Gates Racing timing belt kit or Acura OEM kit??
about to get timing belt and water pump replaced, have a 2005 RL with 171k on it, should i go oem or gates racing? im leaning towards the gates....they are both around the same price 240-300
If the price is even remotely close, why not OEM?
Only cuz on the description it says the Gates belt is 300% stronger than OEM (i doubt it)...but I've read some reviews that say Gates water pump is not good....so definitely just going to buy the OEM kit, Aisin.....also, can anyone tell me what else i should replace if i dont have any service records of the car.....when i searched the forums timing belt and water pump were a big thing, anything else? Planning on keeping car for a long time
Tensioner pulley too.
Also, you should replace your radiator cap every 7 years. It may sound silly, but it's a $7 part that your entire aluminum head relies on.
With today's timing belt compounds, they are meant to last!
there is no reason to not trust Gates! as it is a reputable brand.
I chose the gates kit because it was significantly cheaper.
you can find the OEM timing belt kit and the gates kit at Rockauto.com for WAAAAAAAAAAAAAAY cheaper than you can find it anywhere else.
These kits from rockauto.com COME with everything you need. Pulleys, water pump, belt, etc.
when I did my timing belt and water pump on my 2005 RL, I went with OEM on everything..
the most expensive part is the labour and the parts are minor.
but I am reasonable sure that Gates is pretty good too.
Zonian22
11-14-2015 01:20 PM
merc009
10-03-2015 12:59 AM
Zonian22
09-02-2015 08:19 AM
