reverse sensing wire - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 12-18-2011, 09:38 PM   #1
Registered Member
raydog318's Avatar
i need some help finding the reverse sensing wire for a 99 acura tl. trying to hook up a rear view camera. thanks
raydog318 is offline   Reply With Quote
Old 12-18-2011, 10:44 PM   #2
-Arsenic-
02type-s's Avatar
Get a light tester (cheap). It will take 5 mins
02type-s is offline   Reply With Quote
Old 12-18-2011, 11:42 PM   #3
Registered Member
crownovercoke's Avatar
Quote:
Your transmission range switch is on the transmission. The white wire is the reverse. It goes to a relay then to reverse lights. Not sure but I think taping anywhere between the relay and bulb should be enough to turn on camera.
crownovercoke is offline   Reply With Quote
Old 12-19-2011, 11:45 AM   #4
Registered Member
thats correct
must be AFTER the relay--thats where power actually comes out from after fuse protection
grab the white wire anywhere from there to the back up bulbs- thats an easy place to access the wires,,the bulb~
12 volt test probe or multimeter for numerous elect tests is a smart buy for every toolbox
5 bucks at parts store, harbor freight gives $4 multi meter away all the time, ck coupons
congrats on investing in safety with a camera!
01tl4tl is offline   Reply With Quote
Old 12-19-2011, 04:05 PM   #5
Registered Member
raydog318's Avatar
thanks!!!!!!!!!!!
Old 12-19-2011, 05:16 PM   #6
Registered Member
Get a meter. It's better!
Can't tell 12volts with a test light.
sammy95 is offline   Reply With Quote
Old 12-20-2011, 05:46 PM   #7
Registered Member
The wire color should be green/black. You probably have a trailer connector behind the carpet in the left rear quarter. The white wire is from fuse to switch, don't mess with it.
TLer trash is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Odd Wires near Bluetooth HFL??? HELP! SUPRMN84 3G TL Audio, Bluetooth, Electronics & Navigation 5 10-07-2015 10:46 PM
Trailer Wiring for 2012 TL 27trains 4G TL Problems & Fixes 2 09-30-2015 10:44 AM
Some details and info about KW V1 Damper kits MrHeeltoe 1G TSX Tires, Wheels, & Suspension 2 09-30-2015 03:06 AM
KW Suspension Pics and Product Feature MrHeeltoe 2G TSX Tires, Wheels & Suspension 3 09-29-2015 11:43 PM
Product Highlight: KW Variant 1 Dampers MrHeeltoe 3G TL Tires, Wheels & Suspension 0 09-28-2015 06:43 PM
Tags
2002, 2003, 92, 99acuratl, acura, locations, nsx, range, reverse, rsx, sensor, switch, tl, transmission, tsx, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
