timing belt
Old 03-04-2010, 11:30 PM
pearlrl's Avatar
timing belt
my rl has 72k and was wondering should i change my timing belt and how much would it be??
Old 03-05-2010, 05:54 AM
miner's Avatar
Change your belt and water pump @ 105K. Will probably be around $700 @ dealer. The water pump has to come off when the belt is changed so you might as well pay the price for the part since you are already paying the labor.
Old 03-05-2010, 11:47 AM
getakey's Avatar
I had the 105K service - its about $1100 at dealer in Calif
Old 03-08-2010, 10:17 PM
pearlrl's Avatar
wowzers!
Old 03-09-2010, 11:56 AM
The Box
vas25tl's Avatar
Wait until 105K and get everything done.
Old 03-09-2010, 06:04 PM
SH-AWD
LeftCorner's Avatar
Don't misinform anyone if you're not sure. The pump does NOT have to come off to change the belt. It's still a good idea to replace the pump when doing to the t-belt svc to save on future labor.
Old 03-10-2010, 12:21 PM
miner's Avatar
I stand corrected if you think you are sure. I have not done an RL TB/pump service before - basing my statement on other Hondas I have worked on. It would not be a good decision not to change pump when doing TB.
Old 03-10-2010, 06:38 PM
drolds72's Avatar
Its not physically required to remove the pump to change the belt. However, once you have the belt removed from the car, its about 15 more minutes of work to swap out the waterpump. This is based on my timing belt replacements on an acura integra(twice), acura legend, and a honda civic. What I also have done for an extra $50 or so, is to replace the belt tensioner. Also very easy once the belt is off.
Old 03-15-2010, 08:25 PM
2005 RL
racerrl's Avatar
My local Crown Acura dealer quoted $1600 for a timing belt change!
Old 03-15-2010, 11:44 PM
Dopes6070's Avatar
I asked my dealer about the t-belt service and they said it was $1300. I did it myself for $350 with all OEM parts. It was no harder on the RL then any other honda... Ive done a few civics & accords so it was no big deal at all. Definatly do it at 105k.
New Idler
Tensioner
Water Pump
Belt
Old 03-16-2010, 11:04 AM
rtr
RL owner
rtr's Avatar
105k you mean miles or km's?
Old 03-16-2010, 11:49 AM
Dopes6070's Avatar
105000 miles is when honda says it should be changed. Its not something I would take a chance with since the repairs will likely be into the $3000+ range if the timing belt breaks...
Old 03-17-2010, 01:28 AM
rtr
RL owner
rtr's Avatar
yea thanks im in canada im in km's. Dealer said 180000
Old 03-19-2010, 12:23 PM
getakey's Avatar
New Idler
Tensioner
Water Pump
Belt
Don't forget the plugs.
Old 03-19-2010, 12:30 PM
Карты убийцы
Professor's Avatar
The plugs are a maybe... I pulled the original plugs from my 2003 TL with 175K and the gap was still within specs. The dealer wanted something stupid at the 105K service... like $18.50 per plug. I still have the orginal plugs in the car and no change in gas mileage.
vaughanml2
11-01-2021 10:16 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
09-16-2015 12:21 PM
merc009
09-14-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: timing belt
