06-07 accord trans swap
Old 11-22-2012, 12:22 PM
  #41
03_BigJ_TypeS's Avatar
Ok guys, well I called Acura and they told me to kiss their ass on a free replacement. So looks like I am doing the tranny swap for sure. When I do the swap, I am take pictures and such to do a DIY, I know that would help many of us here. I want to post up pictures of what needs to be replaced from the TL tranny to the Accord tranny.
3rd and 4th pressure sensors, pictures of them on the TL tranny, remove those and put them on the Accord tranny. I would recommend buying new ones though just like Stephen said.
3rd pressure location
3rd pressure removal
4th pressure location
4th pressure removal
Range switch removal
Range switch neutral position
Oil warmer, located on the top of the transmission, it is in a box with the number 1 next to it.
Old 11-22-2012, 12:35 PM
  #42
Transmission Filter
Acura Part: FILTER (ATF)
Part NO.: 25450-P7W-003
Gasket- Oil Warmer
Acura Part: GASKET, PASSAGE BODY (ATF)
Part NO.: 25812-P7W-A01
O-Rings: Oil Warmer: you need 2
Acura Part: O-RING, WARMER (ATF)
Part NO.: 19435-P8E-A01
3rd Pressure Sensor
Acura Part: SWITCH ASSY., OIL PRESSURE
Part NO.: 28600-P7Z-003
4th Pressure Sensor
Part NO.: 28600-P7W-003
Washer for Pressure Sensors
: you need 2
Acura Part: GASKET (10MM)
Part NO.: 90471-PW7-A00
Old 11-22-2012, 12:38 PM
  #43
I forgot to ask, anyone one who has had a Oil Jet kit, I was told the it is not needed but what is done with the hose leading into the jet?
Also, how much fluid does the Accord AV6 Tranny take? Are you supposed to place transmission fluid in the convertor? Haven't messed with Auto trannys in a while!
Old 11-22-2012, 03:54 PM
  #44
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
I filled up with 3.5 quarts when I swapped mine in and then within the first 1000 miles did the 3x3 drain and fill
Old 11-22-2012, 09:13 PM
  #45
Thats all the Accord Tranny takes, 3.5 quarts?
Old 11-23-2012, 12:15 AM
  #46
The torque converter holds majority so unless you crack that open you should only have to fill it with about 3-3.5. That's also the reason why you do the 3x3 within the first 1k miles
Old 11-23-2012, 10:31 AM
  #47
Ah ok, so you put 3 to 3.5 quarts in the convertor, how much in the Trans?
Old 11-23-2012, 11:27 AM
  #48
NO!! I didn't crack open the converter so it already had fluid in it. I only put fluid into the drain whole which is the case and that was about 3.5 quarts. You don't have to put fluid in the torque converter unless you crack it open
Old 11-23-2012, 12:38 PM
  #49
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
All depends on how much fluid is drained out of the trans when you get it. Odds are its the same as the TL trans.
Oh and for those of you doing this because your trans died. DONT reuse your torque converter.
Old 11-23-2012, 12:43 PM
  #50
fsttyms1's Avatar
Did you honestly expect them to give you a free one when its 2 years past the extended warranty?
Old 11-23-2012, 01:45 PM
  #51
Type S-ing!'s Avatar
Do you need all those gaskets and rings? I already dropped my tl at the shop to get my swap, is this going to be a problem without getting new ones?
Old 11-23-2012, 02:04 PM
  #52
You don't need them but it's recommended. If you don't get them there easy to swap later if they leak
Type S-ing! (11-23-2012)
Old 11-23-2012, 02:54 PM
  #53
Well I'll pray that it's cool and that's for the info.
Old 11-23-2012, 03:28 PM
  #54
Some of the o rings and things I reused and I have 3,000 miles so far with no problems
Old 11-23-2012, 08:03 PM
  #55
Thanks, good to know.
Old 11-24-2012, 12:47 PM
  #56
Damn Stephen my bad, misunderstood what you said, I got it, so no fluid in the converter and add 3.5 quarts to the trans and check it. Got it and thanks.
Yea it should be similar, and that is right, use the converter from the Accord guys!
Well I gave it a shot, 2 of my friends fought Acura and got it replaced but of course, they failed again so I'm not even going to fight it anymore, I'm just going to change it and avoid the headache you know.
Like Stephen said, the gasket for the oil warmer and filter is needed, the rest is to be just sure, they are only a couple more bucks.
Old 11-24-2012, 12:56 PM
  #57
I have a trans in sight right now, they want 1150$ And it has 79k on it, 199 day warranty, a 33 day full refund guaranty.
It says best offer, I'm going to offer 800$ and see what's up, shipping is 75$, what you guys think?
It's the best deal I found, the rest of the trannies have 97k and they want 800$ with 125$ for shipping, only 30 day warranty. To high in miles for me.
Old 11-24-2012, 01:40 PM
  #58
I'd offer 800$ shipped I paid 1100$ for mine and it only had 29,xxx miles
Old 11-24-2012, 02:10 PM
  #59
The same guy has one with 29k on it, he wants 1400$ plus 75$ for shipping, now I could offer him 1000$
Old 11-24-2012, 02:19 PM
  #60
I went with one with less miles because it should last longer and it's not going to be beat up for higher amounts of miles. Also of the person never changed te fluid they were still within te recommended interval
Old 11-24-2012, 03:02 PM
  #61
Good good point on the service interval, didn't think about that, the coupe seemed to take a hard hit in the front, I dont think it effected the tranny, here are some pics
Old 11-24-2012, 04:05 PM
  #62
That's a pretty bad impact, I'm not sure how much damage that can do to the transmission. Te one I got had a rear impact
Old 12-01-2012, 08:10 AM
  #63
peewizzle's Avatar
checking in here:
just got my car back lastnight from a buddy who did 06 accord swap for me. car shifts like a dream and WOW talk about firm steering now. sort of feels like there's no power steering at times though but for people doing this swap, be prepared for VERY FIRM steering.
Old 12-01-2012, 09:20 AM
  #64
Originally Posted by peewizzle
checking in here:
I only really notice the stiff power steering the most when I'm trying to turn the wheel without the car moving. I like it better because you get a tighter feel and it feels sportier
Old 12-01-2012, 10:16 AM
  #65
peewizzle's Avatar
yeah when not moving i'm like damnit but while driving it feels real nice haha i just hope nothing gets damaged long term. i already have enough stuff to replace right now
i noticed though that it feels like overdrive isn't kicking in for me. at 70mph i'm at about 2200-2300 rpm, i don't rememeber if this is where it used to rev at while traveling at that speed. otherwise shifting is like a dream
Old 12-01-2012, 11:31 AM
  #66
It's at higher rpms because 4th and 5th gear are shorter gears with that transmission I have a few thousand miles on min and 666worker has well over 10,000 miles with no problems. Also there are other people using different transmissions that deleted it with over 50,000 miles.
peewizzle (12-01-2012)
Old 12-01-2012, 12:20 PM
  #67
peewizzle's Avatar
phew well that explains it! hah i thought i was going out of my mind but now i feel better.
Old 12-01-2012, 12:31 PM
  #68
peewizzle's Avatar
so if i ever need to replace the 3rd/4th gear pressure sensors. are the sensors the same for acura/honda? my buddy said he used my old pressure sensors from the tl tranny and i'm not having any issues.
Old 12-01-2012, 02:49 PM
  #69
I'm running the ones for the 07 accord v6
Old 12-01-2012, 06:07 PM
  #70
peewizzle's Avatar
so this rpm is normal? feels weird since i'm so used to TL overdrive kicking in after getting to 5th.
Old 12-01-2012, 06:27 PM
  #71
that's right around where it sits in my car, why is your cel and tcs light on?
Old 12-01-2012, 06:53 PM
  #72
peewizzle's Avatar
the check engine light is on because i tore the wire to the downstream o2 and the tcs light because i need to replace the wheel speed sensors ughhh
Old 12-01-2012, 09:58 PM
  #73
That sucks the 02 sensor is easy just replaced both mine a little while ago. I got them from napa for cheap.
Old 12-04-2012, 08:33 AM
  #74
jenny76's Avatar
Why does the steering get tighter after the transmission swap
Old 12-04-2012, 09:14 AM
  #75
If you have a tl p there is a powersteerig speed sensor that connects to the transmission. There is not a spot for it on the new transmission so you have to grab a hose to loop the rack. Since there is no more sensor the steering is tighter especially while trying to turn the wheel without the car moving. If you have a type s you don't have to worry about it
Old 12-08-2012, 05:51 PM
  #76
greengables's Avatar
Same indicator lights > bad outcome
Hey guys, sorry for adding to a old tread but I am in trouble, I am currently texting from aside the road. My 03 TL Type S just hit me with the CE, VSA, and /!\ light combo. I'm letting it cool down for a bit before I try to make it home, kinda died on me and I wasn't able to do anything about it. I am interested in the Accord transmission for sure, I will be needing one soon it looks like. Does the triptronic still work if you do the swap? Also does anyone have a shop in the Tri-State area that has done the job? I am so busy with school and work that I may not have the time to do it. This couldn't have happened at a worse time for me financially wise.
That same thing happened to me last Wednesday night when my tranny completely failed. I found someone near Bloomsburg PA which is going to do the swap for me as I do not have an engine lift. Otherwise, I'd probably try to tackle it myself. I'm looking for an accord transmission this weekend. I hope you fare better!
Old 12-08-2012, 06:25 PM
  #77
Just make sure they swap everything that's listed and there's no way your doing it without a hoist becuase it just weighs to much
Old 12-08-2012, 07:56 PM
  #78
2003 Accord Coupe V6
SatinSilverAV6's Avatar
how much are you guys paying in labor for the tranny swaps? thanks!
Old 12-08-2012, 09:20 PM
  #79
Only 300$ because a friend helped me do it. The only place that was willing to do it for me wanted 1000$
SatinSilverAV6 (12-10-2012)
Old 12-10-2012, 08:30 AM
  #80
peewizzle's Avatar
i paid a buddy of mine $500 labor
Quick Reply: 06-07 accord trans swap
