tilt and telescoping steering wheel issues - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 05-01-2011, 03:16 AM   #1
Chapter Leader (Chicago)
RL Chi-town's Avatar
Exclamation tilt and telescoping steering wheel issues
OK i have tried looking and searching. i am tired and i am hoping you can help me out...
i had an issue with my car... so i disconnected my battery... When i reconnected my battery.... the steering wheel won't adjust...
i hope you can help...
steps that i have done
1. Checked fuses
2. remove fuse and but back
3. Remove negative again battery..
i have a feeling its something so small but i can't figure it out... so any tips is highly appreciated thanks.
RL Chi-town is offline   Reply With Quote
Old 05-01-2011, 09:06 AM   #2
Registered Member
dwboston's Avatar
1. Checked fuses
It won't adjust at all? Or just when the car starts up? How old is your battery? Did you try re-linking your key fob? There is a telescoping steering wheel setting in the setup menuas well.
Edit - from the owner's manual: "If your vehicle's battery is disconnected or the power tilt steering wheel fuse is removed, you need to reset the telescopic steering wheel system. Push the ignition switch for more than 1 second and release it, or insert the built-in key into the ignition switch, and remove it. The steering wheel automatically move fully in to let you know the system is reset."
dwboston is offline   Reply With Quote
Old 05-01-2011, 09:53 AM   #3
Registered Member
HEAVY_RL's Avatar
I'm going with a new car battery... how old is yours?
HEAVY_RL is offline   Reply With Quote
Old 05-01-2011, 12:12 PM   #4
I did those steps guys. my battery a 2yrs old. And I have no extra accessories. So dunno
Old 05-01-2011, 07:55 PM   #5
Missing my
tnobori1's Avatar
Try cleaning the contacts and terminals. Even a little corrosion can do weird things to a car.
tnobori1 is offline   Reply With Quote
Old 05-02-2011, 02:46 PM   #6
Registered Member
getakey's Avatar
Are you saying it won't adjust using the button or won't adjust automatically when you start the engine?
If the latter, you have to reset your Driver memory setting after disconnecting the battery.
getakey is offline   Reply With Quote
Old 05-03-2011, 12:00 AM   #7
ok i did that too... i put the key in the ignition and nothing... i also pushed in the key and that didn't work... so
Old 05-03-2011, 09:51 AM   #8
Registered Member
thephantom's Avatar
I'd say this is a dealer gig.
thephantom is offline   Reply With Quote
Old 05-03-2011, 11:43 PM   #9
Registered Member
merlin the wrench's Avatar
please confirm. You open the car door. Move the black knob facing on the side of the column facing the door in all 4 directions and the steering does not move in any of those 4 directions?
If that is correct and it does not move - please look at page 103 in your owner's manual for instructions how to turn it back on. (page 103 is from the online PDF manual and it looks like that is the actual page number in the paper manual).
merlin the wrench is offline   Reply With Quote
Old 05-08-2011, 01:13 AM   #10
Meril i will check this tomorrow...
Old 05-08-2011, 11:48 AM   #11
rtr
RL owner
rtr's Avatar
Why you take the batt off in the first place??
rtr is offline   Reply With Quote
Old 05-09-2011, 10:48 AM   #12
well battery was taken off b/c it wouldn't start so i took the batt to charge it at Autozone. But my surprise the battery was good. and the issue was that i had a 10w amp blown... so replaced it and bam it turned right on...
Old 05-09-2011, 10:56 AM   #13
meril...
the telescope settings are on...
Old 05-13-2011, 07:43 PM   #14
Damn nothing works so far. Will be going to the dealer.
Old 05-13-2011, 10:30 PM   #15
Registered Member
you did check the fuse for it - right?
Old 05-17-2011, 05:53 PM   #16
Exclamation Update!!!
Quote:
yes i did check the fuse. took the fuse out put it back in... did everything lol...
all in all the Motor was fried... so called my warranty and took it to the dealer and they will be replacing the unit tomorrow...
in the mean time i am pimping a MDX 2011... loving it...
Old 05-17-2011, 08:32 PM   #17
Registered Member
HEAVY_RL's Avatar
The motor was fried? That the first I have heard of that.
Thank goodness for extended warranty.
Old 05-18-2011, 12:29 PM   #18
rtr
RL owner
rtr's Avatar
Yea I was thinking that a few weeks ago so I set my wheel not to move and its not bad. If you do a lot of stop and go driving its better for its motor
Thread Thread Starter Forum Replies Last Post
CLOSED: 2G TL Going Back To Stock Sale james357 Car Parts for Sale 19 02-13-2016 03:37 PM
Quality Control Issues for the 2016 ILX SpraykwoN Acura ILX Discussion 13 09-11-2015 09:45 PM
Vibration in cabin when stopped thisisnotdave 4G TL Problems & Fixes 2 09-08-2015 11:02 AM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
FS: Acura OEM Leather Steering Wheel. MyKids&Cars Car Parts for Sale 0 09-02-2015 01:03 AM
Tags
acura, adjust, anymore, motor, rl, steering, telescopic, telescoping, tilt, tsx, weak, wheel, wheels, wont, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
