Battery fuse blowing
Old 09-13-2015, 01:37 PM
Acura9915's Avatar
I have a 99 Acura TL. I just had the alternator changed and now the battery fuse keeps blowing. I checked the battery a and its good. I changed the ground wire to the battery. I did a basic 12 volt shortage check and it shows there is a short but it's not attached to a fuse. Not sure what it could be
Old 09-13-2015, 02:32 PM
Received 8,582 Likes on 6,629 Posts
You're gonna need to track down that short. We can't help you unfortunately over the Internet. The technology just isn't there yet. There's definitely a short, check all your cables and grounds especially around the alternator.
Old 09-13-2015, 04:14 PM
Acura9915's Avatar
anybody know what would make the battery fuse blow when just connecting the battery
Old 09-13-2015, 05:00 PM
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
thelastaspec's Avatar
a short somewhere...
somewhere in the cars wiring system, the + rail is connected to the - rail.
check around the alternator wiring as that was just worked on. Check the alternator in case its shorted out
google how to conduct basic electrical troubleshooting for nice videos that may help
Old 09-14-2015, 01:46 AM
01acls's Avatar
OP, which fuse No., what amperage, and which fuse box?
Old 09-14-2015, 04:48 PM
TLer trash's Avatar
If you're blowing the 125A main fuse, I'd suspect the alternator. Try this. With the battery disconnected, remove the big wire from the alternator. (the one with that's held on by a nut) Make sure this wire can't touch any metal. Insulate it with tape or a shop rag or whatever. Put in a new fuse, and reconnect the battery. If it didn't blow, the short is in the alternator. If it does blow, you've probably got a wire that's chafed between the fuse and the alternator.
The following 2 users liked this post by TLer trash:
01tl4tl (09-23-2015), Blue Hornet (09-21-2022)
Old 09-23-2015, 10:57 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
the battery neg cable has been found to let the cable loose inside its connector to the frame under battery box tray
Wiggle the wire and you get intermittent contact- maybe enough to blow a fuse!
Old 02-24-2020, 01:27 PM
Ryan Bisaillon's Avatar
100 amp fuseable link
MetalGearTypeS
08-29-2016 08:28 PM
jdmaszfcuk
10-19-2015 12:31 AM
hashbrown
09-29-2015 12:13 PM
Quick Reply: Battery fuse blowing
