lip for CL 2g
3.5 psi
no sorry, but it's just beefier than the regular aspec. and has exhaust cutouts. Getting it to fit would be the same deal. You'd just have to make sure the exhaust cutouts line up with yours or have your muffler tips modified after. the WW lips are super bendy which helps.
hows that WW front fit? I'm running 99-01 TL oem, frowns from certain angles, hate that
how much did you have to cut?
how did it fit along the back of bumper?
any pics of fitment before you molded it?
i visited your other thread, looks good in white...
https://acurazine.com/forums/photogr...-build-877419/
teh CL (02-22-2015)
3.5 psi
the WW front I cut into 3 pieces and filled the gaps. I can see how DL fit the rear as my gaps there weren't that big, but in the front there were some decent gaps. Fill those gaps with material you cut off the sides skirts.
probably 2 inches or so cut off flush with the wheel well, i cant remember. i started in middle of rear and tacked it on with screws to hold in place as i went around the corners. once your satisfied everything is even then sharpie the line onto the bumper so you know where to place it when you permanently attach. once the end caps are off, as i said cut off the little tab part and put that back on the rear lip to give it a finished look. here is a few pics
Hmmm yeah thanks I see DL does his own body work and I guess you do too, but I dont, I'll do a test fit maybe but that's it so thanks anyway I'll post some pics after
calrow
05-03-2017 10:21 PM
