struts & springs
Old 01-27-2017, 02:33 PM
Bill 1's Avatar
struts & springs
with 196,000 I think I need struts. Do I need to get new springs also? I'm looking for better handling without a harsh ride.
Old 01-27-2017, 03:10 PM
3.5 psi
gnuts's Avatar
unless they're rusted or cracked I think you're fine to just replace the struts. You could opt for something like the Eibach Pro System Plus which is springs, struts and upgraded front and rear sway bars. This would really improve the handling of the car, but it does lower the car fyi. I'm not sure if you'd be okay with lowering but it really helps handling and visual appearance in my opinion.
Check out the vendor section on this site. They have deals on most things for our cars. Contact XLR8 Performance or HeelToe Automotive and they'll help you out.
Old 01-28-2017, 10:27 AM
YeuEmMaiMai's Avatar
The CL series does not have struts... they are a double wishbone setup in front with shocks and multi link in the rear with shocks. Acura sells the complete assembly for between $2-300 each. Struts are a load bearing member of the suspension, shocks are not.
The following 2 users liked this post by YeuEmMaiMai:
JarrettLauderdale (01-31-2017), M3thod (02-15-2017)
BROlando
95
01-11-2024 10:34 PM
Skirmich
1/2G MDX (2001-2013)
02-09-2020 06:58 PM
03max6spd
3G TL Photograph Gallery
14
02-14-2017 11:27 AM
Fisherkingrose
01-17-2017 07:55 PM
03TLSinCO
12-20-2016 02:32 PM
Quick Reply: struts & springs
