B16 service price
B16 service price
Well, my RL is telling me that a B16 service is due soon (15% oil life left).
I'm in Reno, but travel back to the Bay Area frequently (I leave the transmission in "manual" all the way through the mountains from Reno to Sacramento). The dealer I bought the car from, Los Gatos Acura, provides good service in my experience but their quote for the B16 service seems high. According to my manual, this service is:
1. Change engine oil
2. Change rear differential oil
3. Rotate tires
4. Visually inspect a number of items
The total for the service is about $225. Changing the rear differential oil alone is quoted at $75, whereas a local lube place will do it for exactly 1/3 the cost.
I figure I can save $150 or so by having the local oil place do the engine and differential, and rotating the tires and performing the visual inspection myself.
Does this seem reasonable? In other words, is the price quote from Los Gatos as high as I think it is?
3. Rotate tires
If you go to a quick lube place for the differential service, buy the correct fluid from the dealership. Do NOT use any aftermarket fluid for the differential.
I know Niello charges about $175 for Service B alone...
My "Service B" warning just came on today! I am in the Bay area also and Stevens Creek Acura said the service would be 149 or 165 with mobile1 oil. I didn't ask about the rear differential. Is that needed with 15k miles?
* Official Acura power steeting fluid
* Official Acura brake fluid
* Official Acura engine oil
OK, I'm kidding on the last, but I get the feeling they would have done it if they'd thought they could get away with it. For example, if you have to replace the brake fluid and the Official Acura Brake Fluid isn't available, you can use any DOT-4 fluid, but you should flush it out and refill with Acura brake fluid as soon as possible!
Brake fluid, don't worry about. Use any DOT3 compliant and you'll be fine.
As for Power Steering, there are components in a Honda power steering system that require the friction modifiers and "different" overall build of a Honda Power Steering Fluid, so use the genuine product or the aftermarket equivalent. Given the infrequency of servicing the power steering fluid, cough it up and use the real stuff, as any incompatibilities you'll experience will appear in the long run, and the cost difference, if any, isn't worth it.
Automatic transmissions. Use the genuine product or Amsoil ATF. Honda units do have clutch materials which will react to the friction modifiers present in the correct fluid to deliver smooth shifts. Amsoil ATF has worked well in Honda units for those who have used it and is backed by Amsoil.
For the differential, just use the genuine fluid. It's not worth experimenting imo.
Originally Posted by dramsey
Well, my RL is telling me that a B16 service is due soon (15% oil life left)......
Originally Posted by jkuniverse
dramsey, I just got the A16 service showing on my RL yesterday at 11900 miles. I believe the A16 service is pretty much the same as the B16 except B16 involves more checking of fluids etc...) Anyway, I've decided to leave this one to the pros due to some extra work involved with changing the diffential fluid etc. I've read some folks on this forum DYI the fluid change, some confusion about what fluid to use etc... It might be worth doing it yourself to save $150 but I've checked 3 dealerships nearby and the price quoted ranged from $145 - $215. I just made an appoint with the dealer (stealer ) who will do it for $145 which I think is pretty reasonable. Wish you the best.
I wound up having a change service do the engine and diff oil; I'll rotate the tires myseld and inspect this weekend (I used to work on cars a lot more, back when that was possible...) Total expenditure, not counting my time: $60
.....I wound up having a change service do the engine and diff oil; I'll rotate the tires myseld and inspect this weekend (I used to work on cars a lot more, back when that was possible...) Total expenditure, not counting my time: $60
There's a nice lube place out here called "Safe Lube"; you drive the car over the pit and stay in the car while they do the work, which you can watch on TV monitors. The manual says, as I recall, 0.7 quarts of ATF fluid for the rear diff.
differential fluid
dramsey, thanks for the information...I think that's a good idea. Did you have a place like Jiffy Lube do the change for you?...with your supplied Honda AFT...How many quarts? Thanks.
3. Rotate tires
3. Rotate tires
Today, I had an A16 done at a Honda dealer in Mississippi...abut 47,000 miles. I'm looking at the ticket and see that they went ahead and replaced the oil filter, which would make it a B16. The total price, including taxes, was $126.38. The price charged for the ATF was 33.50 and labor was 38.00.
Out of curiousity, what is your mileage?
Originally Posted by Scottn
How do you turn off the service reminder after you do your own service?
Bringing this thread back from the dead instead of starting my own B16 service thread.
My B16 light came on last week at 12650 miles. I'm at the dealer right now and their quote for the service is $270. Just adding my price as a data point.
My A16 reminder popped up on the way to work this morning. I called a local (near work) dealer and was quoted $153 (oil change, rotate/balance, differential fluid). I called my dealer who quoted $161, without the tire balance. When I told him what the other dealer was offering, he met the price, including the balancing stating "I don't know how they do it."
LL
LL
LL
LL
Sheez: I paid $94 which included synthetic oil (Mobile1) tire rotation and the dealer let me use an RDX for about 4 hours and a 100 miles. Now my B16 service light has about 10% left. I'm wondering what the charge will be for this.
Torch & Pitchfork Posse
Just got my B16 service today with some additional items.
B16 service
Balance 4 wheels
4 Wheel Alignment
New Wiper Blades
Car Wash
Use of a RDX for the day (my choice - only model I have not driven)
Starbucks, donuts and a jelly bean refill.
$193.23
I did not check the manual, but I do not belive the wheel balance and alignment are included in the B16 service, so that seems like a good price.
The RDX was a hoot! I was very impressed with the handling, if not the very busy and choppy ride. The road noise and tire roar was horrible. VAC would not work well in this cabin. Mileage was 16.3 in a 50/50 driving day. For that kinda mileage the MDX I had last call was so much more vehicle for slightly better mpg.
I was soooooo glad to be back in my silent RL, smooth and serene, effortless speed and unfluttered handling.
B16 service
Balance 4 wheels
4 Wheel Alignment
New Wiper Blades
Car Wash
$193.23
B16 for 2008 RL
I called the dealer I got it from and they wanted $325 for B16 service.
Didn't seem fair for mere fluid changes. I called up the one 40 miles away and it was $267. Still high but I made the appt. Still under warranty so I don't want to jeopardize that.
I know I could shop it further, but you know what? There aren't a lot of dealers here. Nearest one is nearly 20 miles.
Is this going to happen every 10k miles? Car runs perfectly.
Scott
Scott
Fun update from 2009!
Just took my 2006 RL in to Acura of Reno for the B12 service. They called back and said since the car had 61,000 miles on it, it should have the "60,000 mile service". This apparently involves checking brakes, changing differential fluid and whatnot and costs a heart-stopping (I asked them repeat it) $950!
They're trying to convince me that this is an Acura-recommended 60K service, even though I'm pretty sure that the Maintenance Minder is what you're supposed to pay attention to. They're also saying Acura recommends differential fluid changes every 15K miles, which I'm pretty sure is balderdash.
Comments?
Comments?
Why does rear differntial fluid have to be changed at 13k miles? Doesn't it basically last as long as transmission fluid, about 60 k miles or 5 years???
BTW, meineke will change your differential fluid for $69, you can give them the fluid if you want. It's not rocket science.
The fluid is about $8 a quart (from honda dealer) and you need 4.
You can DIY VERY EASILY.
Get 2 crush washer for the drain if you are worried about a leak. (they are like $2 ea but can be reused often)
Drain
Fill
I used 4 ft pc of 3/8 rubber hose,
Jammed it on the nozzle of an old gear lube bottle and cut off the bottom. Put it in fill hole, ran hose up to drivers rear tire area, held higher than the Diff and filled til full.
Drain
Fill
Thread revival.
Just paid $294 for a B16 service at 39K because my wife wants to take the car on an all girls trip this weekend.
The inspection came out with
Brakes FR 6/32"; RR 6/32"
Tires FR 7/32"; RR 6/32"
Battery Load Test: Failed; Battery Replaced under Warranty; customer to pay $14.84 in environmental disposal fees
Steering Wheel buttons: Coating failed; Replaced under warranty
So now my wife will be off on her weekend away, and not complaining about the warning lights for B16 service. She will be complaining about how loud the 5zigen exhaust is, however.
Thread revival.
almost 300 for the b16 service?
noway, what else did they do?
I took mine in for her b16 service a few weeks ago, i paid $189 at the acura dealer,
$270 from Acura of Sunnyvale... as an FYI for Bay Area, CA folks.
I'm doing this myself since I did the A16 service at 15k myself. I am currently at 40k miles.
