Transfer case gear oil: Is 75W-90W OK? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 03-14-2010, 09:39 PM   #1
2005 MDX & 2006 RL
At some point, when the east coast weather gets a bit warmer, I'll do my tranny and transfer case. The repair manual suggests API G4/G5 in the SAE 80W-90W range. Seeing that it rarely gets below 0 degrees in the Philly suburbs, 90W hypoid gear oil is the requirement. However, I have a bottle of Valvoline synthetic 75W-90W gear oil in my garage (http://www.valvoline.com/products/br...er/gear-oil/59). Would this be OK to use? Does the weight range matter in this case? Would this oil be too thin? Thanks!
cbrose is offline   Reply With Quote
Old 03-19-2010, 11:04 AM   #2
2005 MDX & 2006 RL
75w90 may work fine in transfer case
After some reading/searching, I found some comments from people asking the same question with their vehicles. Here's a response from Mobile 1 on using 75w90 where 80w90 or 90w is called for:
http://www.mobiloil.com/USA-English/...Viscosity.aspx
Could be propaganda from Mobil 1, but makes sense it's still 90w at operating temperature and it meets the GL-5 EP rating. Comments?
Old 03-19-2010, 01:28 PM   #3
Registered Member
I have used the Mobil 1 product before, as long as it meets the API GL5 its fine....that is the standard that is required etc.
JPSMAN is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Shifting Gears (6MT): Help diagnose the problem SidhuSaaB 3G TL Problems & Fixes 9 10-18-2016 11:20 PM
Ignorant buyers not understanding VCM / complaining about transmission joflewbyu2 Fifth Generation TLX (2015+) 139 10-08-2015 12:16 PM
How do I make my paddle shifters fully manuel? I hate how the gears change on its own guyvelella Second Generation TL (1999-2003) 8 10-01-2015 12:02 AM
B136 Service. 3x3 ATF Swap or just drain and fill hpfiend Second Generation RL (2005-2012) 1 09-27-2015 07:59 AM
SOLD: Metal Gear Solid V: Phantom Pain (PC) AcuraKidd Non-Automotive & Motorcycle Sales 1 09-26-2015 05:10 PM
Tags
75w90, 75w90w, acura, case, fluid, g4, gear, gl5, hypoid, mdx, mobil, oil, parts, range, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
