04-06 acura TL base wheels
Old 04-05-2015, 05:57 AM
pinoy2o9's Avatar
im on D2 Racing RS coils and im tucking just enough.
im bout to purchase a set of 04-06 acura TL base wheels. what would you guys recommend with tire size? im already fender rolled. no camber kit yet. i also have the eibach sway bar kit also.
225/40?
215/40?
225/45?
215/45?
Old 04-05-2015, 09:22 AM
Received 16,260 Likes on 11,971 Posts
the obvious answer is to go with the same rolling diameter as stock.
It will be YOUR choice if you choose to stretch the tire.
Old 04-05-2015, 09:27 AM
from this calculator:
http://www.1010tires.com/Tools/Tire-...5R17/215-45R17
the only one that is closest in rolling diameter to the stock tire is the 225/45/17s
play with the online calculator to find out which tire is the same rolling diameter as your stock tires.
Old 04-05-2015, 11:36 AM
01CLinprocess's Avatar
I run 235/45/17's on mine. You're referring to the 17x8's right?
Fitment is not an issue. I'm slammed on Tein SS's and everything clears just fine with rolled fenders. A camber kit is a must if you plan to lower your car though.
I went from 215's (winters) to 235's and the difference was night and day. The car feels planted, the steering is still light.
If you're looking for daily driving tires I'd recommend Goodyears's New Eagle Sport All Seasons (W Speed Rated). For a W speed rated tire they have amazing tread-wear, and an amazing warranty. Check them out on tire-rack, make sure you're looking at the W-Speed Rated ones.
I got mine mounted and balanced w/ included premium warranty (punctures, excessive wear, etc.) at Sam's Club for $500 out the door.
You'll love the TL wheels. You get OEM Quality with more meat than the CL-S Wheels came with. Cheers!
Old 04-08-2015, 01:03 AM
AM To WDP In My Garage
acura_dipset_tl's Avatar
Im running 225 45 17 with no issues.
Old 04-09-2015, 03:12 AM
pinoy2o9's Avatar
Thanks for the good info Guys
Old 04-16-2015, 07:32 AM
YeuEmMaiMai's Avatar
I would not use 04-06 base TL rims, they are easily bent
Old 04-16-2015, 07:46 AM
talking out of your ass.
they are both made from Enkei
Old 04-16-2015, 03:19 PM
No, I am not... you hit a good pothole with one and it's going to bend... they may be made by the same company but one isn't as strong as the other...
You see years ago when I was researching putting on RL calipers, I had to find rims that would clear them and the 04 TL rims were at the top of the list. I talked to multiple people whom have 04-07 TL and they ALL had bent rims from the roads around here. Talked to my dealer and more than 1 person confirmed that those rims are not as strong as the previous gen's type S rims... the dealer stated that they were surprised by the number of rims that they had to replace on those cars... and they referred to them as being made out of Jell-O.
Old 04-16-2015, 03:53 PM
okay....tell them fools to stop hitting shit.
my 2006 TL wheels arent bent.
02-25-2020 09:57 AM
Soul_Deamon
11-13-2018 04:44 PM
nanos
11-12-2015 08:41 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: 04-06 acura TL base wheels
