Abs and tcs indicator lights
Old 01-26-2017, 11:20 PM
Acuratl3535's Avatar
I have a 2003 Acura TL. So my abs and tcs lights have been on for awhile. I changed my brakes about 5 months ago and the light has been on for about the same time. Where are the sensors that are by the brakes that turn these indicator lights on if something goes wrong? I feel I may have not hooked it back up or never notice it unplugged/ or it may just be corroded.if that isn't the problem what are the first few troubleshooting methods I can use to track down the problem? No codes came up at advanced auto(not sure if they have a good scanner).Thanks for the help
Old 02-08-2017, 09:34 PM
4th Gear
DD01TL's Avatar
Check out this link to another post in the 2G section - I found it very helpful: https://acurazine.com/forums/2g-tl-p...hlight=abs+tcs
Old 02-08-2017, 09:35 PM
4th Gear
DD01TL's Avatar
Old 02-17-2017, 11:39 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Look for the thin wire you tore loose when doing the brakes
Have to be careful about setting brake caliper on the line... see those splines on the end of the CV, the sensor reads those metal ridges
Rust from salt areas is another reason for wire failure.
New Wheel Speed Sensor from dealer, ck our sponsors for a deal
