Check engine light and TCS light came on today! OK to drive to mechanic?
Old 06-26-2009, 10:43 PM
LABachlr's Avatar
My check engine and TCS light came on today out of the blue. I checked the oil, anti-freeze, and temp and they are all fine. I turned off the engine, waited a few minutes, and then turned it on again, and the TCS light did not come on again, but the check engine light still lit up. The only work I have had done lately is the transmission a few months ago.
Any ideas what could cause this?
I did some googling, and some people who had the same problem were able to get a code. Where do I get the error code, or does a mechanic have to get it for me?
Is it OK to drive to a mechanic or should I not drive it at all and tow it?
Thanks.
Old 06-26-2009, 11:06 PM
Bonki' Ehrite!
ANC297's Avatar
If you turn TCS off, the light will appear on the gauge panel. However when you turn the car off and back on again, TCS is automatically turned back on, therefore turning the light on the panel off.
Maybe you hit the button by accident?
Old 06-27-2009, 12:02 AM
LABachlr's Avatar
Maybe. Thanks. I'm going to get the code from the CEL from Autozone tomorrow and them post back. Hopefully it will be a simple problem. If it's the tranny, could that be why the TCS light came on as well?
Old 06-27-2009, 12:49 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
the warning lights are just that- to get your attention
could be a trans issue-- OP has a recent acura replacement trans and any mechanical thing is subject to failure- usually in the first few months of use, and while in warranty
Old 06-27-2009, 10:53 PM
LABachlr's Avatar
You called it, Tom. The tranny started acting up today. Happened in the evening, so I will bring it down early Monday morning. They were shocked that it acted up so soon, as the '08 tranny is supposed to be a solid one. Apparently not all of them.
Old 06-28-2009, 03:46 AM
01tl4tl's Avatar
the warranty replacement trans are made from used hard parts like gears and new soft parts like the clutch packs
the old replaced units go to the shop to be taken apart and reused as able in other units
Then they are hastily assembled by a low paid person ,,,hard to imagine any potential for failure there~
The replacements made since sometime in 05 come with a new designed outer case with better oil flow,, but not fixing the prob completely
Enjoy that loaner car~
Old 06-28-2009, 03:47 AM
01tl4tl's Avatar
of course they were shocked!
would you rather hear: oh yeah about 1 in 10 takes a crap in a month- sorry dude
Old 06-28-2009, 02:36 PM
LABachlr's Avatar
LOL. Tom, you're funny.
Well, guess what. I had a blonde moment (I'm not blonde, but I had a moment). Normally I would have you guess what happened, but even though I fixed the situation, the problem still exists.
The last time I got gas, I forgot to put the gas cap back on. I left it in holder in the little door and closed it. I read that a loose gas cap could cause the engine light to go on. So, I put the cap back on and made sure it was fully on.
I then took the car out for a drive to test it. The lights usually come on when I accelerate. So that's what I did. I accelerated...and they came on again. Does it take a little while for things to get back to normal after having the gas cap off for a day or two, or should it go back to normal right when you put the cap back on?
Old 06-28-2009, 07:34 PM
LABachlr's Avatar
Well, I think it's correcting itself. I was driving today and when I first turned on the car, the TCS light was no longer on, but the engine light was. Then, as I was driving, the engine light went off. I was very happy about that. I decided to see if she was bluffing, so I called her bluff and accelerated pretty rapidly. The engine light stayed off. Very cool.
Has anyone experienced this before? Am I right in my assumption? Tom, have you?
Old 06-29-2009, 06:36 AM
totaledTL's Avatar
I have heard that a loose cap could cause a CEL but haven't experienced it first hand. What about the transm.- you said it acted up- ?
Old 06-29-2009, 06:47 AM
01tl4tl's Avatar
oh yeah the loose gas cap trick-mechanics love this one~
it fools the computer big time into thinking the sealed system isnt holding pressure
thats why it says 3 clicks of the cap too- its spring loaded and clicks like it torque wrench when its tight enough
For this one, go ahead and reset the ECU by pulling CLOCK fuse, #13 or 12 iirc on passenger side foot area or edge of dash (when door open)
pull it for a minute then replace- that forced a master reset and relearn-
if if was just that gas cap it will clear it-
may take a few days as you drive it off ---and it learns there is no fuel pressure leak
Old 06-29-2009, 06:49 AM
01tl4tl's Avatar
you dont have to do the master reset- you can just drive it normal a few days and if that was the prob it will self clear
Old 06-29-2009, 08:33 AM
LABachlr's Avatar
Perfect. Thanks, Tom. The light came on again when I accelerated last night, but did not when I accelerated this morning. As you said, it will probably take a few days to self-correct itself. That's the last time I leave the gas cap off. And the crazy thing is, I never do that. I don't remember any other time when I did that. I must have been really tired or preoccupied.
TotaledTL, the tranny is no longer acting up. Just the lights are a bit sporadic.
Old 06-29-2009, 09:55 AM
01tl4tl's Avatar
Everyone-
with scorching temps in many parts of the country
Make sure to fill the gas tank ONLY to the 1st shutoff of the pump
That allows room in the tank for expansion and vapor action under heat
The road sends heat up to the tank as well as the car metal is all hot, and the exhaust system contribution..
If you `top off` by overriding the shutoff- its very possible for raw liquid fuel to go thru the overflow vent tube and into the charcoal cannister-
thats supposed to trap expanding fuel vapors and at engine start it will pull the vapors into the system to be burned in the cylinders
If the cannister is soaked with fuel- it absorbs it- its charcoal (not bbq charcoal)
and then its ruined
Point of the story is the car will run funny, so especially with the heat of summer dont top off the tank
but DO put the cap back on and turn till it makes 3 clicks
anything more isnt actually turning it tighter- its a spring loaded torque limiter
Old 01-05-2010, 12:49 AM
LABachlr's Avatar
Wanted to let everyone know that it eventually corrected itself. One thing that was surprising was that the dealer told me that the throttle assembly needed replacing, a $600 job. That's why the lights were coming on, according to them. Not the case. It took a while, but within a few weeks, the lights stopped coming on.
Thanks again, Tom. You saved me an unnecessary $600 expense. You rock.
Old 01-05-2010, 03:30 AM
01tl4tl's Avatar
the dealer and especially the service Writer ~who lives by selling~~
would read the codes and see them as diagnosis- not clues as we all know they are!!
I wonder what they would have said when that didnt fix it, or if they suspected gas cap and would install a TB and drive the car overnight to reset the ecu for you.
all that for only 600 wow~ a deal~
I accept paypal donations for advice on love, spiritual needs and automotive probs lol
Old 01-05-2010, 03:32 AM
01tl4tl's Avatar
I would go speak in person with the service MANAGER and tell them whats occured
If tech or writers are pulling bs, the manager needs to hear about it from you
Its called fraud when they do unnecessary repairs
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
SpraykwoN
ILX
09-23-2015 11:44 AM
Bahamanurse1
09-10-2015 10:05 PM
Desert Ridge
09-05-2015 09:47 AM
Quick Reply: Check engine light and TCS light came on today! OK to drive to mechanic?
