How change antifreeze
8th Gear
I was shocked at how much the dealer wanted just to change antifreeze. Could someone explain how to do it or point me to a good source. Thanks
(Sometimes I really miss the '67 Dart that I sold 5 years ago. Change the antifreeze? Just turn the butterfly nut at the bottom of the rad.)
The TL anti freeze is easy to change also. My father helped me with mine two weeks ago. He is good at that stuff. I watched and learned. Took us about 45 min max. Get under car. Look for the drain plug, its right behind the bumper at the bottom on the left side if your are facing the car, right side when you are under the car right under neat the radiator. It should twist open by hand, mine did. Dain and flush. You are set. PM me if you want more detail.
mada51589
05-03-2022 08:54 PM
