Hardwire Radar Detector - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 11-23-2003, 09:31 PM   #1
Registered Member
Southern's Avatar
I have installed my radar detector above the rear view mirror and wanted an easy way to hardwire it without having to run a wire down the column and have the radar detector automatically turn on and off with the ignition. I have outlined the procedure below:
The below procedure is for 1999-2003 TL without the OnStar System.
1. Remove the front ceiling light.
2. Route the power for radar detector wire along side the wire for the automatic dimming mirror.
3. Locate the 3 prong connector for the automatic dimming mirror.
4. Strip 1/2" insulation from the radar detector power cord.
5. Locate the negative wire for the radar detector power cord. Twist the end of the wire to avoid fraying and insert it along side the wire going into terminal 3 of the 3 prong connector for the automatic dimming mirror.
6. Locate the positive wire for the radar detector power cord. Twist the end of the wire to avoid fraying and insert it along side the wire going into terminal 1 of the 3 prong connector for the automatic dimming mirror.
7. Place a narrow strip of duct tape to secure the radar detector power wire to the ceiling of the car. This helps prevent the wires from coming loose from the 3 prong connector.
If you are uncertain which terminal is 1 and which terminal is 3 use a volt meter or continuity checker - terminal 3 is ground and terminal 1 should read 12V with the ignition switch ON (II).
The above wiring procedure will allow the radar detector to power up when the car is running and will turn off when the car is off. One note of caution - the only protective fuse in the circuit is fuse #9 (7.5A).
If you have an expensive radar detector I would wire an inline fuse for the positive wire between the 3 prong connector and the radar detector.
Southern is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Radar detector hardwire install (pics) ITSJESTER 4G TL Audio, Bluetooth, Electronics & Navigation 15 02-03-2016 02:52 PM
Blendmount Alternatives chrisrayala 5G TLX Audio, Bluetooth, Electronics & Navigation 4 12-04-2015 03:17 AM
My new 2012 Acura TL SH-AWD w TECH ITSJESTER 4G TL Photograph Gallery 7 10-13-2015 01:53 PM
SOLD: side engine mount, radar detector, mirror, oem parts sockr1 Car Parts for Sale 22 10-01-2015 02:31 AM
03 TL Hardwire Radar Detector - need live wire deyainrdy4ds Second Generation TL (1999-2003) 5 09-22-2015 11:15 AM
Tags
2003, 2nd, 32, acura, cable, cl, detector, gen, hardwire, hardwired, phone, radar, rsx, tl, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
