me after a few months.
Old 03-28-2005, 02:19 PM
Agean Blue Bishes
not to worry i have hids on order
Old 03-28-2005, 05:27 PM
i took mine out too when i replaced the lens with lexan
Old 03-29-2005, 12:32 PM
JGsTL-S's Avatar
and no problems with the lexan discoloring? Im interested in doin this too since Im replacing with lexan.
JG
Old 03-29-2005, 03:40 PM
Agean Blue Bishes
i drove for 5 hours after i had it done. this was at highway speeds but i had my fogs on the whole time. no discoloration. even if i pump gass and leave them on they don't get hot.
Old 03-29-2005, 05:29 PM
Bxscig's Avatar
Couldnt agree more
Old 03-29-2005, 05:36 PM
USDM UA5 A-Spec
BiggyMcWang's Avatar
Hey guys, I got a quick question, are the lenses of our fox housing sealed like the headlight housing? Reason I ask is I got HID fogs, but was worrying about a rock cracking my OEM lenses.
Old 03-29-2005, 05:56 PM
Bxscig's Avatar
Sealed like the headlight housing in what way? The clear lens attached to the rest of the housing? Then yes... it is just a metal bracket that clips on, behind that there is the glass that is silconed to the housing.
Old 03-29-2005, 06:45 PM
USDM UA5 A-Spec
Yeah.... my bad. I meant the silicone. Melting the sealant has been a problem in the past for me.
Old 03-29-2005, 08:00 PM
ChairmanMaoSaysRTFM
SatinSilverTypS's Avatar
the housing comes apart without removing the glass. i had figured it out last time i was cleaning the condensation out. it has to do with the metal knob on the back, it's actually a screw without a screw-head. i'll try to take pics this weekend and post them. but basically you have to unscrew that part and when the housing begins to loosen you can unclip the sides or something. i can't fully remember, but i'll pull em out this weekend.
SSTS
cycdaniel
12-17-2019 10:58 AM
ellisd03tls
09-08-2015 04:17 PM
HOWELLiNC
09-05-2015 03:09 AM
asahrts
09-04-2015 05:55 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: took the metal peice out of my fogs when i replaced the glass....
