Cooling Fans backwards or losing mind?
Old 05-16-2021, 11:26 AM
JFRENSH's Avatar
While replacing failed radiator cooling fan failure.......Per Acura drawing 5 blade fan, counter clockwise, plastic shroud is on Driver side. 7 blade fan, clockwise rotation, steel shroud is on Passenger side. Existing threads state fan on passenger side is AC condenser and driver side is radiator cooling. Correct?
I'm asking please because my fans are operating Opposite as expected: in that upon start, AC Off, 7 blade fan on passenger side is operating. Turn on AC, 5 blade fan on driver side comes on. Is this backwards?
Control module appears clean and relatively new. Each fan is plugged into the module to the connector closest to each fan - they are not crossed. Size of plugs on fan appear to match the connections exactly on module - in that plugs could be cross connected if needed but why would you?
Can a member please confirm correct location of condenser and radiator fan. And are my fans reversed...or am I losing my mind? Thanks!?
Old 05-18-2021, 05:33 PM
GaRaS's Avatar
i check mine. Outside temp is 75F , engine is at normal operating temp. AC ON, both fans are running. AC off, fan not running but both fans turns on and off from time to time. Maybe others will chime in. Not sure why one fan doesnt comes on mine.
Old 05-18-2021, 08:26 PM
JFRENSH's Avatar
Thank you
Thanks for the reply.
malnik
07-05-2015 07:12 PM
eneffex
2G CL Problems & Fixes
09-07-2011 08:54 PM
AmeliaRose
08-30-2011 05:11 PM
min1982
1G CL Problems & Fixes
08-27-2011 04:59 PM
hdp203
07-25-2007 08:03 PM
Quick Reply: Cooling Fans backwards or losing mind?
