Where can I get my headers installed?
Old 06-09-2015, 09:31 AM
Nathan Allan's Avatar
OK slowly getting to the engine mods now but I'm trying to figure out if anyone knows a place in the savannah Georgia that installs headers. Tried meineke and the guy was scared about taking bolts off. And I don't have the space to do it myself.
Old 06-09-2015, 10:02 AM
3.5 psi
gnuts's Avatar
post this in the regional section.
Old 06-09-2015, 02:08 PM
~HondaF1~
R J Poseidon 6's Avatar
Or go to Orlando (short drive lol) and have it done by Kings Performance | I AM THE KING.
They know our car pretty well
Old 06-12-2015, 07:38 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
I would do the headers yourself, it's really easy. Spray the bolts on the heads with pb blaster a few days in a row and then the day before you are ready to do them crack each bolt at the head and make sure they move. If so, then I would proceed and do the header install. I did mine in 2 hours. Yes all the bolts were not seized thank god. But I made sure they were all movable prior to doing the install. If you have some seized bolts then I'd probably get someone who has been there and done that to do the install.
Old 06-19-2015, 11:56 AM
mike88se's Avatar
That's what I did although I still haven't had time to actually install the headers. None were seized... they all came loose pretty easy. The cat hardware was a totally different thing. All are seized and will have to be creatively removed... or would be if I wasn't putting a bigger cat on. I'm just going to cut the old one off. But anyway you do need some basic tools and a little mechanical aptitude. Good luck
Old 06-19-2015, 01:36 PM
Scottyknows007's Avatar
Yea I did mine myself and it wasn't bad at all except that the bolts on the cats were welded! I had to cut off the head and the bolt and drill out the hole.. that took hours!
Old 06-22-2015, 07:30 PM
Finally got them installed. Stoked
Now onto the next mod
Old 06-22-2015, 07:43 PM
3.5 psi
gnuts's Avatar
And...how's it feel?
Old 06-23-2015, 05:49 PM
The car is picking up speed quicker around 3000 rpms. Trying to figure out what my next move is to make this hoe go faster other than the obvious supercharger/turbo kits.
Old 06-23-2015, 06:21 PM
3.5 psi
gnuts's Avatar
Drop a J35A3 in. Enjoy.
Old 06-26-2015, 04:44 PM
~HondaF1~
Haa!
Old 06-26-2015, 05:27 PM
microracer24's Avatar
Which headers did you get?
Old 07-03-2015, 12:52 PM
Nothing spectacular, just some obx headers off of the old ebay machine.
Old 07-25-2015, 09:35 PM
Well you caught my curiosity. Tried looking for post with people doing this swap and no luck. Other that moror, what else is needed for that swap
Old 07-25-2015, 10:50 PM
3.5 psi
gnuts's Avatar
Are you auto or 6speed? If 6speed: https://acurazine.com/forums/second-...s-cls6-915106/
If auto then nothing I'm aware of.
Old 07-26-2015, 05:44 AM
Yea i have the auto
Old 07-26-2015, 10:15 AM
3.5 psi
gnuts's Avatar
If you were to put in the J35A3 then I would put in an accord trans at the same time. The CL trans wouldn't last long.
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
CLsuperhero
09-23-2015 12:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
2G-TL-Type-S-03
09-20-2015 12:48 AM
TxRzrBk
09-17-2015 01:07 PM
Quick Reply: Where can I get my headers installed?
