How to check fuel pressure?? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 08-31-2006, 09:26 PM   #1
Registered Member
Jorge68's Avatar
Can someone help me and tell me how you go about checking the fuel pressure? I really need to check this to fix my car!! Let me know!
Jorge68 is offline   Reply With Quote
Old 08-31-2006, 10:46 PM   #2
fsttyms1's Avatar
why do you think you need to test this to fix your car?
fsttyms1 is offline   Reply With Quote
Old 09-01-2006, 07:18 AM   #3
Registered Member
Jorge68's Avatar
Because I need to figure out if it's my fuel pump/fuel lines, or my injectors.
Old 09-01-2006, 09:34 AM   #4
fsttyms1's Avatar
fuel pressure gauge. I thought you already knew the fuel pressure?
Quote:
Originally Posted by Jorge68
When they checked the fuel pressure..it was about 10psi. I checked the lines and the gas is coming out fine. I'm guessing it's the injector. Does anyboy know how to clean them?
If you test it again and its still low it wont be the injectors. They are the last spot the fuel goes thru.
Get a fuel pressure gauge and put it on the fuel rail
Old 09-01-2006, 09:55 AM   #5
Registered Member
Jorge68's Avatar
Exactly..I need to retest it since I changed out the fuel pump and it didn't help any.
Old 09-01-2006, 10:02 AM   #6
I=X - optomos
optomos's Avatar
Did you find out what the PSI is suppose to be?
optomos is offline   Reply With Quote
Old 09-01-2006, 10:46 AM   #7
On the way!
fla-tls's Avatar
Quote:
I don't have a manual - but my best guess would be 30-50 psi (leaning towards 40-50psi). I know it can vary based on intake vacuum and rpm.
fla-tls is offline   Reply With Quote
Old 09-01-2006, 11:05 AM   #8
Registered Member
TNelson's Avatar
Quote:
This is acurate. Usually fuel pressure is anywhere from 35 to 55 on most cars. If he is only getting 10 psi, there is an issue somewhere in the fuel system, and is not an injector problem.
TNelson is offline   Reply With Quote
Old 09-01-2006, 12:38 PM   #9
Registered Member
Jorge68's Avatar
Quote:
That's what i'm trying to figure out. It could be clogged lines because of the stuff in my gas tank.
Old 09-01-2006, 03:56 PM   #10
Registered Member
SoCalwarrior's Avatar
After you find out what the PSI is. You also have to do a voume test assuming the PSI is correct. you'll have to get a manual for the specs. You should call your central library ask if they have automotive manuals. Mitchell Manuals are real good on info. Good Luck!!
SoCalwarrior is offline   Reply With Quote
Old 09-01-2006, 04:03 PM   #11
fsttyms1's Avatar
You can get a fuel presure gauge at most auto parts stores.
Old 09-01-2006, 05:52 PM   #12
fsttyms1's Avatar
sorry for the large size but this may help
Old 09-01-2006, 11:09 PM   #13
Registered Member
Jorge,
Did you only change the fuel pump? Did you backflush the main pressure line?
If your pressure is low, I would suspect you can pinch the return line to check the pressure regulator. Also, when you pull the vacuum line from the regulator, if you find any fuel on that side of regulator, you are suffering from a torn diaphram.
If your pressure is still low after changing the pump and blocking the regulator return, I would suspect clogged fuel line. I could suggest a couple of ways to clean out the sediment, but they all involve flushing the line with flammable liquids;-). Or a really long pipe cleaner.
TX-Miner is offline   Reply With Quote
Old 09-07-2006, 06:00 PM   #14
Registered Member
Jorge68's Avatar
it says I need a special part (adapter) to check the pressure. Where can I get that??
Old 09-10-2006, 08:40 PM   #15
Registered Member
Jorge68's Avatar
anybody??
Old 09-10-2006, 10:31 PM   #16
fsttyms1's Avatar
I have no idea? Search google maybe? it has to be out there.
Thread Thread Starter Forum Replies Last Post
CLOSED: Bagged 2008 Acura TL Type-S 5AT Rebuilt (Tamarac, Florida) **REBUILT TITLE** mrkingstonvi Member Cars for Sale 2 02-22-2016 02:53 PM
Need a ramp up fuel pressure regulator NBP_BALLER 2G TL Performance Parts & Modifications 5 09-23-2015 09:18 PM
Check Gas Cap Light? SpraykwoN Acura ILX Discussion 4 09-23-2015 12:44 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown 3G TL Problems & Fixes 4 09-08-2015 07:51 PM
P0300 Random Misfires NSolace 2G TL Problems & Fixes 1 09-03-2015 09:14 PM
Tags
10psi, 1999, 2000, 2002, 96, acura, bonniville, check, fuel, mdx, pressure, pump, rsx, test, tester, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
