12v Power Accessory Socket Doesn't Light Cigarette Lighter?
Hi everyone. I just bought a 03' Charcoal Grey TL with 112k on the clock for $5800. I just want to know from you guys if it was a good deal since this is my first TL and Acura. And yes, the transmission was changed 2 years ago so I should be ok. Right? I just read in my manual that the 12v accessory ("lighter") socket doesn't power "an automotive type cigarette lighter". I just find it weird because I always thought that, that was the main reason for having one of those. I used it a lot in my BMW that broke down recently but I can't believe that it doesn't power a cigarette lighter. What happens if I put one in? It just won't work? Thanks.
P.S. It's funny that "Acura" is considered a misspelled word on an Acura forum.
And its not the forum that is spell checking, its your internet browser.
next to the not an ashtray (you can buy an ashtray insert at dealer)
is the real cigarette lighter 12 v power- with big amps
The one in the center console is a `power port`- for running things like portable nav unit or kids cd player with low amp draw
the ashtray replaces the small compartment that says Not an ashtray
currently used for coins or whatever- caution: coins like to jump out and behind the panel~
your car should have a cigarette lighter built in to the right of the Not- and the extra power port inside the center/arm console- even has a place for cords to come thru so it still closes flat...
unless mine was a special order car!
call parts dept on monday and ask
I think they are both rated the same; 10 amps or less.
Can I even use the "Not an Ashtray" as a phone charger or gps charger...cause I tried to plug in my FM transmitter but it didn't work and when I pulled it out I almost pulled the whole thing out along with the silver part. There is like no connection for the plug. I then plugged it into the center console and it worked. I couldn't find the hole at first to put the wire through but then at night there is a light in there so I put my hand in there and dug around and finally found the hole Thanks 01tl4tl for mentioning it. I was just crushing my wire with the armrest because i can't drive without an armrest.
the thing next to the ashtray in pic is a power port- 12 volt- for those items mentioned above
In many cases its come off its retainer or something and may have pulled the wire off in back
Mine pushed in and need to fix ...Anyone done that? suggestions?, cut side panel off for access~
smokers- you can get a plastic cup like device that goes in the cup holder- its an ashtray!- 2 bucks at parts stores
thank you for not littering
Hi guys I am new here. I guess I have the same problem as I am stuck with the non-smoker edition of my 2003 TL.
I always found it confusing as the car has ashtrays on all the doors but the drivers and no lighter. I plugged in my old lighter from my accord but not working. Are the Acura lighters different than others?
Since I loose my lighters every other day I guess i have to DIY it.
Its so the driver is focused on operating the vehicle in a safe way, not smoking!
and keeps smoke away from the cd player and electronics--they dont like smoke
In their early years- BMWs came to this country with NO cupholders at all-!!
the driving experience itself in Eurpope demands full attention, so they didnt think usa car drivers would need several drink holders and ashtrays and....
IF canada cars same as usa:
there is a lighter socket to the right of Not an Ashtray- may require acura lighter (my 01 came with it and nav)
That socket does like to come out of its holder behind the panel-
have to get in there and clip it back in (mine is loose now)
You can buy, from acura - an ashtray to replace the Not ...box
I think they intended the box for change but you dont want to lose coins thru the back of there (shaking head)
the power port in the center arm rest is NOT a lighter- the wiring is not made for that high a power draw
You CAN run gps and other devices from there- I have a 3 outlet splitter plugged into mine- then whatever I want to run,,satellite radio, phone charger etc,,low load draw items are fine there
if you have a lighter outlet- did you ck the fuse for power?
Yep, I plugged in the 96 honda, then the Ford F150, then the Elantra lighters all the lighters are loose and doesnt hold so i think they used the sub assembly for power only.
Checked the pin inside and its flat nothing is protruding out of the back of the shaft.
Anyways I am going to the dealership and get a acura lighter + ashtray
The plug works fine because it is charging my iphone but to change it is it the same setup as the 2004 tl? because i couldnt find anything for 2003 TL.
http://techinfo.honda.com/rjanisis/pubs/AI/BII25333.pdf
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
