OBD Bluetooth Adapter
Torque limited? It looks to have quite a bit of features from reading the description/looking at screenshots.
~t.s.
- View live OBD engine data on your Android phone - Connect to your vehicle ECU
- Fully customisable dashboard screens - Design your own layouts and custom dials, use your own themes
- Retrieve Fault Codes (DTCs) and clear Check Engine lights - View fault descriptions using the built-in databases
- Upload live OBD2 data to your webserver or the torque web viewer in realtime
- Check the performance of your vehicle with BHP / Torque / 0-60 & Quarter Mile widgets
- MPG
- Coolant temp
- Fuel flow
- RPM
- etc
~t.s.
I've used Garmin's EcoRoute. It's the same thing.
Very cool little device. I was able to read anything the car monitors, see CELs, clear CELs, monitor fuel economy, see how many Gs I could pull through a corner, you name it. The only downside is that the app only works for Android phones, so if you have an iPhone, you're out of luck.
To add: it was extremely accurate with everything it read, so far as I could tell.
Torque Pro is extremely powerful and displays a lot of information, depending if your car is capable of displaying it. However, the UI is a little dated. It does work with those cheap $15 Chinese OBDII readers you find on Amazon.
YungMoola15
06-27-2016 12:09 AM
blackonblack2
04-10-2016 10:16 AM
mossman77
04-09-2016 04:46 PM
MM658
03-01-2016 09:58 PM
