99 acura tl stuck in park and brake lights won't work
Old 08-25-2010, 08:51 AM
7th Gear
Leecie's Avatar
My 99 acura tl will not shift off of park. I have to push the button on side of shifter in order to bypass and be able to drive but didn't realize that my brake lights do not work as well. I replaced the brake sensor underneath the foot pedal and that did not solve the problem. Please can any one help me with this matter....scarred of dealer charging me and arm and a leg
leecie
Old 08-25-2010, 10:43 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
ck the sensor install, ck the cruise control switch next to the new one for installed tight
ck fuses for brake lights
It wont shift out of park BECAUSE it has no brake lights!- a safety feature to protect you
do you get taillights with just headlight switch?
Old 08-25-2010, 10:44 AM
01tl4tl's Avatar
you dont need the dealer on this one- we can get you thru it
reck your work on the new switch, power leads on tight and correct- try swapping them?
Old 08-25-2010, 12:33 PM
7th Gear
Leecie's Avatar
My tail lights and head lights work, its just when I press on the brakes, the brake lights do not light up.
Old 08-25-2010, 12:35 PM
7th Gear
Leecie's Avatar
I checked all brake light fuses and they are all good. I had one bulb out and replaced it and still nothing. Im confused about the cruise control switch. Would that not allow the shift and light to not work?
bartlife (09-04-2021)
Old 08-25-2010, 01:47 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Its either the switch or the brake fuse. Are you sure you checked the brake fuse? The TL has 3 fuse panels. Which one did you look at. Is the switch adjusted properly?
Old 08-25-2010, 06:16 PM
7th Gear
Leecie's Avatar
I checked the fuses on the drivers side, the passenger side and underneath the hood. I also double checked that the foot pedal was pressing against the switch. Where would the brake fuse be? I was told it could be the shifter solenoid. I have the whole center of my car torn apart to try to get to the solenoid and check if that could be the problem.
Old 08-25-2010, 06:42 PM
01tl4tl's Avatar
did you test the fuses with a multi meter, or just visual inspection?
Try new fuses in the possibles?
the cruise control disconnect switch on the brake pedal- next to the brake lamp switch-
if both are not set right you get problems
Ck the DIY section for install of switch= to double ck your work
on bulbs- Every bulb, including the center mount brake light must work, or the safety kicks in
Is there a brake LAMP warning light on? meaning the car knows a bulb is out
ck for power to wires for the brake light switch
should get power thru the switch when pedal pushed
New part may be defective!
stop digging into the console and find the brake light problem
If the brake lights worked- then it would be nuetral safety switch failure
Old 08-25-2010, 06:48 PM
tunene25's Avatar
i got the same situation just happend to me yesterday i tough that the guys that installed the alarm messed up my car they say something behind the brake im gone go tomorrow to buy whatever it is if u fixed ur problem tell us about what it was .
Old 08-25-2010, 10:12 PM
OMG-6SPD
Bada$$VTEC's Avatar
Not sure if your TL has a STOP fuse in the fuse box under the hood (thats for ur brakes),but i can bet thats what causing it not to work according to what u described.
The reason i know is cuz this same thing happened to me on my Accord and then i checked out and saw my brakes werent lighting up when i stepped on it,so i changed the STOP fuse (20A fuse) and it started working again. Goodluck.
Old 08-26-2010, 04:33 PM
2000 Acura TL
closetprisoner's Avatar
fyi,
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-brake-switch-614710/
Old 08-26-2010, 08:08 PM
tunene25's Avatar
yeap it was the brake switch i buy it on pep boyz a new one installed it and it work im happy it was that 40 box and i did it myself.
Old 08-30-2010, 12:37 PM
7th Gear
Leecie's Avatar
Well I'm still going thru it. I dropped it off at a garage and they can't figure out the problem either. I even went to autozone and purchased a new brake switch thinking the one I bought form Napa was defective. I checked all fuses and all are fine. Not sure what to do now. I guess I might have to fold and take it to the dealer. Crap!
Old 08-30-2010, 05:51 PM
01tl4tl's Avatar
a good shop should be able to find where you have power and where it stops
Thats why they are in business
start at fuse box, then switch, wires to brake lights, ground wires, bulbs- connectors
There a real suspect- a bad ground wire
Done any work in the trunk?
there is a main ground under the spare tire that gets disturbed in sub work
Old 09-01-2010, 10:25 AM
7th Gear
Leecie's Avatar
I recently had a stereo installed but other than that no. I had my car in the shop for two days and they cannot even figure out the problem...crazy!..well sucks to say but acura dealer service shop will be ripping me off but I need my car fixed. I thank everyone on here for all your help. This site is a beast!
Old 09-01-2010, 11:10 AM
01tl4tl's Avatar
so the stereo install could have knocked a ground out, or they borrowed off a ground and its not right or ....
has that shop rechecked its work?
when a new prob appears after work,, I suspect that work!
dont go to acura for this- look in the phone book and internet for `automotive electrical repairs`
Those guys love wiring--
most everyone else has a severe dislike of tracing electrical probs--shorts are a b to find
time consuming and back breaking
talk to the stereo shop- look in trunk under spare tire for ground wire not right
Old 04-14-2011, 10:41 PM
bridget_anders's Avatar
i have a 1996 acura integra ls, and im having the same problem. when i turn my car on and put my foot on the brake i cant push my button on my shifter to move it. i also realized i have no lights. i was told this might be the break light switch? does that sound right. what else should i check? and also by bypassing the shifter i use the saftey lock with this mess up my transmission???
Old 04-14-2011, 11:08 PM
please help!!!
Old 04-14-2011, 11:49 PM
freebieman's Avatar
I doubt it will mess your transmission up. Did you check the brake fuses; I have a tl so I don't know where yours would be, but check your manual or go to your fuse boxes.
Old 04-15-2011, 02:12 AM
01tl4tl's Avatar
no it doesnt hurt ther transmission
Its a safety lockout, so you know there is a problem and dont drive off with no brake lights
If all the lights have quit- ck the fuse first,, but its likely the switch
easy DIY, ck parts store for switch
Do you get tailights but no brake lights?
01tl4tl's Avatar
try posting in the correct gen and type for best results
Old 10-29-2013, 02:37 PM
Southphillysean's Avatar
i just got an 99 Acura 3.2 tl. after reading trough this thread i see that i am not the only one with the "cant get out of park" problem. i do have a question. my brakes lights are still working. could it still be my Brake light switch?
Old 01-08-2014, 10:56 AM
sbaughman's Avatar
My symptoms were the same but also included the inability to operate cruise control. Changed the switch to no avail. From this post looked more for fuse. Found it labeled "stop" on right side of engine compartment, 20 Amp. Blown. Replaced. All now works. Thanks everyone.
02-25-2020 09:57 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
bymotion
08-31-2015 05:00 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: 99 acura tl stuck in park and brake lights won't work
