Harmonic Balancer Pulley Issues
Old 04-24-2012, 05:51 PM
2005 RL with over 200k KM
nralpmet's Avatar
My wife and I are in Florida from Canada when the harmonic balancer rubber on my 2005 (with just under 100k miles) apparently disintegrated. Had to have it towed from Ft Myers to Naples Acura. Looks like the rubber on the pulley fell apart. The service guys said they maybe see one of this type of issue a year.
Anyone else come across this? Is this indicative of an underlying issue?
Thx.
Old 04-24-2012, 09:40 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
news to me.
any pics?
Old 04-25-2012, 01:02 AM
253RL's Avatar
Looks like you my friend now have the perfect excuse to upgrade to the unorthodox racing lightweight stock diameter pulley!
HEAVY_RL (04-25-2012)
Old 04-25-2012, 08:01 AM
EL19's Avatar
To my knowledge the J series engine is internally balanced. I am unaware of rubber on the stock pulley. I'm going to take alook at mine when I get to my car (its on my backseat floor)
Old 04-26-2012, 08:33 AM
EL19's Avatar
As I thought theres no rubber on the crank pulley as the crank shaft is internally balanced (no harmonic dampener/balancer). So you must be talking about another pulley. Which pulley are you talking about?
oo7spy (04-26-2012)
Old 04-26-2012, 09:11 AM
HEAVY_RL's Avatar
Pics?
Old 04-26-2012, 12:47 PM
typeR's Avatar
there is on mine
see pic
http://public.fotki.com/typeR/typer/picture_058.html
Old 04-26-2012, 01:23 PM
EL19's Avatar
Not sure whats rubber and what's just dirt? I'll take a look at mine again or take a picture
Old 04-26-2012, 01:25 PM
brinox's Avatar
im not exactly a gearhead, but im decently knowledgeable with regards to cars/engines/etc, and I thought the same thing more or less
Old 04-26-2012, 01:52 PM
typeR's Avatar
im no expert either but im pretty sure that needle and thread isnt stuck in dirt and even slightly more sure its not stuck in cast iron
Old 04-26-2012, 03:24 PM
EL19's Avatar
Its magnetic what car is that from?
Old 04-26-2012, 05:37 PM
typeR's Avatar
J35A4 swap into my '01 CL type S see sig
Old 04-27-2012, 07:02 AM
EL19's Avatar
Nice youve had that setup for years, back when I had my TLS. Glad to see its still running strong! Took another look at my crank pulley and there is a healthy bead of rubber where you have the needle sticking out of. Not sure how thatd disintergrate or what effect it'd have.
Old 04-27-2012, 07:39 PM
nralpmet's Avatar
Sorry, was enroute back to Canada.
No pics and not a tech-head, but from my receipt:
"Technician observed harmonic balancer has separated and the accessory belt was sheared off"
Old 10-26-2014, 03:55 PM
3rd Gear
rdhaliw's Avatar
I have a similar "scare" of mine to show you. It started out with a Knocking sound coming from around the Serpentine Belt area of my 2005 Acura TL. This knocking sound would only be there when the car was in idle or low RPM...
then a few months later, I was driving home and heard a thump noise, and suddenly the Knocking sound went away... I am/was happy... did'nt know why, but no longer the knocking sound when I started the TL or in/near idle (RPM around 1000)...
then came the squealing belt noise... and burn smell in the car. This has been happening for about a week now and finally I had the chance to pop the hood and look inside.
Wait till I upload some pictures of what I found inside the hood!!!...
Old 10-27-2014, 12:04 PM
HEAVY_RL's Avatar
This isnt the TL forum, but I am anxious awaiting these pics.
Old 10-27-2014, 12:08 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
I hate teasers.
Old 10-28-2014, 10:20 AM
velobard's Avatar
I did that on the Chrysler I owned before my RL. When I found one that fit, it made sense to me to give it a try when I had the timing belt done. Hard to slam a decent performance mod for only a little over $100. I can't think of any downsides other than having to keep track of odd belt sizes for future changes.
ETA: On second thought, I'd want to investigate it a little more before putting one on the RL considering how sensitive the electronics are on these cars. With my old car there was no problem, but it does reduce alternator pulley speed somewhat.
Old 10-28-2014, 10:26 AM
Received 16,260 Likes on 11,971 Posts
^if using the stock diameter pulley, you wont need to keep track of odd sized belts, as it uses the stock belt
Old 10-28-2014, 10:32 AM
velobard's Avatar
Doh! Somehow I missed that it said "stock diameter". My old one was a lightweight underdrive pulley. Carry on.
justnspace (10-28-2014)
Old 10-28-2014, 10:45 AM
^no worries!
Old 10-28-2014, 11:47 AM
I Drive Like A Dick 8≈
Nersh7's Avatar
I'm going to go ahead and say this guy is a troll...
I'll take it back when he posts these pictures.
Old 10-30-2014, 02:35 PM
HEAVY_RL's Avatar
been here since 2013... never know.
Old 10-30-2014, 02:53 PM
Nersh7's Avatar
And that was his first post...
Old 10-30-2014, 03:13 PM
flexer's Avatar
I have the engine out on my 05 acura RL with 53k and there is rubber on the pulley and it is pretty cracked on mine.
Old 11-10-2014, 08:00 PM
TomHuz's Avatar
Happened to me. The pulley came unglued to the balancer and fell off. Didn't hurt anything put a new one on and good to go!
Old 11-11-2014, 02:55 PM
Blues Legend's Avatar
Thx.
This is a common Honda phenomenon. NSXs, too..
The harmonic balancer should always be replaced when changing the timing belt. Along with the water pump & tensioner.
It seems they are fine until a hub puller is used on them to get them off the nose of the crank, and failure can occur rapidly thereafter.
And no, it's not a service item. Though it ought to be... if it munches its way into your timing belt through the casing, it's goodnight J. Or C...
Old 11-28-2014, 08:00 PM
dapqam's Avatar
Interesting post. I changed the timing belt myself (along with all other recommended parts), but did not change the pulley. This was the one that was nearly impossible to get off. I have put 15K on the car since with no problems.
Old 12-03-2014, 03:15 PM
They're on famously tight and you need a tool and a hugely-long breaker bar to crack the nut.
Like the little Dutch boy, I'd poke your finger in there now & again, just to make sure it's still OK.
Old 12-23-2014, 01:14 PM
3rd Gear
rdhaliw's Avatar
not a troll... just took a bit longer to get the pictures and update
Picture 1 of 3:
... the loud thump I heard was the outer ring jumping off the pulley... the belt moved down to the inner pulley... ... see groves on the next picture.
Picture 2 of 3:
... see the groves on the inner pulley. this is where the belt landed. I was driving the TL for another few weeks like this.
Picture 3 of 3:
both the groves on the belt and the outer side of the belt damaged. Replaced both the harmonic balancer and the belt. she now purrrs; and I am happy.
oo7spy (12-23-2014)
Old 12-23-2014, 06:27 PM
oo7spy's Avatar
Pay up or get .
Old 12-24-2014, 07:21 AM
Mind you, some of the stories here about people Darwiningly ignoring serious symptoms for so long are worryingly common.
I'm sure the US must be like the silent movies, where Tin Lizzies would spontaneously collapse all over the place!
Old 12-24-2014, 08:11 AM
3rd Gear
rdhaliw's Avatar
... just counting my blessings... it is by pure luck that the belt landed on the inner pulley, while the outer ring dislodged and was laying alongside.
Blues Legend... your point well taken. do not recommend anyone letting this type of a situation and still drive. My previous commentary is more a Root Cause Aanalysis
Old 12-24-2014, 09:47 AM
Former Sponsor
ExcelerateRep's Avatar
We offer our XLR8 stock diameter crank pulley now that is actually made by Unorthodox Racing for us, and is CNC machined and 0 gram balanced.
XLR8 Aluminum Pulleys - Excelerate Performance - Japanese and European Performance Specialists!!
Old 12-29-2014, 11:41 AM
flexer's Avatar
No dampener on that pulley though. I wonder if the loss of the dampener could cause problems at higher rpm on the crank?
02-25-2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
mrkingstonvi
02-22-2016 01:53 PM
njresendez
09-21-2015 11:23 AM
iCrap
09-11-2015 06:21 PM
Quick Reply: Harmonic Balancer Pulley Issues
