clock light issue...
Old 10-19-2007, 07:41 PM
Punctuation Nazi
asujosh1's Avatar
the light on my clock has not worked for a while, I replaced the bulb and checked the fuse, but it was all good. Is there a known issue?
Old 10-20-2007, 09:17 AM
hockeynut's Avatar
Mine's been out for a while as well. Don't have an answer for you but how difficult was it to get to the bulb? I have been living with having my tuner show the clock at night, but it's irritating because I prefer it to show the artist, etc. (Sirius Sat)
Old 10-20-2007, 10:30 AM
2002 TL Type S
Balla4lyfe4421's Avatar
Hit above the clock on the dash with a good smack with the hand turns right back on and ur all set
Old 10-20-2007, 11:34 AM
Punctuation Nazi
asujosh1's Avatar
You have to take the cluster cover off, and there are only a few screws to do that. There are two above the gauges and one in the fuse cover area. Then there are clips above the right vent and the gauges. There are additional clips on the bottom near little cubby thing. It sounds a lot more difficult than it is.
Old 10-20-2007, 01:03 PM
Anachostic's Avatar
I posted my experience to: https://acurazine.com/forums/ramblings-12/where-should-i-go-162184/ with pictures
Old 10-29-2007, 11:13 AM
wdhendrick's Avatar
Talking Clock light is dim - is that normal?
Hey guys, when I bought my '99 TL the clock light was out. I read some of the DIYs here and replaced the bulb over the weekend - pretty easy. Thanks! However, I noticed now that the light for the clock is considerably dimmer thak the light for the climate control or the radio... is that normal? If I had to guess it's like 20 % as bright as the climate contol backlight. Since mine has never worked as long as I've owned it, I have nothing to compare it to other than the climate contol backlight. Can anyone confirm if that's normal?
Thanks!
Old 10-29-2007, 11:28 AM
Glacier Frost Mica CL-S
INSPIRE 32V's Avatar
WTF!!!!! is there suppose to be a clock light on the 03 CL-s as well cuz i thought there wasn't. this whole time i had to turn on the dome light at night to see the time.
Old 10-29-2007, 12:02 PM
Anachostic's Avatar
Thanks!
Mine is dimmer using the bulbs specified in the clock light thread. It bothered me at first, but not enough to try and find a brighter bulb.
Old 10-29-2007, 12:21 PM
No He Can't
6MTUA5's Avatar
AFAIK, there should be one on the CL as well
Old 10-29-2007, 12:29 PM
wdhendrick's Avatar
So the 'original' bulb was brighter? I can read the clock at night, which is good, but it's not quite as easy to read as the climate control, etc... I doubt I'd take the dash apart to put a brighter one in, but if it goes out again I'd probably prefer the brighter bulb... thanks.
Old 10-29-2007, 12:58 PM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
The OEM clock light bulb is rated at 0.94W. What's the power output for the aftermarket one ?
Old 10-29-2007, 01:50 PM
OM NOM NOM NOM
heyitsvu's Avatar
Just to let you guys know. The light produced from the clock should match every other part producing light from the instrument panels. my clock light matches my HU and my cluster
Old 10-29-2007, 03:15 PM
Anachostic's Avatar
I'm not so good at electronics, but I think the Amps/Volts/Watts is all one formula, so if I'm wrong, just say so.
The bulbs are 12V, 60mA, so does that equate to .72W?
Reference: https://acurazine.com/forums/showthread.php?p=1861557
Old 10-29-2007, 03:21 PM
2G TLX-S
Edward'TLS's Avatar
That explains why the aftermarket bulb is dimmer than the OEM one. It has 23% less power output than the OEM one.
Old 02-05-2016, 05:22 PM
Robbie Hill's Avatar
Lmao iv been doing the same thing the whole time!!!
Yikes
05-03-2021 04:29 PM
Kevin Sami
09-22-2015 09:59 AM
95legend6speed
09-21-2015 06:40 PM
thisisnotdave
4G TL Problems & Fixes
09-08-2015 10:02 AM
Quick Reply: clock light issue...
