What is needed for a full tune up for my 2003 Acura CL-S?
Bought my 2003 Acura CL-S this past July. Havent tuned it up yet? I see These Acura's use no spark plug wires. So I need info on whats needed for a full Tune Up for my car. The whole shabang... Looking forward to hearing your input, thanks...
New to this Acura World. So any info is deeply appreciated..
This assumes no maint on car.
spark plugs at 120K miles
Air filter when dirty
engine oil depending upon mileage and driving conditions
change coolant if it is green, it's too old as Acura is using blue stuff for quite a few years now
3x drain and fill if auto with a short drive between each fill
ps fluid change
bleed brakes until you get all clear fluid out of each caliper
cabin air filter
ps fluid change
cabin air filter
lowrd on tein CS biatch
If U got access to a hoist go under the car check ur ball joints and pivot points for play. Basically reef on the wheel forward and backwards, left to right, up and down ...Etc.
Grab ur stabilizer links they should be able to pivot by hand if the are mint. When they get older u need to use an adjustable wrench to pivot them. And when they are bad. They do not pivot, and that will lead to an awful squeak in the suspension.
saberlove
03-11-2021 09:29 AM
handsom-hustla
11-13-2015 05:04 PM
