Any 2G TL-S, TL-P with original trannys?
Old 01-31-2015, 11:45 PM
wowzer42's Avatar
I just joined Acurazine, but I am the original owner of a 2002 TL-S. I only have 80k miles and did all of the TSB's. My car still drives very well. With all of the posts about rebuilt trannys, I'm curious if there are there any other TL owners out there with the original transmissions?
Just curious...
Old 02-01-2015, 09:03 AM
comet24's Avatar
I'm pretty sure mine has the original trans. 2001 TL I bought it used a few years ago with about 85000 miles. It had sat for a year or two. Person I bought it from had a spreadsheet with maintenance. It listed going in for a recall on the transmission early on.
Old 02-01-2015, 11:04 AM
TunaTheFish's Avatar
About to hit 150000 miles. Original tranny w/oil jet kit. Sadly my torque converter failed on me but still driving fine atm
Old 02-01-2015, 12:00 PM
MarcDavidoff's Avatar
What are your torque converter symptoms? Just curious
Old 02-01-2015, 03:25 PM
AyyCee's Avatar
'03 TL-S A-Spec w/ original tranny. Only have 62k miles though lol
Old 02-01-2015, 08:48 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
anything over 50 is ripe for failure! thats what acura techs say!
Major problem with talking about trans on here- the azine curse~
OPEN Hood:
look at top of trans in center- is there a large bolt with ATF stamped on it, and the heads of several small and large bolts on the trans are painted BLUE?
that's a post feb 05 replacement
When you change fluid that big ATF bolt is the filler hole
If you look at top center of trans- where filler hole should be- and there is a device with a small hose attached- you have an original trans with the recall install external oil jet kit
Its possible to have a replaced trans prior to the case design change in 05- so it would have both the external thing and the blue bolt paint
Old 02-01-2015, 08:51 PM
01tl4tl's Avatar
You all need to get on a program to introduce the new fluid= DW-1 to the TL
and a new external trans filter is a good idea
cooling is the problem with our trans, and new fluid is better than decade old fluid-
you cant even buy the old stuff anymore!
Old 02-01-2015, 11:03 PM
wowzer's Avatar
How do you go about installing an external trans filter?
Old 02-01-2015, 11:36 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
^ pretty easy to do.
There is a serviceable line that comes out of the stock filter remove that and place a Inline filter in its place and it's done.
Old 02-02-2015, 01:12 PM
dannysayaseng's Avatar
99 TL-P with roughly 153xxx miles with original tranny but will be doing 6MT swap when time permits in the spring
Old 02-03-2015, 01:07 PM
ellisd03tls's Avatar
2003 TL-S with only 185k km (115k miles) with original. Been using DW-1 since about 140k KMs.
Old 02-03-2015, 02:10 PM
jaaaydeeem's Avatar
2nd owner of a 2000 TL going on 217k.... But tranny is finally giving out, so getting all my 6spd swap parts...
Old 02-03-2015, 05:41 PM
01tl4tl's Avatar
wowzer see the diy for help on replacing the atf filter
there is one there even acura parts guys have never sold~ but we know about it!
remove battery tray and its below that= a few more bolts and things in the way then its right there!
Requires a minimal donation of skin layers to the car gods for access.
Spin on type, order aftermarket brand online (amazon) for 15$
if you install an additional filter unit- get the magnetic type iirc called magnafine ?
someone here knows for sure
jaaaydeeem (02-04-2015)
Old 02-03-2015, 06:26 PM
ReCKeD's Avatar
2000 SSM TL-P , 120,xxx miles, original tranny
Old 02-04-2015, 03:43 PM
jaaaydeeem's Avatar
I'll def look into it!
My rear main seal is in pretty bad shape, making and the cost to fix it is outrageous... Soooo, jus gonna do the 6spd swap lol!!
Old 02-10-2015, 12:16 AM
8th Gear
PD1505's Avatar
2002 acura tl type s original tranny 87000
Old 02-11-2015, 06:34 PM
9th Gear
Scotland's Avatar
Magnafine is correct. Also look at Transprotector at TRNW E-Store
Old 02-12-2015, 01:08 PM
Brianm97's Avatar
My sister has a 2002 TLS with about 210,000k miles on there with ORIGINAL TRANNY.
We've had it in our family since new. Still drives better than my 02 TLS with 195,000 miles with a rebuilt tranny.
Then again my aunt and my sister probably never takes it above 5k rpm.
Old 02-13-2015, 11:20 AM
acura_fantacy's Avatar
2003 TL-P with 108k miles, original tranny with 3QT ATF drain/fill every 20k since new.
Pham Alvan
05-18-2021 06:48 AM
Charles Bennett
01-28-2018 08:53 PM
MetalGearTypeS
08-29-2016 08:28 PM
Jinkazetsukai
11-21-2015 05:28 PM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: Any 2G TL-S, TL-P with original trannys?
