K-002: Window control/window won't roll down/window reset procedure
#81
Rear window malady here too. Solution was the 5 second up/down described in response by "getakey" member. THANK YOU!
Note: Had battery replacement months ago, but hadn't tried rear windows (Winter).
Saved a 50 mi RT to dealer, probably $.
#82
rear windows 05 rl
ahh man thanks to this post. i could finally fix this problem ..had this problem for a couple of days now and i was pissed so i decided to google it and this came..thanks guys i appreciate it!!!
#83
Thanks for posting a year after joining! Welcome to AZ and glad you got this problem solved. It's very common with the RL.
#84
you can reset the windows yourself. press and hold the button to put the window the whole way down then hold for 5 seconds after the window is down. let go of the button. press and hold the button to put the window the whole way up then hold for 5 seconds after the window is up. your windows should now be reset and can be controled from the drivers window controls. I had to perform it just tonight to be able to control the passenger windows from my drivers door controls
oo7spy (07-25-2011)
#85
Thank you for finding this thread and not starting a new one!
#86
please help
Just a few weeks ago there was a snowstorm in new york. While i was removing the snow from my car some of the snow ended up window on my power window switches. i tried to remove the snow as quickly as i could but some snow got in there. Ever since then my rear windows wont go down when i use the driver side window switch . i tried pressing the window lock button but the windows still wont go down. i have an appointment on wednesday to acura but im not sure it it would be covered under warranty....please help
#87
Search "window reset". Something about holding the button down for 5 seconds after it goes all the way down, and then 5 secs after it goes all the way up will reset it. Other than that, there is a service manual in the garage with a Power Windows.pdf that could help you troubleshoot.
#88
#90
when i use the back power window switches the windows go down but the driver side one won't
#91
you just need to do a reset. happen before
To reset the EACH problem window, do these steps from the individual window control, NOT the driver's master control panel:
Press and hold the button to roll each problem window all the way down, then hold for 5 seconds after the window is down. Let go of the button. Press and hold the button to put the window the whole way up then hold for 5 seconds after the window is up. your windows should now be reset and can be controlled from the drivers window controls.
#92
#94
Maybe an unambiguous statement is necessary to help diagnose the alluded issue?
#95
If the rear switch can still open and close the window, but not the main switch, it means the driver's main switch is bad due to snow falling on it and killing it.
#97
Thanks everybody for all your input . You guys saved me a trip to the dealership the back windows work now . i did the reset and it worked like a charm. Thanks again
#98
Auto down stopped working
Well...I've only had my car for about 2 months and I've already encountered a problem. My auto down seems to have stopped working. Any idea what could be causing this? I'm guessing I will have to take it to Acura but I just wanted to get some input.
#99
did u try checking the fuse?
#100
Have you tried resetting the controls? There are instructions to do so on this site. Here they are:
Press and hold the button to put the window the whole way down, then hold for 5 seconds after the window is down.
#102
Power window issue
Hey guys ,
I recently noticed my rear power windows were not working from my drivers switch but when push the actual button on the rear doors it works, i thought it was a window lock issue until today when my passenger window switch also stopped working!. Now only my drivers window works out of the 4 switches on the drivers control , anyone else experienced this issue?
#103
a lot of previous threads on this
just follow the instructions for the "reset" in this thread
https://acurazine.com/forums/showthread.php?t=839352
The following 2 users liked this post by getakey:
2005WhiteRL (04-05-2012),
HEAVY_RL (04-05-2012)
oo7spy (05-25-2012)
#106
I had the same problem. What this fix is for is if you have a window that will not roll down with the drivers master window control but it will roll down with the single control at that door. You need to roll that window down and up in this sequence and then the master control will work. If you have a window that won't roll down with any of the switches you have another problem.
Scott
#109
I apparently fixed it when I went to investigate why I could not roll down the passenger window but the passenger could. At first I thought it was a short. So I rolled it down ... then rolled it back up - then it worked again! Now I see why. LOL!
#110
Thanks again.
#112
Would LOVE for this to work to CLOSE all windows Do any of the newer RL's, mines 08 work like this? Would be nice to open home door and close all windows before I go to bed !!!
#114
Hold the key after locking to close.
#115
#116
Power windows help
So my windows been working fine until one day I go to open passenger windows with the driver controls and they don't respond, if I reach over to each individual window and push down, they will open. I check fuse box and all the related fuses and they are fine. Just wondering if anyone ran into this problem before and of there is some trick to get this working or some fuses that I don't know about...thanks
#117
Yes this is a common issue and easy to fix. I believe you need to make the window go all the way down and hold for 10 seconds, then all the way up and hold for 10 more. Something like that anyways. You can search for "Window reset" if you don't want to rely on my shoddy memory.
#118
Originally Posted by RL Service Manual, Power Windows.pdf
Power Window Reset Procedure
1. Turn the ignition switch ON (II).
2. Move the window all the way down by using the window DOWN switch.
3. Open the driver's door.
4. Do the following 3 times before going to step 5:
-Turn the ignition switch OFF.
-Push and hold the window DOWN switch.
-Turn the ignition switch ON (II).
-Release the window DOWN switch.
5. Confirm that AUTO UP no longer works. If AUTO UP still works, go back to step 1.
6. Move the window ail the way down using the window DOWN switch.
7. Pull up and hold the window UP switch until the window is all the way up, then continue to hold the
switch for 1 second.
8. Confirm that the power window control unit is reset by using the window AUTO UP and AUTO
DOWN function.
DOWN function.
EDIT: Reading back over this, I don't think all of these steps are necessary. IanVS is right. First try this:
1) Hold window button down until 5 seconds after the window is all the way down.
2) Hold window button up until 5 seconds after the window is all the way up.
The following 3 users liked this post by oo7spy:
#119
You guys nailed it! I had tint installed for the driver and passenger front windows and the company must have run the battery all the way down during the process. When I picked up my 2008 MDX, I had to reset many of the program features.
The big problem was the passenger window wouldn't roll down from the driver position. I had no clue how to fix the problem and didn't want to deal with another auto shop or dealership. Enter AcuraZine... The knowledge of this site has made my MDX purchase much easier. I simply followed the instructions of fellow members (hold window button down for 5 seconds down and and up) and BOOM! fixed.
Thanks for the help guys.
Now if we could only find someone to start making the front lower aluminum trim for the 2007+ MDXs again.
#120
AZine is smarter than Siri's and Watson's unlikely children.
