2015 Acura RDX Technical Service Bulletins
Forum Contributor
Received 1,391 Likes
2015 Acura RDX Technical Service Bulletins:
TSB 14-008 - 2015 RDX: TQI Information
Applies To: 2015 RDX - 2WD (Base)
2015 RDX - 2WD with Technology Package
2015 RDX - AWD (Base)
2015 RDX - AWD with Technology Package
http://www.urvi.net/forumfiles/SB/B14-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-008.PDF
TSB 14-009 - 2015 RDX: TQI of the Navigation System
Applies To: 2015 RDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B14-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-009.PDF
TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction
Applies To: 2013-14 RDX - ALL - ALL
2015 RDX - 2WD - From VIN 5J8TB3...FL000001 thru 5J8TB3...FL006607
2015 RDX - AWD - From VIN 5J8TB4...FL000001 thru 5J8TB4...FL010639
http://www.urvi.net/forumfiles/SB/B14-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2007-15 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 14-053 - TIGHTEN FUEL CAP Message On or DTC P0455 and/or P0456 is Set
2015 RDX - ALL 2WD - From VIN 5J8TB3...FL000001 thru 5J8TB3...FL010016
2015 RDX - ALL AWD - From VIN 5J8TB4...FL000001 thru 5J8TB4...FL017148
http://www.urvi.net/forumfiles/SB/B14-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-053.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 201316 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-051 - HFL Poor Sound Quality or Static
http://www.urvi.net/forumfiles/SB/B15-051.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-051.PDF
TSB 16-002 - Front Brake Noise and/or Front Brake Judder
This bulletin is replaced by S/B 17-049, Front Brake Noise and/or Front Brake Judder (201318 RDX).
Applies To: 2013-15 RDX - ALL - ALL
2016 RDX - 2WD - From VIN 5J8TB3...GL000001 thru 5J8TB3...GL012358
2016 RDX - AWD - From VIN 5J8TB4...GL000001 thru 5J8TB4...GL019272
http://www.urvi.net/forumfiles/SB/B16-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-002.PDF
TSB 16-043 - 201317 RDX: Judder from the Torque Converter Lock-Up Clutch
Applies To: 2013-17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-043.PDF
TSB 16-059 - Pop or Clunk from the Rear Suspension in Cold Weather
Applies To: 2013-16 RDX - ALL - ALL
2017 RDX - All 2WD - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL009835
2017 RDX - All 4WD - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL015307
http://www.urvi.net/forumfiles/SB/B16-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-059.PDF
TSB 17-004 - Safety Recall: 201516 ILX and RDX Takata Drivers Airbag Inflator
Applies To: 201516 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-004.PDF
TSB 17-017 - 2013-17 RDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 201317 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-017.PDF
TSB 17-018 - 201317 RDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B17-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-018.PDF
TSB 17-049 - Brake Judder (201318 RDX)
This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder.
This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX).
http://www.urvi.net/forumfiles/SB/B17-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF
TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026)
Applies To: 2007-15 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF
TSB 18-028 - Warranty Extension: Customer Support Program For Front Passenger's Airbag Inflator for 2013-15 ILX and 2013-15 RDX (Expires June 30, 2030)
Applies To: 2013-15 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-028.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-028.PDF
TSB 19-009 - Front Brake Noise and/or Front Brake Judder
This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (201318 RDX).
Applies To: 2013-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
Applies To: 2007-16 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator
Applies To: 2015 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2007-18 RDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030)
http://www.urvi.net/forumfiles/SB/B20-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF
TSB 20-014 - Front Rocker Arm Oil Control Valve Leaks
http://www.urvi.net/forumfiles/SB/B20-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-014.PDF
