Got my 01 CL S yesterday
#363
GO RANGERS!!!!!!!!!!!!!!!
Waterpump, T-Belt & assorted tensioners/pullies in, valves adjusted, exhaust were tight intake spot on, rear main seal & retainer is being a pita, Honda sent the wrong one & the 0 ring I got from Honda here seems loose.
Internals very clean.
#366
Carfax shows dealer service every 3k. We are going to get that cleaned or replaced.
#367
B A N N E D
if you don't mind take a picture of the inside of the oil pan also, should kinda look like mine also
also that clean head looks to be the front bank btw, i bet the rear one does have some brown to it though, but that is more due to that rear bank running that much hotter then the front one (lack of airflow around that head in general)
#368
04/14/2004 ALBUQUERQUE, NM 11 Motor Vehicle Dept. TITLE (Title #:041054G04002398) REGISTRATION EVENT/RENEWAL (Lien Reported)
05/24/2005 ALBUQUERQUE, NM Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
06/09/2005 ALBUQUERQUE, NM 15,003 Dealer Service LUBE, OIL/FILTER CHANGED
01/12/2006 ALBUQUERQUE, NM 22,201 Dealer Service LUBE, OIL/FILTER CHANGED VEHICLE SERVICED
04/21/2006 ALBUQUERQUE, NM 24,744 Dealer Service VEHICLE SERVICED
06/22/2006 ALBUQUERQUE, NM Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
08/18/2006 ALBUQUERQUE, NM 29,377 Dealer Service VEHICLE SERVICED
10/18/2006 ALBUQUERQUE, NM 30,896 Dealer Service BRAKES SERVICED VEHICLE SERVICED
05/30/2007 ALBUQUERQUE, NM 35,016 Dealer Service VEHICLE BODY SERVICED BRAKES SERVICED ELECTRICAL SYSTEM SERVICED
VEHICLE SERVICED
12/21/2007 ALBUQUERQUE, NM 40,468 Dealer Service VEHICLE BODY SERVICED EHICLE SERVICED
03/14/2008 ALBUQUERQUE, NM 42,231 Dealer Service DOOR SERVICED VEHICLE SERVICED
08/01/2008 ALBUQUERQUE, NM Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
10/08/2008 ALBUQUERQUE, NM 47,330 Dealer Service VEHICLE BODY SERVICED VEHICLE SERVICED
01/12/2009 ALBUQUERQUE, NM 50,042 Dealer Service BRAKES SERVICED VEHICLE SERVICED
12/04/2009 DESERT SOUTHWEST REGION 53,743 Auto Auction REPORTED AT AUTO AUCTION
01/14/2010 DESERT SOUTHWEST REGION Auto Auction AUCTION ANNOUNCED AS SALVAGE, EXTENT OF DAMAGE UNKNOWN
Apparently the LKQ guy was wrong about when it was wrecked.
VEHICLE SERVICED
#369
That is the front, it was on the stand at an angle that put the back head underneath & I could not take a picture. I'll get better pictures Monday after I drop off the car.
I did not have my camera because he called me when I was at breakfast & said I needed to find the parts we need immediately, I ran to Honda & got them.
#370
B A N N E D
as said before the vehicle proably had been wrecked a couple of weeks ago, cause it takes time for the insurance and such to process the vehicle and get it to auction
but your salvage yard did only strip the motor out as said like a week or two ago, so that part is true
and btw i much rather have had a motor that has been sitting in the actual vehicle, upright, and with everything still attached, then to have it sitting in some warehouse on it's side, let alone probably getting handle roughly too
#371
I saw it in the van, the only thing I needed to verify was miles because there was no battery so no Odo.
I am very happy to see this service info on the carfax as well as the one owner deal.
My mechanic made some calls and is looking for RL pistons so we can use my heads, if he can get them it will take another day to send the heads out to be rebuilt.
#372
B A N N E D
#373
I have no idea what you are trying to say.
Do you know what a hypocrite is? I did not say one thing and do another.
Judging by your immature posts (driving at insane speeds, driving on a bad tire etc) you have nothing to say I want to hear.
My avatar is funny, you may have all the missing vowels.
O, U, E.
O, U, E.
#379
Good for you you found another means of creating something from nothing.
I do not care that you live in your Mom's basement, in a diaper and have not seen the sun in years.
We already concluded that when you completed 3k posts in under four months.
How 'bout we return to the topic of this thread?
#382
Whats up with RDX owners?
Uhhhhhh....
So hows the car comin?
#383
Great thanks for askin'
Got 29 mpg on the last tank that will run through the original motor.
#384
Sweet! Youre going to love the torque.
#385
I just dropped the car off. He got the heads & pistons yesterday and the motor is ready to go in (minus the UR pulleys, and 09 IM from my motor)
I am trying to get back over there before he gets too far so I can get more pictures.
#386
moar.
#388
The UR Pulleys?
They are coming off my motor right now. It is out of the car, he is having lunch, then he will transfer my headers, pulleys & 09 IM.
#390
Motor is out. The tensioner on the Ody is different, we'll know after it's back in if there are issues can't see yet because need the AC compressor back in place.
The other issue is the coolant plumbing is a bit different coming out to the transmission cooler hopefully a three way coupling will solve it.
Empty bay.
New motor with header front
New motor with header rear
Old motor
Old motor TB full
Leaky old motor rear main seal
Empty bay.
Old motor
Old motor TB full
#391
Nice pics.
e30cabrio: If you get a chance, can you ask your mechanic what torque value he uses for the bolt on the 'Timing belt adjuster' when replacing that part? That's the bolt that pits200 had an issue with on his TB failure thread.
Number 7 on the link below:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
The torque spec for that bolt is non-existent in the helms manual, I far as I can find. Thanks!! And good luck with your new motor.
#392
I think Pitts or someone came up with 19lbs.
I'll ask.
I just spoke to Aj, my mechanic. The motor is in all seems well, if there is a problem with the belt the UR pulleys call for that I brought him he will order a number of belts until he finds the right one so that issue is solved.
Whew.
I'll ask.
Whew.
#394
Yes & a 3.7 forged crank.
Need to get a 3.6 badge lol
#396
I cannot wait to get it back, the rear motor mount was on the verge of breaking so I had to run to Acura and get one, I'll get the 80A Urethane in it so it will be ready to go in long before this one dies.
#397
El OLE!
I did not paint my valve covers.
Messenger broken?
Messenger broken?
#399
