Yungone501's- Excessive infatuation with the J-series
Old 02-17-2013, 02:52 PM
  #161
J-series addict
yungone501's Avatar
Received a few photos from Hickam lastnight. The first photo shows how the cylinder heads exhaust port is actually smaller than the flanges ID therefore we should be able to use them. This is great news cause they were about to become Matt's "shelf stock". ;-)
The final 3 pics show the beginning of the manifolds from the heads and the last is the brace of which the turbo will be mounted.
Rear
Front
And the brace
Old 02-17-2013, 03:34 PM
  #162
@Mikeshlong On IG
mikebikelife's Avatar
Well damn , there's not much room for it is there
Old 02-17-2013, 06:55 PM
  #163
J-series addict
yungone501's Avatar
Apparently, Matt has a vision. I'll let him roll with it...
Old 02-17-2013, 08:39 PM
  #164
Lone Wolf
brian6speed's Avatar
Yea looks like a tight fit and that is with no fans installed.
I want to ask what size temp sensor adapter do you have? I need to order one. Was it the 30mm?
Old 02-18-2013, 07:23 AM
  #165
J-series addict
yungone501's Avatar
Not really sure. I happened to make this one from the coolant tube that's beneath the lower manifolds on a j32a2. Exact match to the ID of radiator hose.
Old 02-18-2013, 02:25 PM
  #166
03 CLS-6
1foxbody's Avatar
I'm happy your going the turbo route. I can't wait to see what type of power you make. I didn't know you have a auto trans. That will be consistent and fun!
Old 02-18-2013, 03:51 PM
  #167
J-series addict
yungone501's Avatar
Thanks man, me too. Just to let you know, I won't be running the turbo at its maximum potential for the engines sake. Although the motor could handle much more, it will be de-tuned to around 450-500hp at most. And yes, it's an auto.
Brian6speed, this is for you:
32mm is the adapter you're looking for.
brian6speed (02-19-2013)
Old 02-18-2013, 04:00 PM
  #168
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ you are detuning for the transmissions sake
IMO the engine will hold up 450hp fine....the AT might not be able to (at-least thats what I have seen on the 3G Side)
eager to see more
Old 02-18-2013, 05:33 PM
  #169
J-series addict
yungone501's Avatar
eager to see more
As long as I don't boost under gear changes and replace the fluid every other oil change or so, I can hopefully get a little play time out of it. But yes, eventually, death shall become of it.
1foxbody (02-18-2013)
Old 02-18-2013, 11:01 PM
  #170
J-series addict
yungone501's Avatar
These two pictures made my Monday worthwhile.
The following 4 users liked this post by yungone501:
NvrDwn (02-19-2013), richardparker (02-19-2013), Stephen00TL (02-21-2013), vic06b (04-09-2013)
Old 02-19-2013, 12:50 AM
  #171
@Mikeshlong On IG
Mind = Blown .
yungone501 (02-19-2013)
Old 02-20-2013, 10:42 AM
  #172
HickamHatch's Avatar
Mind = Blown .
If this blows your mind, wait til you see how much room the car doesnt have for the 3" downpipe.
Old 02-20-2013, 11:54 AM
  #173
@Mikeshlong On IG
True .
Old 02-20-2013, 02:31 PM
  #174
03 CLS-6
1foxbody's Avatar
There's a very easy fix for that. Make it go straight out of the hood lmao!! Problem solved!
Old 02-20-2013, 03:49 PM
  #175
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Some fancy pipe work and Twin 2.25/2.5 down the front and under the engine like the stock single traveled
Edit: forgot hes running the honkin auto. Less room to work with
Old 02-20-2013, 07:31 PM
  #176
pmak23's Avatar
Old 02-21-2013, 09:45 AM
  #177
J-series addict
yungone501's Avatar
Front bank all tacked up in place. Photo also illustrates how much room the man has to work with. All hoses will be thermal sleeved.
Went ahead and ordered a dual core all aluminum radiator along with two 12" Mishimoto slim cooling fans. This should help with reducing engine coolant temps as aluminum has way better heat transferring properties than plastic (side banks).
Old 02-21-2013, 10:08 AM
  #178
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Not only did you do a nearly impossible swap but now yor turbo charging it. I am jealous lol
mikebikelife (02-21-2013)
Old 02-21-2013, 11:58 AM
  #179
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
So glad to see this build going to the next level, which rad did you order?
Old 02-21-2013, 09:32 PM
  #180
J-series addict
yungone501's Avatar
Correction, Hickam is turbo charging it. I'm just funding the project.
Might I add, he's made some good time considering he has limited time to work on the build. I'm very fortunate I have him to do the work. There's not many people one can trust whenever you're a car guy yourself.
Thanks. I ended up going with an eBay company that I have received firsthand feedback from called Radiator Classic. They also have a 99.3% feedback rating on eBay as well from 75,000 different people. I went with an 03-07 Accord dual core radiator (very close to AV6 specs) because it had the j-series radiator tube configuration. I payed $110 shipped and has a lifetime warranty against manufacturer defects.
Old 02-22-2013, 09:49 AM
  #181
swoosh's Avatar
damn that is SICK !! so jealous...
not of the car, but of your skill level
Old 02-22-2013, 10:50 AM
  #182
Kline's Avatar
i want to see what the dyno runs are. hopefully you get the power your looking for.
Old 02-23-2013, 07:23 AM
  #183
J-series addict
yungone501's Avatar
Had the pleasure of working on the Accord at Matt's shop yesterday. A close friend and I went after work to relocate the battery to the trunk and replace the radiator and install cooling fans. The radiator I ordered ended up not working due to the position of the upper hose but atleast we got the old one out. I ended up ordering a radiator from CSF that is specifically for the 3.0 6th gen Accord that was triple the price of the first one. Atleast we know this one fits.
Snapped a few pics while we there of Mr Hickams work. In person, it looks 10 times better.
Old 02-23-2013, 02:26 PM
  #184
@Mikeshlong On IG
Old 02-23-2013, 06:38 PM
  #185
TegoTL's Avatar
this is a crazy build!!!
Old 02-23-2013, 10:41 PM
  #186
fsttyms1's Avatar
Old 02-25-2013, 03:16 PM
  #187
swoosh's Avatar
Old 02-25-2013, 06:25 PM
  #188
J-series addict
yungone501's Avatar
Old 02-25-2013, 11:55 PM
  #189
J-series addict
yungone501's Avatar
Matt sent over a few shots of the downpipe fitted and tacked. According to him, this was the tightest fit he's ever done. Looking at a few of the shots, I realized how much time and attention to detail he puts into his work.
Old 02-26-2013, 06:41 AM
  #190
fsttyms1's Avatar
Old 02-26-2013, 09:19 AM
  #191
Brennan8's Avatar
so how is the trans with the auto i would love to turbo my 07 tl type s but places ive went to tell me it wont be worth it bec its auto any advice ?
Old 02-26-2013, 10:24 AM
  #192
3.7L Nitrous Breathing CL
richardparker's Avatar
Looking good.
I don't like where the hoses sit in relation to the piping.
Is the new radiator going to have the same inlet/outlet locations.
Time for a custom electric water pump/cooling setup.
Old 02-26-2013, 10:39 AM
  #193
swoosh's Avatar
SICK !!!
once you are done with that, we can work on my car
Old 02-26-2013, 11:46 AM
  #194
Brennan8's Avatar
^2
Old 02-26-2013, 12:10 PM
  #195
J-series addict
yungone501's Avatar
I'm honestly not sure how the auto will do in regards of traction...which is what I'm assuming you're referring to. I have yet to put it on the road. At 300hp, the trans. doesn't appear to have to much trouble but I also have 10.5" wide wheels atm. Guess we will see...this may just be the ticket I needed for a manual swap instead. ;-)
97BlackAckCL (02-26-2013)
Old 02-26-2013, 12:11 PM
  #196
J-series addict
yungone501's Avatar
Originally Posted by richardparker
Looking good.
Thanks.
But we're not finished just yet Rich.
Old 02-26-2013, 12:13 PM
  #197
J-series addict
yungone501's Avatar
SICK !!!
I'm down man! This has become my life seems like...good times.
swoosh (02-26-2013)
Old 02-26-2013, 01:04 PM
  #198
(Mid-Atlantic)
Old 02-26-2013, 02:27 PM
  #199
Thanks for posting the pics.
Inspiring idea's
Old 02-26-2013, 05:55 PM
  #200
swoosh's Avatar
imma take u up on that
Quick Reply: Yungone501's- Excessive infatuation with the J-series
