Acura RL Center Console arm rest replacement all colors
Old 06-26-2012, 10:25 AM
russianintrigue's Avatar
This is where I purchased my replacement automotive vinyl center console arm rest cover. You can have it professionally installed by anyone who does this type of work. Or you can try it yourself, it comes with instructions. I can't tell the difference from OEM.
http://www.ebay.com/itm/200712853716...ht_1459wt_1144
Old 06-26-2012, 10:27 AM
EL19's Avatar
Good find, although I don't see that they offer black. Mine has just started to bubble. I'm going to contact them to see if they have black
EDIT: NVM found it in black
Old 06-26-2012, 10:38 AM
Chapter Leader (Chicago)
RL Chi-town's Avatar
I think this is an awesome fine... love it...
Old 06-26-2012, 10:40 AM
I removed the old damaged vinyl material myself (one of the first hands-on tasks I have done on my car) by literally pulling it away from the material bellow it. It's lightly glued on and will come off completely clean.
I am trying to find a drivers-side replacement leather armrest now.
Old 06-26-2012, 10:47 AM
IanVS's Avatar
Isn't the OEM door armrest made of some kind of rubber or something? Doesn't seem like vinyl or leather.
Old 06-26-2012, 10:58 AM
It looks like leather but it's probably some leatherette-like material. Regardless of what the material is, I don't like the fact that it's getting all stretched out and looks very unkept at this point. I have been able to find entire door inserts on Ebay, just looking to find the right match (grey colored, drivers door). It appears you have to replace the entire door panel.
Old 06-26-2012, 11:24 AM
IanVS's Avatar
You can take the armrest piece off (I've done it, have some instructions for doing it if you need them). OEM part is $63.27 at oemacuraparts.com: http://www.oemacuraparts.com/product...a-a03zb-acura/
russianintrigue (06-26-2012)
Old 06-26-2012, 11:32 AM
Thank you, I will have to purchase the driver side armrest then. Is it difficult to take it off and replace?
Old 06-26-2012, 11:37 AM
IanVS's Avatar
It's not too hard, no. I did it by myself, but it would have been nice to have a second person there to help support the door while I fiddled with disconnecting and reconnecting the plugs. I posted instructions at: https://acurazine.com/forums/showpos...97&postcount=2
Old 06-26-2012, 11:42 AM
Thank you, I'll have to convert the .doc file to pdf since the visuals aren't coming up on my mac. It opens in word 08.
Old 06-26-2012, 11:55 AM
IanVS's Avatar
Attached a pdf version. Hopefully that works better for you.
File Type: pdf
Old 06-26-2012, 12:05 PM
Gracias....
Old 06-26-2012, 12:46 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
The driver's door armrest is leather.
The center console armrests are pleather.
I have replaced both when the car was under warranty. The dealer replaced the door armrest and the entire upper console (the folding armrests cannot be purchased seperately).
But then my center console armrest bubbled again. It is not seperating from the foam padding as you would think, but instead the vinyl skin delaminates from the fabric substrate.
So I had a local upholsterer recover the console armrests in real leather (with stitching as is OEM). It has supassed both previous OEM replacements.
There are threads about this going back as far as 2007.
https://acurazine.com/forums/showthr...ht=upholsterer
https://acurazine.com/forums/showthr...onsole+armrest
The following 3 users liked this post by TampaRLX-SH:
HEAVY_RL (06-26-2012), IanVS (06-27-2012), russianintrigue (06-26-2012)
Old 06-26-2012, 01:01 PM
I wish I would have seen this earlier. I mentioned the armrest to my dealer several times when it was under warranty, aside from it being obviously torn up at the time. I was told it was not under warranty every time..... Ugh......
Old 06-27-2012, 01:31 AM
253RL's Avatar
Any test subjects who would send their drivers arm rest piece to this eBay vendor if possible? I'd def be on the bandwagon to purchase one as I have heavy elbows too. Will be installing my new eBay armrest covers this weekend.. Hopefully.. Having him make a template like the console should be cake.. I'd think ?
Old 07-06-2012, 02:24 PM
blaser's Avatar
Guys
Anyone has instructions on how to remove the center armrest?
Mine started to bubble and I would like to remove it and take it to an automotive upholstery for replacement, it shouldn't be so expensive, I will post pictures after and price
Old 07-06-2012, 04:39 PM
Originally Posted by blaser
Guys
It's very easy, remove the stickers that are under the round black feet. There are screw holes behind them. Take the plastic cover off the handle and there are screw holes behind them. Make sure you take a picture of the hole position and the screw position underneath the first series of screws as it can be a little tricky if you have never done it before. Don't over think it, I am not handy at all and it took me several minutes to take it apart and to assemble it as well.
Old 07-07-2012, 03:53 PM
forcemac101's Avatar
Guys
I just did mine this week. Like everyone says its pretty easy, just remove those rubber/sticker covers ocer the holes. Remove three screws, then take small screw driver to pop off the plastic cover up by latch...there are two ore screws there. Then seperate and rotate the plastic under side of the arm rest. There are four more screws that hold a metal plate to the armrest hinges. Unscrew those and the top leatherette armrest is free. Take it to your shop.
When putting back together, reatching th metal plate, armrest and hinges is tricky, becuase of play in the hinges and in the screw holes. I what i did was to insert the 3 screws that were i itally hidden under the rubber/stickers to hold the plate to the new armrest, while i jimmy'd the hinge screws in. They didn't want to go back in straight for me as the metal plate and hinges didnlt align easily...
blaser (07-09-2012)
Old 07-07-2012, 04:45 PM
blaser's Avatar
Thanks, it was easy
Old 11-19-2012, 01:20 AM
Toppatop's Avatar
I just rewrapped my center console armrest in leather and it looks beautiful. Better than when the VCR was brand new. I used the eBay vendor sent it in overnight Monday received back Friday. Total cost including shipping $100. $30 for leather cover $40 for labor and $20 for shipping. I must say I am very impressed. This is the link to the one I used.
http://item.mobileweb.ebay.com/viewi...d=170906226845
Old 11-19-2012, 01:44 AM
Toppatop's Avatar
http://pho.to/AnAE
Old 11-20-2012, 07:38 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Old 01-21-2013, 11:10 PM
zip5famu's Avatar
Thumbs up Need help
Will you send me the instructions?
Old 01-21-2013, 11:13 PM
zip5famu's Avatar
Removing lids
Will you send me instructions on how to remove lids?
Old 01-27-2013, 09:22 PM
Tony Torque's Avatar
Need to do this to my driver side door armrest!
Old 01-27-2013, 09:29 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
most of us do
Old 01-27-2013, 09:56 PM
oo7spy's Avatar
1 bubble!
Old 04-08-2013, 06:28 PM
HybridCB7's Avatar
Hey Guys. New Member here. Just recently picked up an 05 in Silver.
After looking at both links which one would you guys recommend? One claims to be real leather and the other says it is vinyl
http://www.ebay.com/itm/170904504197...84.m1423.l2649
http://www.ebay.com/itm/200599128430...84.m1423.l2649
I'm leaning towards the vinyl for the simple fact that it is cheaper and comes with directions. Just want to get insight from fellow members before pulling the trigger. Has anybody on here bought either? What are your opinions on them?
Old 05-09-2013, 08:20 AM
HybridCB7's Avatar
Just wanted to update people if anybody was interested....
I bought the replacement lids and sent out my old lids to the ebay vendor.
Long story short, they came out terrible. I would have been better off just keeping my lids as is.
The new lid covers are still quite loose and not much excess leather was removed so now it does not fit nearly as snug as the OEM lids did. I am in the process of reaching out to the vendor to find out a solution to this, we will see.
I want to hear what he has to say. I may try to salvage the lids myself but if not I may just have to bite the bullet and have an actual professional refinish these for me as what I have right now looks nothing like I was expecting(They weren't that high to begin with...)
Old 05-09-2013, 10:13 AM
BDoggPrelude's Avatar
I think the best solution for this is to just contact a local auto upholstery shop to recover the armrest for you. I had mine done by a guy in my area for $90. Looks great and came with a 2 year warranty. Have them add some extra padding to the armrest while you're at it, your elbow will thank you for it.
HEAVY_RL (05-09-2013)
Old 05-09-2013, 01:55 PM
phishfood's Avatar
Picture?
Old 05-09-2013, 02:13 PM
Color match is perfect. The guy actually sourced some lambskin leather because it is thinner. I think the reason Acura chose the pleather to begin with is because of the tight tolerances on the underside of the armrest. He was unsure that the thicker cowhide leather would fold under correctly without showing a bunch of folds on the outside.
The following 5 users liked this post by BDoggPrelude:
HEAVY_RL (05-09-2013), kcjohnnyboy (08-15-2014), minla007 (05-09-2013), oo7spy (05-10-2013), Türk (04-30-2014)
Old 05-10-2013, 09:00 AM
phishfood's Avatar
Picture?
Old 06-05-2013, 10:31 AM
jose3031's Avatar
Mine has started to bubble
Old 06-05-2013, 10:33 AM
HybridCB7's Avatar
Originally Posted by phishfood
Picture?
Never took pictures. It came out terrible. In defense of the ebay seller. He was good with communicating and gave me a partial refund.
Old 06-05-2013, 10:35 AM
HybridCB7's Avatar
Should have done this from the very beginning
My locak guy charged me $70 and it looks EXACTLY like OEM. Such a good job.
Old 06-07-2013, 12:27 PM
StReCh4130's Avatar
At first glance, I thought the ebay route was my best bet, but I guess I will be searching for someone to re-do my upholster my armrest in the NYC Tristate area.
If anyone has any suggestions I'm all ears.
Old 06-07-2013, 12:31 PM
HybridCB7's Avatar
Definitely try and shop around in your area first. And if you do physically go to these people and show them the arm rests as they will give you different quotes assuming it will be much harder than it really is.
Old 06-09-2013, 07:36 PM
HEAVY_RL's Avatar
If you do not go to an upholstery shop or a stereo shop and get them covered then there will be no sympathy.
Old 10-03-2013, 02:55 PM
3rd Gear
Lobo160's Avatar
How do I send the items to them to be recovered? I don't see any address or call info on their we-page?
Quick Reply: Acura RL Center Console arm rest replacement all colors
