Rear Tag/License Plate Mounting
Old 11-10-2016, 02:21 PM
BluNosr2's Avatar
This drove me nuts with my 06 and continues to drive me nuts with my 2012...what screws/bolts are made that actually are the right size to properly attach the rear plate at the BOTTOM, so you don't get that annoying rattle/"slap" sound when closing the trunk? Local dealer here had nothing and only ever uses the top bolts to mount the plate, which yields the slap/rattle.
Old 11-10-2016, 02:23 PM
Received 16,260 Likes on 11,971 Posts
use the same bolts as the top! to secure the bottom!
Old 11-10-2016, 02:36 PM
BluNosr2's Avatar
Doesn't work - they are too long and the bolt hole fittings mounted to the trunk lid at the bottom have a center "hole" in each that doesn't even appear to be threaded (they are almost more like plastic spacers on each side where the lower bolts should go, between the trunk lid and the plate).
Received 8,575 Likes on 6,626 Posts
Got pics?
Old 11-10-2016, 02:40 PM
understood now.
I would find, maybe adhesive rather than a bolt.
you could probably line the whole backside of the plate with 3M double sided tape(or any other automotive double sided tape) and just stick it on.
and since the top is bolted, there's NO chance of the adhesive coming off.
that would solve the rattle
Old 11-10-2016, 02:55 PM
HEAVY_RL's Avatar
Received 1,037 Likes on 843 Posts
3m tape or a strip of foam... stereo shops have been using it for years.
The following 2 users liked this post by HEAVY_RL:
BluNosr2 (11-10-2016), projektvertx (11-10-2016)
Old 11-10-2016, 05:02 PM
BluNosr2's Avatar
Yeah double sided 3M just on each of the bolt "spacers" or whatever might do the trick. Can't go too crazy with it as the plate/tag stays me if the car is ever sold or traded LOL
Old 11-11-2016, 06:55 AM
butt butt 3m tape is removable!
I would line the whole plate!
Old 11-11-2016, 06:56 AM
and I hate you Heavy.
I came up with the Adhesive thought, First.....BUT You get the thanks....
whatever, I'll just ban you.
HEAVY_RL (11-14-2016)
Old 11-11-2016, 08:21 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
I slapped a square of Dynamat on the back of my plate since my two 12" subs took the rattle to a whole new level.
Old 11-14-2016, 09:55 AM
HEAVY_RL's Avatar
bring it in crab man.
:gheyhug:
03-27-2024 01:43 PM
00TL-P3.2
02-11-2019 11:23 AM
rockstar143
03-27-2016 07:41 AM
peterjedi
03-24-2016 08:53 AM
wmahmud
01-23-2016 03:08 PM
Quick Reply: Rear Tag/License Plate Mounting
