High beam socket came off wires.
Old 01-15-2013, 10:21 AM
xTheWarrior's Avatar
Ok I was just replacing my high beam bulbs but there was no slack at all with the wiring so getting the bulb out was more difficult than it should have been. Anyways by the time I got the bulb out the wires came loose off of the socket that the bulb goes into. Idk how to put the wires back into the socket and make them stay connected. Right now the socket is off and the wires are just hanging freely under the hood. Anyone help?
Old 01-15-2013, 04:15 PM
3.2TLc's Avatar
Have you tried removing the front bumper cover for better access to the headlamp ?
It may be easier to work on this way, if you have not already done so.
There are connector pins which the wiring is connected to within the socket. It may be easier to get another socket and splice the existing wires to the new one, IMO. That will give you some more slack in the wiring.
HEAVY_RL (01-15-2013)
Old 01-16-2013, 10:17 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Can you take a picture for us to better see? Are there bare wires exposed, or did the pins pull out of the harness and still attached to the wires.
Also next time take the connector off the light BEFORE trying to remove the bulb.
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
MrHeeltoe
09-29-2015 10:43 PM
San Yasin
09-29-2015 10:52 AM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: High beam socket came off wires.
