OBD scanning
Old 03-30-2007, 09:30 PM
Prototype's Avatar
OBD scanning
Alright guys, I've got a CEL on my sister in law's 02 TL-S
I can't find the OBD scanner plug-in for the life of me on the car. Where is it? I've looked on both the driver's side and passenager side.
thanks!
Old 03-30-2007, 09:43 PM
MikePA's Avatar
Way to go. Register and ask a question before even doing a search.
It's between the seat heater switches behind the plastic panel.
Old 03-30-2007, 09:47 PM
Prototype's Avatar
I figured it out
oh and I did a search. Thank you very much. I am a regular on CRSX so I know how it goes.
anyone know what code P1750 is?
I got two codes
P0740
P1750
Nevermind, I'll just search.
Old 03-30-2007, 09:56 PM
MikePA's Avatar
Originally Posted by Prototype
I figured it out
I got two codes
P0740
P1750
Wow, I did a search on "obd port" and found a post that mentioned exactly where it is. Go figger.
Old 03-30-2007, 10:46 PM
Prototype's Avatar
i looked for obd, obd scanning, and obd scanner and came up with now. I guess I'll have to try harder.
Thanks!
Old 03-30-2007, 10:53 PM
Bob_F's Avatar
Mike,
I know that's the ODB port location on my 1999 TL.
But isn't there a different port location on the 2002-2003 TLs? I thought I read that once in this forum.
Bob
Old 03-30-2007, 11:12 PM
Bob_F's Avatar
OK, I found mention of the other ODB port location in 2002-2003 TLs:
On the later model '02 and '03, the OBD2 connector has been relocated to underneath the steering column.
Posted by Pure Adrenaline in this thread:
https://acurazine.com/forums/car-talk-5/tl-spec-127688/
I remember being surprised by that.
Bob
Old 03-31-2007, 09:09 AM
On the way!
fla-tls's Avatar
I figured it out
I got two codes
P0740
P1750
Those are transmission codes (all P07xx and P17xx codes are). I'll try to look them up for you.
Old 03-31-2007, 09:22 AM
On the way!
fla-tls's Avatar
OK - here they are:
P0740 = Problem in lockup control system
P1750 = Mechanical problem in hydraulic control system of A/T clutch pressure control solenoid valves A & B, or problem in hydraulic control system
Are you experiencing transmission problems? Hopefully you're under warranty.
Old 03-31-2007, 10:19 AM
Prototype's Avatar
thank you for the look-up.
Well, the car's instrument panel has a flashing D5 w/the CEL and VSA lights. After reading the literature on the tranny issue, we'll be bringing in the car to acura and hopefully get the tranny serviced/replaced under warranty.
again thanks for the look-up. I'll shared my experience about this in the thread related the tranny recall
btw, the car has 78k. She picked up the car with 68k with no knowledge of its past. So we'll find out if this car has had its tranny replaced before she took ownership
Old 03-31-2007, 11:43 AM
Dragging knees in
Pure Adrenaline's Avatar
Oh, I remember when my tranny bit it. I was on the highway.
Good luck with the repairs. You said it was an '02, so it should be covered under the extended transmission warranty.
Old 06-05-2007, 08:49 AM
Doc Holliday's Avatar
Lightbulb
Clear your private messages out Mike lol you lazy
Jamus22
06-11-2023 10:08 AM
Jinkazetsukai
11-21-2015 05:28 PM
mars
09-28-2015 11:03 AM
BigJilm
09-21-2015 08:32 PM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
Quick Reply: OBD scanning
