wiring...
Old 06-04-2007, 08:47 PM
pwnage
sistom's Avatar
Question wiring...
How can I wire something so that it turns on and off with the running lights and/or head lights? Please help.... Thanks!
Old 06-04-2007, 09:46 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Use a 12Volt test light and find the wire for the hot power on those lights.
Clip a connecter to it - insert new wire and clamp shut- cover with tape.
Old 06-04-2007, 09:49 PM
pwnage
sistom's Avatar
Am I an idiot because I dont know what that means? I mean there are like 23984723984729834 wires in that section where the fuses are... Just do it by trial and error?
Old 06-04-2007, 10:23 PM
pwnage
sistom's Avatar
Or does anyone have a wiring diagram I can look at to find out where I need to go with these wires?
Old 06-04-2007, 10:41 PM
EnvyAce's Avatar
Same question I asked heres the forum with pic
https://acurazine.com/forums/showthr...ing+headlights
Old 06-04-2007, 10:44 PM
Bob_F's Avatar
Just as a general caution, be very careful when you're working on the wiring. If your're not careful you can fry some expensive electronics and you can actually disable your car.
One forum member had this happen recently while wiring up door handle LEDs.
Bob
Old 06-04-2007, 11:08 PM
3.2TL
ThreePointTwoTeeEl's Avatar
Fttsmy (something like that) has a pic of the back of the drivers side fuse panel with a red circle, the circle is what you need to connect the positive to for the lights to turn on when you flip the side marker switch. I use that for my Footwell LEDs
Old 06-05-2007, 04:34 AM
pwnage
sistom's Avatar
Well actually my car did start doing wierd things after I installed the wiring... My aftermarket alarm would lock/unlock the doors and some other small stuff but t seemed to work itself all out and now everthing is fine...
Old 06-05-2007, 08:54 AM
pwnage
sistom's Avatar
wouldn't*
atsx1313
08-07-2015 09:42 AM
grammo
05-25-2012 10:16 PM
Bham03TLs
02-09-2012 07:31 PM
riplee
04-06-2011 08:29 AM
Quick Reply: wiring...
