FAQ: 06-07 AV6 Transmission 'Swap'
Old 10-11-2016, 11:42 PM
  #521
SuperGreg's Avatar
Originally Posted by Skirmich
Damn you were lucky to get it with such few miles!! Got mine with 80K and I thought I was special
You must only use the ACCORD TC with the AV6! Using the TL Torque Converter with the AV6 will cause Catastrophic damage to the Transmission Bell.
Yup, I think something like 48K. Thanks for the info about only using an AV6 TC, was wondering about that.
Old 10-13-2016, 12:31 PM
  #522
3rd Gear
TrannyBrokeAmScrewed's Avatar
Hi guys,
Thanks for the feedback.
I've found a mechanic who may be willing to do this swap. He has told me that if I encounter some particular error code, he won't be able to do the swap. Apparently said error code will mean a certain part is broken, which will render the job impossible. Is anyone familiar with this? If so, which code is the bad one, and to which part does the code correspond?
Old 10-14-2016, 04:23 PM
  #523
SuperGreg's Avatar
Originally Posted by TrannyBrokeAmScrewed
Hi guys,
That doesn't really make much sense, I dunno.
Old 10-14-2016, 07:27 PM
  #524
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Look for another mechanic... That guy is smocking something, There are no codes for physical damage to the transmission.
Old 10-14-2016, 07:44 PM
  #525
3rd Gear
The guy isn't answering my calls, so I've been looking around.
Does anyone have experience with buying a *new* aftermarket transmission (Jasper, HH) and having it installed? I may be able to get my hands on one, and have a shop remove and replace. Does anybody know how much that might cost, or specifically the labor time of removing and replacing a transmission?
Apologies-- this is not something that pertains directly to this thread, but I want to know either way, so I can weigh my options.
Old 10-14-2016, 10:45 PM
  #526
Skirmich's Avatar
DO NOT GET ANOTHER STOCK TRANS.. It is a waste of money and time.... Get the AV6.
Old 10-15-2016, 06:20 PM
  #527
SuperGreg's Avatar
What about a rebuilt AV6 though? I agree don't bother with a rebuilt B7WA.
Old 10-16-2016, 12:55 AM
  #528
Skirmich's Avatar
A rebuilt AV6 will be far more expensive... I mean by all means it will be the BEST Choice but if money is concern? better get the used AV6.
Old 10-26-2016, 01:40 PM
  #529
acrdr's Avatar
Hi. I have done this swap multiple times .
My question is . Can I use 03-05 Accord trans to do this swap?
Old 10-26-2016, 09:54 PM
  #530
Skirmich's Avatar
You should use the 06 and 07 since those are the newer design..
Older trans are still using the same layout as the B7WA but with the Band Aids and "Fixes" Acura did so you run the risk of getting another lemon trans but from the Accord Arena.
Old 10-26-2016, 09:58 PM
  #531
acrdr's Avatar
Ok. I might be able to get my hands on a rebuilt 04 v6 Accord trans .
As long as it fits .
Old 10-27-2016, 09:09 AM
  #532
bbsitum's Avatar
Guy above just say to you to NOT do it. However whatsoever you want.
Old 10-27-2016, 01:48 PM
  #533
Skirmich's Avatar
Its okay, live and learn I guess.. Perhaps he got a sweet deal on a rebuilt older AV6?
Old 10-27-2016, 02:53 PM
  #534
acrdr's Avatar
My friend has a 04 Accord v6 that he had the trans rebuilt about a year ago .
And his engine retired after 230k miles .
00-03 tl is avaliable for about $700-1k in good condition with a bad trans .
I have done few av6 swaps from 06-07 Accord trans into tl .
I wasn't sure if the 03-05 Accord trans is different on the outside from the 06-07 one .
I was going to suggest to him to get a used tl with a bad trans and use his trans.
Old 11-11-2016, 10:41 AM
  #535
MassiveTL's Avatar
Is there anybody in the NYC area that performs the AV6 swap? I have a 2003 TL with 113K. I bought the car brand new back in 2002. I had the transmission replaced under Factory warranty back in 2005 when the car had 31K. I am looking to do the AV6 swap
Old 11-11-2016, 10:49 AM
  #536
acrdr's Avatar
I can do it for you . I'm in North NJ
Old 11-14-2016, 10:45 AM
  #537
captainlight's Avatar
Hi, 03 TL-P owner here. I did the AV6 swap with an '07 Honda trans about 2 years ago. Original trans went at 140k, now at 175k with one problem - I get the dreaded P0740- TCC Circuit Malfunction code now. I can clear it, but it comes back after a while. Cleaned the solenoid screens (weren't very dirty) but haven't changed the fluid. Would a fluid change help, as the State I live in won't pass a car through yearly inspection if the check engine light is on. I will try to reset the CEL and drive for 50 miles and take it right into a garage for the inspection, but I would rather fix the issue. Fluid looks normal.
Old 11-14-2016, 03:18 PM
  #538
Received 8,575 Likes on 6,626 Posts
25k, you're due for a fluid change, change it and try it. regardless it's ready for some fresh fluid.
Old 11-17-2016, 04:14 PM
  #539
Kris9884's Avatar
Any luck getting the pictures updated in the OP? I bought a 2000 TL with 240k for $600 and the trans is original so I can only assume its on its way out. I'll start a build thread or actually, just a "back to commuter" thread if anyone wants to check it out.
Old 11-17-2016, 04:54 PM
  #540
Skirmich's Avatar
^ I Uploaded the OPs Manual, The pictures are all here: https://es.scribd.com/doc/300711570/...nsmission-Swap
The following 2 users liked this post by Skirmich:
Chojun (12-08-2016), Kris9884 (11-17-2016)
Old 12-06-2016, 11:08 AM
  #541
mike_engr's Avatar
AV6 swap guys or shop in Raleigh Area?? pro or semi-pro ?
Is there anybody in the RALEIGH NC area that performs the AV6 swap? I have a 2003 TL with 120K that's been in the family the whole time. Not a beater! Tranny had the oil jet recall done back in the day.
Weeks ago it started slipping/reving during forward cruising. Got 0740 code.
Cleaned 4 or 5 linear solenoid screens, did drain/fill 2X. Ran great for two weeks!
Now during forward cruising it is doing something different! In forward cruising its like it SUDDENLY hits the brakes! I think the Tranny is either spontaneously downshifting or Locking the Torque Converter! But it feels like a sudden applicaiton of brakes, and then the "brakes" release, but its not the brakes, its the tranny (95% sure).
Anyone know which solenoids could be causing this? What to check?
Anyone know someone (pro or semi-pro) in RTP who can do the AV6 tranny swap ????
Thanks! I'd like to keep this non-beater family TL on the road for my daughter!
Old 12-16-2016, 09:08 AM
  #542
its actually tan
MidoriTL's Avatar
subscribed for later use thx for the info guys
Old 12-23-2016, 09:17 AM
  #543
Michael Hinchey's Avatar
Can anyone tell me if this will work with the type s? Specifically the 2002 Acura TLS 3.2l? Thx
Old 12-23-2016, 09:24 AM
  #544
Also anyone know of a mechanic that does the av6 swap in Pennsylvania near Philly?
Old 12-23-2016, 09:33 AM
  #545
acrdr's Avatar
I can do it for you . But I'm in North NJ.
Yes it works on both type-s and base tl .
On the type-s it's a bit easier. Because power steering lines don't run through the speed sensor .
Old 12-23-2016, 10:42 AM
  #546
mike_engr's Avatar
Originally Posted by mike_engr
Is there anybody in the RALEIGH NC area that performs the AV6 swap? I have a 2003 TL with 120K ......!
UPDATE: I'm having an Ody swap done now by a local mechanic/small shop using the PDF! He didn't see any need to drill/tap the Ody tranny yet.... Anyone have pics or diagram of drilling?
I hope this turns out well. Might get it back today. I'll share Raleigh area AV6/Ody swap mechanic contact info if it turns out well and if he wants to do more! Stay tuned....
Old 12-23-2016, 11:26 AM
  #547
What part of North Jersey? What is the cost? How long will I be without? Thx for your reply.
Old 12-23-2016, 12:31 PM
  #548
Originally Posted by 03blackbeast
Hey just wanted to give a testimonial for this FAQ sheet. I took my TL in with the AV6, 10 quarts of DW-1, rear main seal, cooler filter, and internal filter and got it back this past Thursday. I printed off the FAQ sheet and my mechanic followed it exactly. There's been no problems so far and my TL has never shifted smoother. This really works.
How were you able to print out everything? I am having issues with printing HOW IS YOUR CAR RUNNING?
Old 12-23-2016, 12:41 PM
  #549
Originally Posted by IndianaTLowner
Well I'm going to buy a 07 accord 3.0 v6 automatic transmission today after work to put in my 04 3.2 automatic acura tl. I hope I've got all the I do right since the transmission shop is dragging their feet and haven't took mine out yet. The guy at the shop said the only way it would work is if the numbers on the trannies match, but idk what the hell he's talking about. I know my trans is a BDGA BETA and the accord is a BAYA, but it's the same thing basically. I've posted a couple times about this and tried to get confirmation that I'm buying the correct part, but haven't gotten a reply so hopefully this works because I can't afford to buy two. I've done the research and I'm about 85 percent that I'm doing the right thing. If anyone who knows about this can chime in and confirm what I'm doing is right I would really appreciate it.
Why did you decide to do a swap instead of getting a remanufactured one? Just curious is all? How is it holding up?
Old 12-23-2016, 06:55 PM
  #550
mike_engr's Avatar
Why "Swap" instead of Reman?? answer: Everything I read says you are better off with a good used newer-gen tranny (06/07 Accord or 05/06 Ody) compared to fixing / rebuilding/ reman an older TL Tranny!
I think they are right! It took me a couple weeks to digest the PDF and find a local mechanic to ramp up.....
Our TL became "undriveable" last month even after I cleaned linear solenoid screens twice and did drain & fill a couple times!
Glad to say I found a Raleigh / Cary / Apex / RTP / NCSU area local mechanic to do the TL AV6 / Odyssey transmission swap!
Just went with a Ody Transmission with 91k miles. (2003 TL with 120k miles - - grandpa's hand-me down).....
Just got it back on the road and it shifts better than ever! There's "peace of mind" knowing that I now have a next-generation auto 5 spd transmission instead of a band-aid solution!
Contact me if you need a Tranny hook-up near Raleigh! Hope to see ya on the beltway!
Old 12-24-2016, 08:37 AM
  #551
acrdr's Avatar
PM sent
Old 12-29-2016, 10:02 PM
  #552
Originally Posted by Stephen00TL
Nice job I would also recommend replacing the rear main seal while you are doing the swap
would that seal be for the Acura part or Honda part? Seems they have the same part number but one cost more than the other. ?
Old 12-29-2016, 10:05 PM
  #553
I'll second what Memphlow said. My mechanic called part way through the swap to tell me I'd lose power steering so I walked him through finding the actual pump on the motor and explaining the secondary pump on the tranny and he realized he was wrong. Don't be surprised if you get the same call haha. Everything is bolt on parts.
could you explain what you mean by this?
Old 12-29-2016, 10:20 PM
  #554
Originally Posted by yody
No damage to tranny, I used the matching converter to the new transmission, and yes I filled the torque converter.....
I do have an update
Drove the car some more today. The noise miraculously went away. I have a feeling one of the shaft bearings was dry. It took 6 quarts of fluid to fill this one, so it must of been bone dry, plus it had likely been sitting for 4 years.... I'm gonna do a 3 quart flush soon, I used new oil sensors, filter, and Redline D4, but the fluid that was in there was kinda gross, prob water contaminated. I also re-used the newer filter system, pretty much same thing but I like the cheaper more easier to inspect, dropin filter
This thing is beautiful, shifts so smooth, no more clunking or whining like my old trans. I also did the rear main seal and put some redline 10/30 in the engine. Having a ultra smooth transmission and no more nasty oil leak under the car is a big improvement.
crazy how the noise just came and went, it sounded pretty bad.
What exactly did you change out? And what if any modifications did u have to make for the new filter to fit? And what is the part number to the filter?Thx
Old 12-29-2016, 10:29 PM
  #555
Originally Posted by MBP 03
It's not required, but with the relatively low cost of new 3rd and 4th gear pressure switches, it might be a good idea to replace them for peace of mind if the AV6 transmission has higher miles on it and you have a few extra bucks in your swap budget.
would you happen to have part numbers?
Old 12-29-2016, 10:38 PM
  #556
Originally Posted by Sapiophile75
Great info. Just dropped a '06 AV6 Accord tranny in a '02 TL base and it went well. Shifts better, doesn't hard down/up shift on 2-3 gears. Only one thing, the power steering is way to stiff. I'm throwing it up on a rack to see if the mechanic did the PW modification correctly. Other than that, what a great work around for these transmission nightmares. Thanks to everyone who shared all this valuable information.
what was the outcome? And what do u mean aid he did the pw modification correctly?
Old 12-29-2016, 10:47 PM
  #557
Originally Posted by Memphlow
The filter he is referring to is serviceable on the AV6 transmission. It replaces the spin off filter on the TL Transmission if he elect to keep that setup. I am using the same setup because it is more cost effective ($6) than the spin off and easier to inspect.
Is the spin off filter better than the one on the av6? Or the same. When do these get changed out? What are the part numbers specifically and did you have to modify in anyway to get the trans into place ?thx
Old 12-29-2016, 11:01 PM
  #558
Originally Posted by Brandle34
Does anyone 3x3 the trans fluid after the AV6 swap? I thought I saw someone post a rule of thumb to 3x3 change the fluid after 3k miles of the AV6 swap, but can't seem to find the thread.
I did the AV6 swap about 4 weeks ago (still runs better than it ever has and seems to get better every day ) and never changed the 3rd and 4th gear pressure switches with the swap.
I'd like to get those replaced during the next trans oil change - the sooner the better, just don't want to be changing the fluid too soon (if possible?) because ~$8 a bottle of DW-1 sucks
Did you ever get the pressure switches done? Did that make a difference at all? Do u know the part numbers?
Old 12-30-2016, 12:12 AM
  #559
I want to re-visit this just to be sure since I felt like a small slip in my transmission today (Bear in Mind I had the AV6 trans in my Garage for almost 2 years now).
What I have to Replace from my Current trans to the AV6:
1.- ATF Warmer
2.- Trans Harness
3.- Range Sensor
4.- VSA Holding Bracket
And that's it? I will re-use the AV6 ATF Filter since its cheaper.
How did your swap go?
How has it gone since the day you swapped?
Did you ever change your 3rd and 4th gear pressure switching?
Thx for the info?
Old 12-30-2016, 12:29 AM
  #560
Originally Posted by ttvegas2002
Just an updated on my swap
Got the transmission installed, replaced rearmain seal, axle seals, TC seal, new solenoids, new transmission filter ( i kept the old AV6 transmission filter setup). Been driving for 100 miles now and everything seem good, shift very smooth. Thank you very much for the great DIY guys, I saved myself 700-1000 in labor
ja
transmissi
What were the solenoids part number you changed ?
Quick Reply: FAQ: 06-07 AV6 Transmission 'Swap'
