RL Calipers Fit behind 05 TL 17" rims!
#202
Whats up with RDX owners?
Just bought some RL Calipers, should be here Wednesday, hopefully NVA gets back to me soon on the brackets... I'm going to try using a 15MM spacer to clear the Stock CLS Wheels.
#207
IIRC E30 had Servos and they didnt clear.
#208
Yes sir, I think Eibach has a hubcentric 15mm spacer kit with extended studs around $100 bucks I'll get.
Just sent Paul payment, think I'm gonna powdercoat my calipers ABP or Red before I throw them on. What do you think the average charge should be on that?
#210
I just spoke with him and he said he bought Inspyres. The Servos are a toss up for fitment. It they have a high pad height then you shouldnt have a problem. The offset itself doesnt really matter, the spoke clearances do.
#211
03 cls stockies needs at least 15mm spacers or maybe 20mm. I knew Rotora BBK needs 5mm spacer on stockies. so i tried 5mm on RL calipers, but it didn't work. and i tried 10mm. not even close! I was like f&*k this!! 01,02 cls stockies won't even clear inside of wheel. so you better find wheels to clear RL calipers. anyway this is one of the best upgrade so far!!!
#214
Won't be running stock wheels anymore. Scored something nice and the calipers will be back from the powdercoaters next week. Got them in lollipop blue which was close to the factory abp.
#217
No.
#219
whats the cost breakdown? --calipers, bracket, rotor, lines and fluid
how does it compare in price to Excelerates 6 piston wilwoods?
Im running enkei 18"s on the 01TL so clearance should be ok
#222
The Wilwood kits come in either 4 or 6 piston varieties. The 6 piston costs over $1k though.
Look at spending around $700. The biggest variable is the calipers themselves. Check out Car-Part.com for calipers. You want 05-07 RL.. I heard there was a slight difference in the 08-up but Im not sure what it was.
#224
For those with the BBK, are you guys experiencing any issues with the ABS system? StopTech has a really great article that addresses the problem. http://stoptech.com/tech_info/wp_abs_bigbrakekits.shtml
Basically, it explains how your ABS system uses an algorithm containing some very specific numbers to minimize stopping distance and allow vehicle control under hard braking. Going to a larger rotor and pad set up has adverse effects on the performance of the system.
I had upgraded the 10", single piston brakes on my '97 2.2CL with the NSX set up. I believe the 2nd gen are similar to 1st gens in that the front ABS sensor counts the teeth on the axle. The actual speed of the wheel might not directly effect the system, but the beefier brakes have increased bite and probably effect the pulsing of the caliper.
I haven't done any hard braking since the upgrade other than immediately after the install, I had bed-in the pads and rotors by following StopTech's procedure. That was until last week, when I was traveling at roughly 75 mph on the highway and suddenly had to stand on the brakes. The front right wheel locked up. It didn't release until I had let off the brake pedal at around 50 mph.
I'm a bit concerned about this problem and wanted to know if any of you had come across it?
#225
I havent run into any issues, only once in a panic stop at a high rate of speed (read - illegal) and ABS kicked in for a moment then I backed off a bit. Im sure the balance of the ABS is thrown off a bit.
#226
I personally never had to apply the brakes hard enough to engage the ABS prior to that day. At least on dry pavement anyways. So I don't have much to compare it too. Locking one wheel for as long as it did has me a bit worried.
#227
Not much different. It stopped the car though, and thats the important thing. Went from about 95 to 45 pretty quickly. I didnt have just one lock up on me, I think all locked up a bit, because when I slammed on the brakes the car got a bit squirrelly.
#230
Shouldn't have a problem running them. The 5AT uses a similar brake bracket as us. The models with the "Brembos" dont use a bracket, the calipers bolt directly to the knuckle from behind. And you should be able to run the A-Specs. I can run them on mine.
#231
GO RANGERS!!!!!!!!!!!!!!!
I had to stop quickly several times before and after the upgrade. The only change was much improved braking.
I'd have that caliper and it's line checked.
#232
Mr. L.E.D.
question regarding wheel position using the different rotors. my wheels are hellaflush and i cant afford any lower offset of the front wheels so when looking at e30's pics and seeing that the rotors hat is sitting virtually flush with the end of the hub kind of worries me because it looks as if the EBC rotors are acting like a 5mm spacer or somewhere around there.
then civicdrivr said his hub actually sticks out the same as oem if not more with Powerslot rotors. since 2nd CLs and 6th gen accords are pretty similar i figure i'd have the same fitment as you guys so i wanted to get this clear before i choose which rotors to buy.
the powerslot rotors do cost a little more so i really should just go with those to be on the safe side but i wonder if anyone else has noticed their wheels being a little lower offset (sticking out more) when using the EBC rotors.
#234
Regional Coordinator (Texas)
I haven't had a time when I had to "Slam" the brakes, but i came pretty close to it several times and these RL brakes do the job pretty damn good compared to OEM CL calipers. They feel like regular brakes unless u push down on them close to the slamming them.
#236
If youre asking about caliper to wheel clearance, it all depends on if the wheel is BBK friendly.
#238
From what I gather from his post, he's already running an aggressive fitment.
#240
Mr. L.E.D.
From what I understand about the differnece between your powerslot rotors vs e30s ebc rotors is that the hub which the rim sits on is virtually gone on his setup but is still available on yours. And since the rims sit against the hat of the rotor, by theory my rims would sit exactly the same way they r now on my car if I use the powerslot rotors but if I use the ebc rotors then my wheels would stick out several mm more.
Do u happen to have a pic of your rotors installed on the car with the wheels off maybe if i had a picture to compare your rotors to the ones e30 posted.
Sorry if its still unclear. Worst case ill just spend a few more bucks for the powerslot rotors since u said u still have a hub for the rim to sit on.
