2016 Acura RDX Technical Service Bulletins
Old 04-03-2015, 07:56 AM
Forum Contributor
EE4Life's Avatar
Received 1,391 Likes on 643 Posts
2016 Acura RDX Technical Service Bulletins:
TSB 15-019 - 2016 RDX: TQI and New Model Service Information
Applies To: 2016 RDX - All
http://www.urvi.net/forumfiles/SB/B15-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-019.PDF
TSB 15-020 - 2016 RDX: TQI of the Navigation System
Applies To: 2016 RDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B15-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-020.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2016-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2013–16 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane
Applies To: 2016 RDX - Advance, All with AcuraWatch Plus - ALL
http://www.urvi.net/forumfiles/SB/B15-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-027.PDF
TSB 15-051 - HFL Poor Sound Quality or Static
http://www.urvi.net/forumfiles/SB/B15-051.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-051.PDF
TSB 16-002 - Front Brake Noise and/or Front Brake Judder
This bulletin is replaced by S/B 17-049, Front Brake Noise and/or Front Brake Judder (2013–18 RDX).
Applies To: 2013-15 RDX - ALL - ALL
2016 RDX - 2WD - From VIN 5J8TB3...GL000001 thru 5J8TB3...GL012358
2016 RDX - AWD - From VIN 5J8TB4...GL000001 thru 5J8TB4...GL019272
http://www.urvi.net/forumfiles/SB/B16-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-002.PDF
TSB 16-015 - Audio Unit Displays Wrong, Blank, or Random Character Presets
Applies To: 2016 RDX - With Navigation - ALL
http://www.urvi.net/forumfiles/SB/B16-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-015.PDF
TSB 16-025 - Steering Wheel Noise When Driving
Applies To: 2016-17 RDX - 2WD - From VIN 5J8TB3...HL000001 to 5J8TB3...HL003353
2016-17 RDX - AWD - From VIN 5J8TB4...HL000001 to 5J8TB4...HL005430
http://www.urvi.net/forumfiles/SB/B16-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-025.PDF
TSB 16-043 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch
Applies To: 2013-17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-043.PDF
TSB 16-059 - Pop or Clunk from the Rear Suspension in Cold Weather
Applies To: 2013-16 RDX - ALL - ALL
2017 RDX - All 2WD - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL009835
2017 RDX - All 4WD - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL015307
http://www.urvi.net/forumfiles/SB/B16-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-059.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2016 RDX - Tech/Adv - ALL
2017 RDX - 2WD Tech/Adv - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL006065
2017 RDX - AWD Tech/Adv - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL009274
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-004 - Safety Recall: 2015–16 ILX and RDX Takata Driver’s Airbag Inflator
Applies To: 2015–16 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-004.PDF
TSB 17-016 - Front Brake Noise (2016–17 RDX)
This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder.
http://www.urvi.net/forumfiles/SB/B17-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-016.PDF
TSB 17-017 - 2013-17 RDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2013–17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-017.PDF
TSB 17-018 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B17-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-018.PDF
TSB 17-049 - Brake Judder (2013–18 RDX)
This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX).
http://www.urvi.net/forumfiles/SB/B17-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF
TSB 18-021 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2016 ILX and 2016 RDX (Expires February 28, 2026)
Applies To: 2016 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-021.PDF
TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030)
Applies To: 2016-17 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF
TSB 19-009 - Front Brake Noise and/or Front Brake Judder
This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (2013–18 RDX).
Applies To: 2013-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
Applies To: 2007-16 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2007-18 RDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-003 - A/C Compressor Stator Inspection
Applies To: 2016 RDX - 2WD - From VIN 5J8TB3....GL006186 thru 5J8TB3...GL008996
2016 RDX - AWD - From VIN 5J8TB4....GL007555 thru 5J8TB4...GL014320
http://www.urvi.net/forumfiles/SB/B20-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-003.PDF
TSB 20-038 - Steering Wheel Rattles
http://www.urvi.net/forumfiles/SB/B20-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-038.PDF
EE4Life is offline
The following 11 users liked this post by EE4Life:
5 Acuras (04-03-2015), Brown13 (06-28-2016), carbonTSEX (10-28-2016), Danny Boy (01-19-2016), EFItech (06-09-2015), giovane (05-23-2015), Harrison Chien (08-16-2016), NLRL (05-23-2015), Rocket_man (04-04-2015), WhiteLightning2 (12-14-2020), wsw (03-29-2019) and 6 others liked this post. (Show less...)
EE4Life
04-12-2024 11:42 AM
EE4Life
09-01-2023 11:05 AM
EE4Life
05-15-2017 06:12 PM
EE4Life
10-26-2016 10:10 PM
EE4Life
10-26-2016 08:13 PM
Quick Reply: 2016 Acura RDX Technical Service Bulletins
