Question About Lower Ball Joints - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 02-06-2009, 03:16 AM   #1
I Need To Organize
TACURA's Avatar
Hey guys. I bought a pair of lower ball joints from my local shop. Do lower ball joints usually come with a castle nut and cotter pin?
These have neither. Just the ball joint and grease. Does it matter?
TACURA is offline   Reply With Quote
Old 02-06-2009, 05:04 AM   #2
SodaLuvr's Avatar
I don't remember, but on another Honda that I did ball joints on, I think I reused the original nut.
I can't tell what brand ball joints those are, but I highly recommend Spicer Professional or Moog ball joints.
SodaLuvr is offline   Reply With Quote
Old 02-06-2009, 08:19 AM   #3
fsttyms1's Avatar
I see it has a lock nut. Id still rather have a cotter pin. Is there a hole in the ball joint for the pin? maybe reuse the OE nut?
fsttyms1 is offline   Reply With Quote
Old 02-06-2009, 09:08 AM   #4
I Need To Organize
TACURA's Avatar
Quote:
McQuay-Norris is the brand.
Old 02-06-2009, 09:11 AM   #5
I Need To Organize
TACURA's Avatar
Quote:
It's weird. There's not even a hole for the cotter pin. Do you think it's still ok to use without a cotter pin?
Old 02-06-2009, 10:34 AM   #6
fsttyms1's Avatar
Should be with the locking nut
Old 02-06-2009, 03:45 PM   #7
Registered Member
totaledTL's Avatar
Castle nuts used w/ cotter pins.
totaledTL is offline   Reply With Quote
Old 02-08-2009, 02:51 PM   #8
2002 Acura TL-S
just buy it from the dealer, they arent expensive at all, and the ones from the dealer comes with new cotter pins, just gotta reuse the nut, but thats no biggy, and remember there is a special tool to put the ball joint back in without ruining the boot.
Aznfury is offline   Reply With Quote
Old 02-09-2009, 06:08 AM   #9
I Need To Organize
TACURA's Avatar
Quote:
The dealerships around here won't sell the lower ball joints without the lower arm. So I just order some OEM ball joints from ebay.
Thanks for all your help guys.
Old 02-09-2009, 10:57 AM   #10
Registered Member
acutee's Avatar
Your balljoint comes with the secure nut, that is why the balljoint was not designed with a hole for the pin. You can see the white plastic in the nut.
acutee is offline   Reply With Quote
Old 02-09-2009, 04:33 PM   #11
Registered Member
thinhthan's Avatar
it should come with the nut and pin
thinhthan is offline   Reply With Quote
Old 02-09-2009, 06:02 PM   #12
Registered Member
kidduce's Avatar
I actually just did mine the other weekend and yes they came with a new castle nut and new cotter pin. I don't remember what brand they were but I got them from my local auto part store, Napa.
kidduce is offline   Reply With Quote
Old 02-09-2009, 06:11 PM   #13
I Need To Organize
TACURA's Avatar
Ok, cool. Thanks for all your responses. Much appreciated.
I just went ahead and returned these. Then I bought a pair of OEM Honda Ball joints just to safe. About the same price also.
Old 02-10-2009, 11:20 PM   #14
2002 Acura TL-S
actually the dealerships DO sell just the lower ball joints by itself, the part number is 04510-s84-000 trust me, i work at honda, it comes in a kit...
Old 02-11-2009, 02:43 AM   #15
I Need To Organize
TACURA's Avatar
Yes, you're right about them selling the ball joint by itself, but only at certain dealerships do they do that. I've called both Honda and Acura dealers around my area, none of which do.
Old 03-26-2010, 04:03 AM   #16
Registered Member
Did you guys see this thread? http://tl.acurazine.com/forums/showthread.php?t=633975
Apparently there is a tsb here: http://www.in.honda.com/Rjanisis/pubs/SB/B06-015.PDF
The tsb shows the ball joint is 06523-S84-405.
Which one is right 06523-S84-405 or 04510-s84-000 . Are they the same thing? One is Acura other is Honda P/N???
I'm pretty sure because it looked pressed in, and I don't see a B (but not sure where to look), but I might as well ask - This one is replaceable right?
TACURA, if you want, and if it's the right part, you can find them online: http://www.hondapartsnow.com/genuine...3-S84-405.html
silver2003tl is offline   Reply With Quote
Old 03-26-2010, 08:50 AM   #17
Registered Member
The shop manual doesn't seem to suggest replacing the lower ball joint, but rather the whole knuckle assembly. The ball joint certainly is replaceable after the knuckle assembly is removed from the car. The Moog ball joint has the snap ring, castle nut, and cotter pin. I would use a type with a castle nut.
swalch@stanford.edu is offline   Reply With Quote
Old 03-26-2010, 10:06 PM   #18
Registered Member
Did you read the TSB? It shows that ball joints not stamped with B can be one time replaced. The TSB also says to use P/N 06523-S84-405, but Aznfury mentioned something about P/N 04510-s84-000 so not sure which to get.
Old 04-18-2010, 02:59 AM   #19
Registered Member
Just to close the loop for someone in the future...
I went and bought P/N 06523-S84-405 from eBay and it fit great. These new ball joints do have the letter B stamped on them. The originals do not have a B so that's how they keep track.
Pressed them in/out with a rental too from Advanced Auto Parts. Autozone one only had 3 tubes that didn't work. Advanced kit was Alltrade 940579 (10 piece kit) which worked much better. Maybe not essential but take off the boot b4 pressing the old one out.
Lower ball joint separated from lower control arm via 1-1/16 tie rod separator tool. 1-1/8 one I used first kept slipping off because it was just a tad too wide.
Old 02-22-2012, 09:45 AM   #20
Registered Member
nevTL's Avatar
Just bought some Moog lower ball joints, and redoing a lot of suspension parts in a few days. Is it suggested that I replace the lower control arms while my mechanic is down there?
03 TL-S 130,000 original everything.
nevTL is offline   Reply With Quote
Old 02-22-2012, 04:47 PM   #21
Registered Member
RC99TL's Avatar
I am doing new lower ball joints and wheel bearings. I bought the knuckle joint combo.
RC99TL is offline   Reply With Quote
Old 02-23-2012, 02:27 AM   #22
Registered Member
nevTL's Avatar
Quote:
Can you link me to that?
Old 02-23-2012, 07:32 AM   #23
Skirmich's Avatar
Quote:
Originally Posted by silver2003tl View Post
That Knukle looks Dangerously Rusted, You should replace it instead of the Ball Joint.
Knukle comes with Ball Joint anyway.
Skirmich is offline   Reply With Quote
Old 02-23-2012, 12:27 PM   #24
Registered Member
nevTL's Avatar
Need to know if these look good for my 03' TL-S. Much cheaper than the OEM ones! Experts, shed some light...
http://www.ebay.com/itm/Honda-Acura-...ht_1834wt_1173
Old 02-23-2012, 03:09 PM   #25
Registered Member
I gotta disagree. Looks like cosmetic, surface rust to me. You'd have to lose a lot of material from that casting before it became unsafe.
TLer trash is offline   Reply With Quote
Old 02-23-2012, 04:45 PM   #26
Skirmich's Avatar
Look where his ball joint sits on top, It isnt even.
If I were him I would be more concern about that, than the Ball Joint Itself.
But thats Me.
Old 02-23-2012, 06:18 PM   #27
Registered Member
Yeah, I didn't really notice that. I'll have to look at another to compare.
Old 02-23-2012, 06:50 PM   #28
Registered Member
nevTL's Avatar
Can anyone help me out with this?
Thread Thread Starter Forum Replies Last Post
Broken axle or bad ball joint job? jblessing 3G TL Problems & Fixes 11 07-09-2016 11:15 AM
Motor Mounts - We need a thread. udelslayer 1G RDX Problems & Fixes 12 05-06-2016 01:27 PM
Rattle/Clunking front pass side, losing my mind, HELP! marcelft Second Generation TL (1999-2003) 25 01-11-2016 11:18 AM
Troubles of the lowly V-tecAc 2G TSX Tires, Wheels & Suspension 2 09-21-2015 10:25 AM
Best way to remove splattered axle grease? jblessing Wash & Wax 1 09-17-2015 10:28 PM
Tags
02, 2008, acura, ball, castle, ebay, joint, lower, nut, problems, rsx, size, tl, tls, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
