Braking problem
Old 08-19-2011, 05:42 AM
BN3DC2's Avatar
Smile Braking problem
my 03 TL just wont stop in the right time when i stepped on the brake pedal...it seems that my break pads can't hold the disc brake in fully stop. i tried driving my car in 40-60 mph and stepped on the brake so hard but the car just wont stop right away..the brake pads are new and it has enough brake fluids..is it normal or there's something wrong with it? please help.
Old 08-19-2011, 07:49 AM
She thinks my TL's sexy.
farmdevil's Avatar
I'm not certain I follow. So are you saying that once the car is stopped, the brakes won't hold it? That would be a bit weird. If I'm misunderstanding and it's just not stopping very well, perhaps you need to flush the fluid or perhaps just bleed it. If you have really old fluid or if air and moisture has gotten into it, stopping will feel really bad. I suppose another possibility would be incorrect pads.
BN3DC2 (08-19-2011)
Old 08-19-2011, 09:13 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
if those are brand new pads they need useage to `bed in` fully to the rotor
so the micro hills and valleys of both parts wear into each other
then you get solid braking
also change/flush the brake fluid if not done in the last 2 years
old fluid gives weak pedal
For now- ck the install and get some use on the brakes
It may take 500 miles of normal driving to get them working right
DO NOT do any full effort braking- thats hard on new pads
BN3DC2 (08-19-2011)
Old 08-19-2011, 10:07 AM
totaledTL's Avatar
Any foreign matter on rotors, i. e. grease, oil, brake fluid, etc.??
Old 08-19-2011, 10:43 AM
01tl4tl's Avatar
OP didnt mention new rotors... but contamination during brake job is always a possible
I am wondering how thick the rotors are? wear over 7-8 years can take it to minimum...
if OE rotors they are junk by now
and old `hygroscoped` fluid, with new pads, and didnt sand clean the rotors before install...
that would add up to not much brakes at first
Im still going with needs bedding,,maybe rotors and fluid
Why not do a brake job right!
like clean and lube the slider plates,,lube caliper pins, lube pad backs,,replace fluid
Old 08-19-2011, 12:32 PM
BN3DC2's Avatar
where do i flush or bleed the fluid to change a new one? thanks for the help fellas...i really appreciate it..
Old 08-19-2011, 04:54 PM
01tl4tl's Avatar
use the search for brake flush or brake bleed
Do you have a buddy that knows a little about cars, has basic tools?
jackstands?
BN3DC2 (08-20-2011)
Old 08-20-2011, 04:35 AM
BN3DC2's Avatar
i have the basic tools...now i know what to do after researching..
jackstands?
Old 08-20-2011, 06:41 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Is your pedal spongy at all?
Old 08-20-2011, 11:54 AM
01tl4tl's Avatar
spongy = meaning when stopped- in park- try a quick double pump on the brake pedal
does it feel firmer- stops higher up, on the 2nd pump?
Does it feel mushy during braking?
the TL has a special bleed order: LF driver front then clockwise around the car
LF RF RR LR,,thats different than most cars
The 2 man method works well for noobs, DO place a 2x4 wood block under brake pedal arm to prevent pedal from going more than 3/4 way to the floor- its normal operating range - or risk damage to the master cylinder,,another 100 bucks you didnt need to spend
BN3DC2 (08-20-2011)
Old 08-20-2011, 01:23 PM
BN3DC2's Avatar
is not spongy at all..the only thing that i've noticed, is when i step on the brake while on park and the engine was running...everytime i step on the brake, there is something clicking right under the shift knob..any idea?
Old 08-20-2011, 02:17 PM
farmdevil's Avatar
That clicking is not a problem. It is just the brake pedal telling the gear shift that it's safe to go from park to drive. On some cars it gets a bit louder, but all automatics have such a contraption.
BN3DC2 (08-20-2011)
mada51589
05-03-2022 08:54 PM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
rklatzkin
09-23-2015 04:08 PM
HOWELLiNC
09-10-2015 01:39 PM
Quick Reply: Braking problem
