RL Calipers Fit behind 05 TL 17" rims!
Old 01-18-2011, 04:00 PM
  #361
aznboi2424's Avatar
Originally Posted by gnuts
has anyone just bought the used calipers and thrown them on without rebuilding them?
I did as well. I went the cheap route and everything works.
Originally Posted by ANC297
Very tempting as I am looking for a bbk.
My only issue is I just got new tires on stock wheels...Which apparently do not clear the calipers? 02tl-s
You need about a 15mm spacer to clear the spokes.
Old 01-18-2011, 06:05 PM
  #362
Quarantuning
SlickShiftNall6's Avatar
Wink
This just in:
RL calipers might have saved my life yesterday!
Alright I might be over exaggerating, certainly saved my front end some damage. But really I almost rear-ended someone yesterday. They obviously weren't paying attention to the person turning in front of them. Cruising along at like 25-30 on a local road. I look away for a split second (at my phone) I look back up and no less than 10-15 feet in front of me two cars are stopped.
The Audi in front is in a panic stop with the trunk in the air from hard braking just coming down. I jammed on the breaks hard, I mean this is the hardest I ever stopped in 4 months with these breaks. The tires even chirped, I went chest first into the steering wheel. I still had to yank the wheel into the next lane looking at my rear-view hoping there wasn't a car there. I mean it was a blind turn I had no time to check. I had just enough time ahead of a fedex truck to make it!!! Crazy,... closest call in a long time.
I can't say for sure but stock calipers might not have given me enough bite to allow me to swerve, or swerve without losing control.
if you think upgrading your brakes is worth it.
Old 01-19-2011, 06:09 AM
  #363
p.diddy's Avatar
oh yea its def a day and night difference between the stock brakes and the RL brakes. i love these brakes.
Old 01-19-2011, 06:45 AM
  #364
3.5 psi
gnuts's Avatar
damn, i may have to get these....and some 3rd gen TL rims
Old 01-19-2011, 09:40 AM
  #365
p.diddy's Avatar
i say do it. they cost half the price of the aftermarket ones likes rotora and brembo and i really like that it has ACURA stamped on them.
Old 01-19-2011, 12:09 PM
  #366
AM To WDP In My Garage
acura_dipset_tl's Avatar
This.
Old 01-20-2011, 04:30 PM
  #367
aznboi2424's Avatar
Originally Posted by SlickShiftNall6
This just in:
Thats exactly what ABS is designed to do: applies your brakes so that you get maximum stopping distance while maintaining the ability to turn. This result is from the ABS system, not the brakes entirely. But I'm sure that they did help decrease your stopping distance.
Old 01-28-2011, 06:02 PM
  #368
J33 stroker
Imageless83's Avatar
New member here...been running them on my 7.5th gen Accord sedan since last year and diff. is nite and day compared to the stock calipers. I bought the 05 RL calipers with about 60,000 miles on them and will probably rebuild them next year.
Old 02-14-2011, 09:56 AM
  #369
6mt swapped..smart
AnthraciteTypeS's Avatar
Does anyone know if as aznboi noted above: will 15mm spacers allow 03 cls wheels to clear the rl calipers (the same as 01-03 tls wheels)? The wheels arn't going to stick out horribly and look hideous right? Or should I just go 3rd gen TL wheels
Old 02-15-2011, 06:09 PM
  #370
aznboi2424's Avatar
15mm should clear based on my measurements but it really depends on the spokes too.
55-15 would be a 40 offset but the 3G TL wheels are +45 offset and they clear.
Old 03-19-2011, 05:08 PM
  #371
ivan06106's Avatar
were can i get them brackets...i recently purchased the rl calipers just need the bracket
Old 03-19-2011, 06:25 PM
  #372
Quarantuning
Pm member nva-av6 he makes the brackets.
Old 03-20-2011, 02:16 PM
  #373
StreetKA's Avatar
can someone measure how much clearance TL rim has with these calipers preffered in mm ?
Old 03-20-2011, 02:40 PM
  #374
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,763 Likes on 1,228 Posts
I can't measure since my car has been gone for almost a year but I have this picture.
Old 03-20-2011, 03:23 PM
  #375
StreetKA's Avatar
Thanks for picture but what im looking for is spoke clearance. If someone can post spoke clearance measurements i will greatly appreciate it. Based on that measurements i will be able to see if my servos will clear rl calipers
Old 03-21-2011, 11:30 AM
  #376
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,131 Likes on 4,802 Posts
I took the TL wheels off my car last week. If you know someone with a 3rd gen TL 6MT, put one of your servos on their car. If they clear, they should clear the RL calipers. But I have a feeling they wont.
Old 03-21-2011, 11:35 AM
  #377
StreetKA's Avatar
Thats actually good idea. Thanks!
Old 03-22-2011, 02:54 PM
  #378
aznboi2424's Avatar
Go back a couple pages, I gave the approximate mm clearance from the rotor to the top of the caliper. I think its like 20 or 30mm if I remember but I would go back to be sure. But something with at least +40mm and no lip should clear unless its the 3G TL wheels, those are +45mm
Old 08-03-2011, 01:05 PM
  #379
Recently turned 18
Blitz's Avatar
I hate that I'll have to use the TL wheels. I REALLY don't like them at all but I'm going to need something since these don't sound like they'll fit with the 03 CL's even with spacers. And are those the ONLY options? The A-spec wheels won't fit or something from somewhere else? I'm talking inexpensive and easy to pick up. The TL's are going to be my winter wheels anyway. I have my eyeballs set on something more..."aesthetically pleasing"...for the rest of the season.
Also, are the EBC rotors the only option? They're nice but I want crossed drilled (or dimpled) and slotted.
Old 08-03-2011, 01:18 PM
  #380
aznboi2424's Avatar
A-specs should work as well since they are factory wheels for the TL. I have tried several wheels that fit without spacers. I have a set in my garage with 35mm offset with clears the BBK and I'm currently running a set of RX-8 wheels that are +50 offset with 15mm spacers. I found out that wheels without a lip is a must for clear the BBK. I think the general rule is that it has to be below +45 offset with no lip.
As far as rotor options. I just ordered a set of 350z brembo sized blanks. It was a no name brand from advanced auto parts. Basically anything that fits 350z brembo option will work.
Old 08-03-2011, 01:36 PM
  #381
civicdrivr's Avatar
As long as the rotors are from a 350Z w/Brembos, you can use them.
As long as the wheels clear the stock Brembos on the 04-06 TL 6MT or 07-08 TL-S, they will clear these brakes.
Old 08-03-2011, 02:01 PM
  #382
aznboi2424's Avatar
Thats the cliffs version of what I said
Old 08-03-2011, 02:11 PM
  #383
Recently turned 18
Blitz's Avatar
I've been gone for awhile and have forgotten a lot of information that I barely knew. What wheels do you/did you have that fit without issues? Remember...another key thing for me is CHEAP and fits. I've got the nice ones that fit covered and barring those cease to exist or a set of Volk GT-S or GT-V's pop up, I'm just looking for some junk to throw on there when they're not on.
Old 08-03-2011, 02:18 PM
  #384
aznboi2424's Avatar
If your looking for junk or cheap then the 3G wheels. I found a set with tires for a couple hundred bucks. What I have are a set of aftermarket wheels that will more then likely cost more then the 3G wheels. You can also try finding a set of wheels that are 40+ offset or lower without a lip, they could fit too.
Old 08-03-2011, 02:20 PM
  #385
Recently turned 18
Blitz's Avatar
Awww yeah! TWITA. Hahaha. I should say "junk" with quotes. Something that I don't care about scratching. I don't want bent crap that will wobble right off the car. LOL Not THAT kinda junk!
Old 08-03-2011, 02:21 PM
  #386
6mt swapped..smart
In the process of getting my rl calipers powdercoated now, and a few things came to mind.. are you guys with rl brakes noticing you have to push down farther to really start stopping? Back to throwing off the braking bias from a while back in this thread, is the cl master the same as the rl master cylinder? Just wondering because I was worried the stock cl master or stock proportioning valve wasn't designed with the purpose of pushing 4 pistons. Now I realize this goes for most all BBK kits available for our cars, but was just wondering...
Old 08-03-2011, 02:23 PM
  #387
Recently turned 18
Blitz's Avatar
Where you getting yours powdercoated? Someone around here mentioned Waldorf but I need to find that post again.
Old 08-03-2011, 02:32 PM
  #388
aznboi2424's Avatar
Well I'm simply saying that the 3G TL wheels seem to fit the bill. They are pretty inexpensive. Just search on craigslist. And I bet you don't care about getting those scratched.
Yes, I noticed that too, even after bleeding the brakes (make sure you do that, you can get a lot of bubbles trapped in those pistons). I think it is the fact that the 4 pistons creates more volume so the pedal is softer. I think SS brake lines are in order to fix it. (I'm ordering a set soon).
I highly doubt the CL and RL share a master cylinder.
Old 08-04-2011, 10:31 PM
  #389
6mt swapped..smart
Just getting them done by a buddy locally..
Azn^^^ I don't think SS lines are going to fix the issue to the point i'd be satisfied
Anyone know the answer to any of the concerns above?
Old 08-05-2011, 07:16 PM
  #390
anthracitecl's Avatar
I didn't notice that. I also replaced brake line w/ss line at the same time when i installed RL calipers. Maybe that's why.
I got my calipers powdercoated from this guy. He is pretty good and cool guy.
I know few AZ member got theirs done from him. Location is White plain, MD. I know you are in MD now.
http://www.customfunctionz.com/
This is my caliper he powdercoated. He sent me these pics right after he finished powdercoat. He wanted make sure if i like the finish.
still look fresh!!
Old 08-05-2011, 07:23 PM
  #391
Recently turned 18
Blitz's Avatar
Looks VERY good. Thanks for the link.
When you say you "didn't notice that" are you saying you didn't notice any changes for the worse in the braking performance? Trying to clarify.
Old 08-05-2011, 08:33 PM
  #392
^ This. and for braking performance, day and night difference! one of the best mod so far!
Old 08-06-2011, 10:51 AM
  #393
civicdrivr's Avatar
The pedal will be slightly softer with the RL calipers since you now have to move a lot more fluid for the four pistons. It shouldn't be very soft though.
Old 08-06-2011, 04:25 PM
  #394
aznboi2424's Avatar
Yea, so thats why properly bleeding the brakes and SS lines are probably the best we can do at the point.
To those with SS lines, did you replace all 4 or just the front 2? I don't even know if they sell just 2 SS lines.
Old 08-28-2011, 09:56 PM
  #395
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Maybe i missed it but the 3rd gen TL Brembo calipers are they the same as the RL?
Old 08-29-2011, 12:21 AM
  #396
StreetKA's Avatar
No
Old 08-31-2011, 07:45 PM
  #397
aznboi2424's Avatar
The RL calipers arent even made by Brembo.
Old 08-31-2011, 08:50 PM
  #398
AznWay's Avatar
Anyone know how to get that glue looking yellowish color off the word "ACURA" on caliper? (peeling off already) I try using PB glue remover with no lucky.
I'm thinking of trying quick like sanding. Would anyone have better suggestion?
Old 09-01-2011, 02:59 PM
  #399
aznboi2424's Avatar
huh? I didn't have any yellow on the face of the caliper.
Old 09-01-2011, 03:43 PM
  #400
p.diddy's Avatar
me either.
Quick Reply: RL Calipers Fit behind 05 TL 17" rims!
