How do I replace the drivers side headlight?
Old 01-24-2009, 07:48 PM
yatahaze's Avatar
I can't really figure out how to replace the drivers side headlight. It's being blocked by some sort of plastic vent that doesn't look removable.
Do I have to remove the whole headlight assembly or is there an easier way?
Does anyone have any tips for doing this? Thanks.
Old 01-24-2009, 08:07 PM
Meridian
VoLLy's Avatar
You will HAVE to take out the reservoir overfill bottle in order to get to the headlight.
Old 01-24-2009, 08:09 PM
yatahaze's Avatar
But there's this big black tube thingy blocking the entire face of the headlight cover. That seems to be in the way more than the bottle... unless they are related.
Old 01-24-2009, 08:16 PM
Ya....It's an Acura
ftLauTL's Avatar
what year is yours?
Old 01-24-2009, 08:20 PM
yatahaze's Avatar
2003
Old 01-24-2009, 08:52 PM
Mista Juice's Avatar
for the drivers side?
check the DIYs.. there are a couple threads i believe.. im not sure exactly which pieces you are talking about that are in the way though.. mine was totally clear when i did mine a couple weeks ago.. then again, i have a CAI, so everything has been taken out..
Old 01-24-2009, 09:11 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
You shouldnt have to remove the intake piping but to make it easier you can. Other than that there isnt any thing that needs to be removed.
Old 01-24-2009, 09:39 PM
yatahaze's Avatar
It's the drivers side, we've already done the passinger side. It looks like intake piping but we have no idea how to remove it, can't see any method of removing it. That's why we're asking if we need to remove the whole headlight assembly.
Old 01-24-2009, 10:41 PM
Meridian
VoLLy's Avatar
shoot, nvm, i was referring to the driver side high beam.
Old 01-24-2009, 11:00 PM
yatahaze's Avatar
To clarify, it's the drivers side xenon hid bulb I'm trying to replace... not the whole assembly either, but I was wondering if I needed to take the whole assembly out just to change the bulb.
I checked around and couldn't find much info on replacing the drivers side. Found info for passengers side and got that done.
Old 01-24-2009, 11:28 PM
yatahaze's Avatar
I already put the long plastic cover back together so I can't take a picture of the actual piece I'm talking about... but here's a pic anyways.
Old 01-25-2009, 01:33 PM
yatahaze's Avatar
So does anyone know what I'm talking about? I'm gonna open it up and work on it again today... I'll be able to get a picture of whats actually blocking it.
Old 01-25-2009, 03:22 PM
yatahaze's Avatar
Stumbled upon http://www.acura-cl.com/forums/showthread.php?t=689886
Old 01-25-2009, 04:43 PM
yatahaze's Avatar
For Non-Type-S owners, there is an annoying plastic piece blocking the headlight that just requires brute force to remove.
Old 01-25-2009, 04:49 PM
fsttyms1's Avatar
Forgot about the horn. Yes just yank up on that. Many of us dont have that as we have removed our resonators (that part and the box below it)
Old 01-26-2009, 03:17 AM
spoka's Avatar
That's the snorkel on the resonator, I've always found it easier to replace bulbs and ballast with the headlight off, which requires the removal of the bumper.
It may seem hard but its actually only a couple of clips and 2 screws in each wheel well, only takes me a couple minutes to remove mine.
Old 01-26-2009, 04:59 AM
wham bam thank you ma'am
Rajca's Avatar
x2
Old 01-26-2009, 07:36 AM
fsttyms1's Avatar
The 3-5 min it takes to take just the bumper off you could have replaced both bulbs
Old 01-26-2009, 01:13 PM
yatahaze's Avatar
Already done the hard way :P
Old 01-26-2009, 01:38 PM
Low & Slow w/Dubz On My
ZEUS'O3TL's Avatar
did u remove the intake resonator?...datz a free mod right there and ur saving urself like 50 pounds...lol...j/k...but it sounds nicer when u rev it a lil...
02-25-2020 09:57 AM
csmeance
09-10-2018 09:15 AM
nanos
11-12-2015 08:41 PM
Ny1718
09-11-2015 09:21 AM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: How do I replace the drivers side headlight?
