Help with HID fog conversion
Old 02-16-2010, 01:20 AM
kingsht205typeS03's Avatar
Hey guys...I know you have probably had this question asked a million times, but here it goes again.....I have searched the threads and cant seem to find a D.I.Y. post step by step for the installation of HID fogs. If anyone could help me out it would be great.....Thanks a lot
Old 02-16-2010, 01:39 AM
dsickles's Avatar
uhh, well if you have plug and play HID kit it should just be as simple as installing the bulbs, mounting the ballasts, and hooking up the power to the foglight connector. youll probably want to remove the front bumper for this.
Old 02-16-2010, 01:48 AM
its 100% plug and play supposedly but im not too sure about taking off the bumper and do i run the ballasts to the battery under the hood for the power?
Old 02-16-2010, 02:14 AM
dsickles's Avatar
nope, if its plug and play you plug the ballasts into the factory foglight harness.
Old 02-16-2010, 06:01 AM
7th Gear
CRiXy's Avatar
i think u can get hid fogs these days for under $200 INstalled
Old 02-17-2010, 10:51 PM
Traded in my
'02_TL-S's Avatar
Shit..where are you going for HID kits and installation. I paid ~$80 for DDM slim ballast kit shipped and installed it myself.
OP - If it's plug and play, you really do just plug it in and you're done. The only tricky part is where to mount the ballast.
Old 02-17-2010, 10:54 PM
2000 acura tl FPR
assclown's Avatar
if you can, try to find a kit that has mounting holes on the ballasts, they provide doubleback tape, but i've had ballasts fall off (even when i cleaned the areas with alcohol), i mounted my ballasts in holes that were already there on the frame (i have a 2000 though)
Old 02-17-2010, 10:58 PM
Traded in my
'02_TL-S's Avatar
^ Exactly what I did.
They'll fall off unless you use 3M tape and not what they give you. With 3M and good cleaning where you mount them, they should go nowhere..shit is STICKY!! LOL
Old 02-18-2010, 02:43 PM
thanks for all the suggestions guys...i will be trying the install today...wish me luck
Old 02-18-2010, 03:39 PM
'13 Hyundai Sonata
TLin401's Avatar
VERY easy install.
If the HIDs do not turn on the first time, then the +/- ma be on the wrong side. Just flip the connection around and it will work. Then just use a couple zip ties to hold the connection in place.
Avenger411
10-11-2015 03:53 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
rhdune16
09-28-2015 11:31 AM
h22lude
09-27-2015 06:22 PM
Quick Reply: Help with HID fog conversion
