Battery Suggestion?
#42
Stay Out Of the Left Lane
Received 1,236 Likes
#43
Also, the last time I had a battery changed in store I request a power source be put on my electrical system before the battery was disconnected to save my radio code so I would not have to pull my antenna. Said they would but did not. When I put in a new Durlast battery myself today, I noticed that when Sears installed my old battery, the did not even bother to tighten the battery hold downs so the battery was rattling around for the last two years. The terminal screws were barely tightened. Very sloppy.
#44
Thanks for your reply. I was just curious as I have always gone to DieHards when the OEMs fail, but admittedly I haven't had to replace one in quite some time. I just replaced the OEM in the Accord my daughter uses in January and am expecting more than a year out of it.
Can't and won't defend Sears regarding your experiences, but I have always replaced the batteries on my own. I will say both at the time of the purchase and return of the old one that there were no other customers either time, so not sure what if anything this says about their automotive business. Good luck with your new Optima.
#46
Other than time and aggravation, the second battery didn't cost you anything right? And theoretically if you went with a third DieHard it wouldn't have costed you anything either right? These should have been covered 100% under warranty, no?
I know you already bought your Optima, but this is a good reference read - https://acurazine.com/forums/diy-faq...attery-890429/
#47
I did not buy the Optima and wound up with a Duralast Platinum because of terminal placement. Did not care about warantee, aggrevation not worth it. Battery died when I stopped in Barstow, halfway between where I live and Las Vegas. That was fun. Took a long time for AAA to find me and it was like 115 degrees.
#48
I got about 6 years out of the Optima Red Top in my TL (in extremely cold temps). I got about the same out of my BMW OEM battery in the car before that (in extremely hot temps). Now I believe my current VW has the OEM battery and it's 6 years old. It seems to me that 6 years is about what I expect if I buy a good battery.
MetalGearTypeS
08-29-2016 08:28 PM
kb1rl
09-30-2015 10:17 AM
4drviper
09-23-2015 09:00 PM
